Author Topic: Rigol ds1054z internal noise?  (Read 7488 times)
Offline MozeeTopic starter
« on: February 20, 2018, 05:28:05 pm »
Hello there,
I need your help guys with the noise I’m getting as indicated in the attached video
I was playing with this little thing and I read that the noise should be zero when coupling is set to ground but as you can see in the attached video it is not! Also there is about 50Mhz frequency being indicated and I have no idea where it is coming from.
Is my scope normal? Could anyone test his rigol scope to reproduce this behavior? What’s normaland what is not?
Note that I am somehow new to oscilloscopes!
https://youtu.be/TNAsUnpCdZM
We always learn, till the moment we’re dying , we learn how it feels to be dead
Online Fungus
Re: Rigol ds1054z internal noise?
« Reply #1 on: February 20, 2018, 05:39:28 pm »
I don't know where you read that but it's not true on a DS1054Z.
The following users thanked this post: Mozee
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #2 on: February 20, 2018, 05:53:47 pm »
It is the same on my unit.
Keep in mind though, that measurement takes place on screen and you have selected 10x probe, so all on screen values are measured times 10.
1x mode in the 1mV - 5mV range it measures around 300-500 uVpp.
Can not tell you where exactly that noise is generated - likely the ADC - but in my book the signal to noise ratio is pretty OK for a sub 400€ device :)
He’s like a trained ape. Without the training.
« Reply #3 on: February 20, 2018, 06:11:13 pm »
So your unite has exactly the same behaviour? Same noise and frequency?
Also would by any chance affect it’s  ablity to correctly measuring waveformes?
Also is there any way to reduce this noise to zero or its about or actually should I?
Offline frozenfrogz
« Reply #4 on: February 20, 2018, 06:44:44 pm »
Every scope will have some kind of background noise present. Reducing it to absolute zero does only work in a perfect world. If you really need that kind of precision for squiggly lines of very low voltage signals, be prepared to drop some serious amount of money on a differential preamplifier such as the Tektronix ADA400A plus maybe a scope with 12-bit ADC.
If that is the route you are wanting to go, head over to the m&ms (metrology maniacs, no offense! :-*). They can initiate you to the rites of hunting down noise!
If you simply want to see squiggly lines of your signal, don’t bother too much about it. Get to know your tool for what it can and can not do :)
« Reply #5 on: February 20, 2018, 06:52:27 pm »
You made me laugh also made my day knowing that my scope acts normal  ;D ..
To be honest I just wanted to know if my little scope is normal or not and I need to know the limitation of it so where should I start?
Offline tautech
« Reply #6 on: February 20, 2018, 07:29:03 pm »
Start by watching this:
https://www.eevblog.com/2014/04/10/eevblog-601-why-digital-oscilloscopes-appear-noisy/
Then Pt 2.
https://www.eevblog.com/2014/04/27/eevblog-610-why-digital-scopes-appear-noisy-part-2/
Avid Rabid Hobbyist
Online Fungus
« Reply #7 on: February 20, 2018, 08:01:41 pm »
The only way to reduce it is to live in a Faraday cage in a bunker with no electrical devices around. Even then it won't be zero.
No, don't worry about it, it's normal.
(It should actually be a little bit less when you connect a probe).
Then Pt 2.
You forgot this:
Offline MT
  • Country: aq
« Reply #8 on: February 21, 2018, 03:03:18 pm »
Hello there,
Why do you have one of the greatest electrostatic generating towels ever made on top of your scope?
Deliberately electrocuting all your bredboard setups?
The following users thanked this post: rodcastler, Mozee
Offline imidis
« Reply #9 on: February 21, 2018, 03:23:17 pm »
Plastic bag too?
Gone for good
« Reply #10 on: February 21, 2018, 04:02:53 pm »
Wow, never knew that this microfiber towel is an electrostatic charge generator! the plastic bag too!!
Offline ogden
  • Country: lv
« Reply #11 on: February 21, 2018, 04:51:28 pm »
Could you re-do your test? - Disconnect all probes/cables except power cord, set probe to 1X and bring up measurements using "measure" button, obviously set measure source to channel you are looking at. Mine shows Vpp = around 300 uV, @ 5ns/div. Funny thing that at 5ms/div it shows around 480uVpp :) yet I still find this normal.
Offline rodcastler
  • Country: cl
« Reply #12 on: March 07, 2018, 12:16:33 pm »
 Sometimes noise gets in through the mains. I have some LED strips to illuminate the bench I have to actually turn off in some measuring scenarios due to high freq interference coming from the power supply.
« Last Edit: March 07, 2018, 12:25:10 pm by rodcastler »
Offline Porcine Porcupine
« Reply #13 on: March 07, 2018, 11:45:47 pm »
Does anyone know what ground coupling on this oscilloscope does exactly?
I think on older oscilloscopes ground coupling physically disconnected the probe and connected the oscilloscope's input to ground using a switch you flipped or a relay. I don't hear a relay click when setting the DS1054Z to ground, so I assume it doesn't do that.
The manual says "When the coupling mode is "GND": the DC and AC components of the signal under test are both blocked."
Is it just filtering all frequencies? If that's the case, I'm not sure what use it would be. It wouldn't even allow you to check for an offset in the ADC.
By the way, some DSOs actually do just draw a line at zero volts when the coupling is set to ground:
https://www.tek.com/support/faqs/unlike-other-dsos-when-channel-coupling-set-ground-theres-perfectly-flat-baseline-ie-no
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #14 on: September 30, 2019, 03:32:08 pm »
YES mozee, it is really terrible the noise inside this scope,
it looks like either switchmode noise or cpu card crosstalk,
it is clearly not just white noise. see my pictures on this link:
webx.dk/rigol
did anyone with a good EMC background take apart this scope and investigate in the cause and solution of this ?
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
Online 2N3055
  • Country: hr
« Reply #15 on: September 30, 2019, 04:01:00 pm »
webx.dk/rigol
You didn't do your homework. You shouldn't have enabled 500uV/div (it is a software magnification, together with 1 and 2 mV /div), there are literally hundreds of places where people warn about it.
DS1000Z is not low noise scope but its just fine.
If you wanted 500uV /div in hardware (real ) and lower noise you should have gone with Siglent SDS 1000X-E series.
Offline oz2cpu
« Reply #16 on: October 01, 2019, 11:13:28 am »
well mr 2N3055, did you read my page ? seen any of the pictures ?
then you would have noted the noise it also seen in 1 2 5 10 and 20mV/Div
I dont need the 500uV div feature, it just came with the all features upgrade,
and the 500uV div feature should of course not affect any other settings.
SO YES, there is something odd spreading noise inside this type of scope,
and you can google a little bit and see it is not only me who see it.
Online 2N3055
  • Country: hr
« Reply #17 on: October 01, 2019, 01:55:07 pm »
What's with the attitude?
DS1000Z is not low noise scope. It has some clock bleed in signal but many scopes do. It is you who expect too much of a very cheap little fellow that is quite nice little scope.
In attachment you can see that it is well in specs, it's noise floor is in fact lower than 18000 USD Keysight both in P-P and RMS, because keysight has much larger bandwidth. With 20 MHz bandwidth limit on, Keysight has 10 dB lower noise floor and spurs. Although you can clearly see that it also has sampling clock spurs bleed in spectra..
For the money DS1000Z does good job.
If you need lover noise, sell it and buy SDS1000X-E instead..
That is cheapest option that will give lover noise for not too much money..
« Last Edit: October 01, 2019, 02:05:22 pm by 2N3055 »
