Author Topic: Rigol HDO1000 and HDO4000 12bit oscilloscopes launched in China  (Read 201500 times)
Offline Fungus
Re: Rigol HDO1000 and HDO4000 12bit oscilloscopes launched in China
« Reply #500 on: December 01, 2022, 05:43:53 am »
For those interested, Rigol EU now has a 10% promotion for the 1k series.
I wonder how their math works? I've tried to get "10%" from their numbers, and failed. Seems like more than 10% to me. :-//
Online 2N3055
  • Country: hr
« Reply #501 on: December 01, 2022, 07:46:49 am »
999 down to 899 is roughly 10%..
And then prices with tax just get calculated..
« Last Edit: December 01, 2022, 08:22:27 am by 2N3055 »
Offline MegaVolt
  • Country: by
« Reply #502 on: December 01, 2022, 08:02:25 am »
1188.81*0.9=1069.92....
Offline rf-loop
« Reply #503 on: December 01, 2022, 08:10:31 am »
1,188.81  down to 1069.81   is  ~10%  save.
I wonder how your math works?
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline Fungus
« Reply #504 on: December 01, 2022, 11:07:21 am »
Duh.  :palm:
I was doing 1188.81 / 1069.81
 :-DD
The following users thanked this post: rf-loop, 2N3055, Martin72
Offline tv84
  • Country: pt
« Reply #505 on: December 01, 2022, 03:56:43 pm »
Fungus, inverted as always...   ;D
The following users thanked this post: egonotto, tautech, Fungus
Offline svetlov
  • Country: ru
« Reply #506 on: December 07, 2022, 07:40:13 pm »
This store says they have them in stock -1072-74?
https://rigolshop.eu/
Offline skander36
« Reply #507 on: December 08, 2022, 12:21:10 pm »
Yes. They finish delivery for older orders.
Offline skander36
« Reply #508 on: December 08, 2022, 12:26:24 pm »
Someone asked about the app windows.
When they are more that two active on the screen, they can be moved between them. Actually it is possible. When you pick by the move icon a grey rectangle will appear suggesting a possible placement.
You cannot resize by drag or overlapp one over another. They will autoresize.
Anyway with too many open windows the scope became very slow.
« Last Edit: December 09, 2022, 05:38:52 pm by skander36 »
Offline Fungus
« Reply #509 on: December 08, 2022, 12:53:21 pm »
Oh, now we're going to complain about that...?  :-DD
Offline markone
« Reply #510 on: December 08, 2022, 01:32:38 pm »
Right now, FW bugs apart, there is only one thing i would complain about : FAN noise.
IMHO it's barely acceptable, much louder than DS1054Z, i would ask to Rigol an additional warranty sticker with official permission to open scope and change those t**** with something decent, at my expense.
What I do not understand is that there is plenty of space for at least 25mm deep FANs, where now we have 2x 60x60x15 19CFM @ 3600 that when are cold make buzz/rattle sound.
I measured average power draw, is around 46 Wrms (2 Wrms in standby),  all this noise is not justified.
Offline skander36
« Reply #511 on: December 08, 2022, 03:07:49 pm »
This can't be a complain, just an observation. Can't be part in a normal use case scenario. I have put so many windows on screen to show how they behave.
Offline markone
« Reply #512 on: December 08, 2022, 03:26:10 pm »
It would be nice to be able to turn off the screen for remote operation.
Offline Fungus
« Reply #513 on: December 08, 2022, 03:50:50 pm »
And totally failed to observe that putting multiple "windows" on screen is totally unheard of in a scope at this price level.
(until now)
From the screenshots I've seen: This 'scope appears to be much, much more than just a "low noise" oscilloscope. It's another real game-changer from Rigol.
Offline skander36
« Reply #514 on: December 08, 2022, 04:09:22 pm »
You are wrong. I have said that I put many windows on screen because only with more than two windows you can change their position. I have added that the scope became slow just as a mention that it will not be a working scenario for anyone. It's not about price level. Any embeded device will start to react slow as long as you start to activate more applications in the same time.
P.S. Maybe I wasn't explained very well. I remember that also some peoples failed to understand what I have said in tjhe past ...
Offline markone
« Reply #515 on: December 08, 2022, 04:17:14 pm »
(until now)
I would say that a couple of windows at the same time are not bad at all :
Offline skander36
« Reply #516 on: December 08, 2022, 04:33:56 pm »
Yes , on two apps the scope response is pretty well.
Offline markone
« Reply #517 on: December 08, 2022, 04:55:17 pm »
Yep and i'm impressed by the FFT function, this is my first personal DSO that can be operated as a Spectrum analyzer with FFT, with a decent sensitivity.
Offline Grandchuck
« Reply #518 on: December 08, 2022, 05:05:03 pm »
If you have the time, some examples would be appreciated.
Offline markone
« Reply #519 on: December 08, 2022, 05:17:55 pm »
Especially if you think that the 2 channels come at 699 plus taxes, even less during sales.
Offline Fungus
« Reply #520 on: December 08, 2022, 07:19:19 pm »
Q: Can it display the frequencies of the peaks in the FFT?
Offline markone
« Reply #521 on: December 08, 2022, 09:25:45 pm »
Yep, you can activate a table with peak frequencies and level.
Offline markone
« Reply #522 on: December 08, 2022, 09:34:44 pm »
To put it simple you have a single menu with everything you need with no hassle, a decent dynamic range and good refresh rate in awesome LCD panel.
Offline markone
« Reply #523 on: December 08, 2022, 10:28:03 pm »
Also quite accurate with level, in attachment video with FFT of AM modulated signal : Fc 1MHz -56 dBm (-69dBV), AM 10KHz-30%.
« Last Edit: December 08, 2022, 10:33:54 pm by markone »
« Reply #524 on: December 08, 2022, 10:31:47 pm »
No markers ?  :-//
Avid Rabid Hobbyist
