Author Topic: Rigol DG5102 Func/Arb WG  (Read 9343 times)
Offline kevykTopic starter
  • Firmware & Software by day. Electronics by night..
    • Bard Designs
« on: July 28, 2011, 06:20:34 am »
So I just received my 'brand new' Rigol DG5102 (which cost a fortune plus 1) and discovered that the Self Test menu option can not be selected (it's dimmed out). Furthermore the FRAM (whatever that is) is faulty according to the test info on screen.
Has anyone else experienced these issues with their Rigol WG's?  :-\
Thanks,
Kevin
Amuse, Inc.
www.mylivingdesktop.com
Kevin
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: Rigol DG5102 Func/Arb WG
« Reply #1 on: July 28, 2011, 10:58:13 am »
I wonder if you decided to spend 5k$ on FG why didnt you go with more reliable brands?
Oh, the joy of sending various electronics to silicon heaven
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: July 28, 2011, 11:22:43 am »
There is one here:
https://www.eevblog.com/forum/index.php?topic=1140.0
That short report suggests the firmware is buggy but it does work.
Best Wishes,
 Saturation
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: July 28, 2011, 03:05:08 pm »
I wonder if you decided to spend 5k$...
did i miss something?
The Ultimatum of False Logic... http://www.soasystem.com/false_logic.jpg
Offline saturation
    • NIST
Best Wishes,
 Saturation
Offline Bored@Work
« Reply #5 on: July 28, 2011, 04:12:00 pm »
But it is a Rigol. If you read the Rigol fanboys all over the Internet you know that Rigol never fails, their instruments can walk on water, and their support is delivered by mayan virgins.
  • Country: hr
    • HackLordSniper
« Reply #6 on: July 28, 2011, 07:58:59 pm »
I have been watching your coments. You dont  comment often but when you comment you make my day. The mayan virgins support idea is really a nomination for the post of a year :-)
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #7 on: July 28, 2011, 08:07:15 pm »
I would be interested to ( read ) the voice of Rigol about this.
Send them one email, and share with us their answer.
  • Country: my
« Reply #8 on: July 28, 2011, 09:07:07 pm »
An Agilent arb is in that price range.
http://www.amazon.com/Agilent-Function-Waveform-Generator-1-Channel/dp/B0041H33TI/ref=sr_1_2?ie=UTF8&qid=1311868280&sr=8-2
i mean i dont get it. the op asked for experience with rigol AWG, and then came the 5k AWG suggestion. did the OP consider to buy 5k AWG and then later decided to buy rigol?
Offline dfnr2
« Reply #9 on: July 28, 2011, 10:45:01 pm »
You didn't miss anything, you just don't believe your eyes.  The Rigol is a pretty fancy piece of kit, 100MHz, up to 1Gs/s 14-bit dual channel generator with specs pretty comparable to the Tek AFG3102, and about the same price.  I see the Rigol here in the US for $5000-$5500.  I think the Tek may have slightly less jitter, perhaps less memory; and can be had for a bit (but not much) less used on Ebay.
Personally, If I really had the need and the budget, and couldn't find something used, I'd go for the Tek.  At least there ethernet/GPIB/SCPI stacks are likely well debugged since they've been around a long time.  If simple UI stuff isn't perfect, I worry about what's hidden underneath.
Dave
« Last Edit: July 29, 2011, 12:07:36 pm by dfnr2 »
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #10 on: July 28, 2011, 11:50:39 pm »
You didn't miss anything, you just don't believe your eyes.  The Rigol is a pretty fancy piece of kit, 100MHz, up to 1Gs/s dual channel analyzer with specs pretty comparable to the Tek AFG3102, and about the same price.  I see the Rigol here in the US for $5000-$5500.  I think the Tek may have slightly less jitter, perhaps less memory; and can be had for a bit (but not much) less used on Ebay.
If the Rigol and Tek are similar spec and price, who in their right mind would buy Rigol?
Day Job: Mostly LEDs
  • Country: my
« Reply #11 on: July 29, 2011, 04:18:26 am »
ok i really missed somthing. in the title saying DG5102. i keep thinking of DG1022, so yeah, i feel like stupid now.
  • Country: hr
    • HackLordSniper
« Reply #12 on: July 29, 2011, 07:06:40 am »
Well to tell you the truth wherever i see words like "rigol" and "f.g" i immediately think about DG1022 because i would not think somebody would buy the model mentioned here
