Author Topic: Rigol MHO98 Teardown  (Read 14026 times)
0 Members and 17 Guests are viewing this topic.
Offline norbert.kiszka
Re: Rigol MHO98 Teardown
« Reply #75 on: November 01, 2025, 03:36:56 pm »
As a side note, I didn't have the impression that there is any kind of fan regulation. It seems to always run a the same speed.
Maybe it will speed up when temperature will be higher.
# V03以及之后的硬件版本
if [ "$hdcode_val" -ne 1 ] && [ "$hdcode_val" -ne 2 ]; then
# 配置风扇驱动
echo "insmod /rigol/driver/pwm_fan.ko"
chmod 777 /dev/pwm_fan
fi
I sugest to check if this module is loaded with one command:
adb shell lsmod
Offline EEVblog
« Reply #76 on: November 03, 2025, 05:14:56 am »
I haven't heard it change.
Offline 0xdeadbeef
« Reply #77 on: November 03, 2025, 08:59:42 am »
I left it one for several hours to dump the SD card image (twice) and all the partitions and while it definitely got hot, the fan noise never changed at all.
Worked perfectly fine using a Ugreen "Nexode Pro" 100W USB PD power supply btw. and from what I can tell, it never used more than 60W (usually 55W or so).
adb shell lsmod
Sorry, I was lazy, but now I tried:
>adb shell lsmod
Module                  Size  Used by
usbtmc_dev             41918  2
libcomposite           60749  1 usbtmc_dev
focaltech_ts          213735  0
8821cu               3514198  0
afe_rms_gpio            2864  0
dac_gpio                3663  1
beeper_gpio             3684  1
spi2afe_gpio            5571  1
xdma                   99943  2
pcie_rockchip          20793  0
fpga_gpio               3923  0
spi2pll_gpio            4744  0
motorcomm              17303  0
pwm_fan                 8802  2
hdcode_gpio             3046  0
-> looks like "pwm_fan" is loaded...
« Last Edit: November 03, 2025, 09:09:16 am by 0xdeadbeef »
Offline Hydron
« Reply #78 on: November 03, 2025, 09:01:03 am »
Has anyone tried a 65W supply? Sounds like that would be enough and would be very handy as it's a common power rating, but is below the spec they ask for.
Offline 0xdeadbeef
« Reply #79 on: November 03, 2025, 09:38:42 am »
Keep in mind that most USB PD supplies are meant as chargers, not as permanent supplies. I.e. it's not uncommon that they can't keep their specified maximum load for more than 1-2 hours.
E.g. the Nexode Pro 100W that I used is known to drop to 65W after 1-2h under full load (100W). If a 65W supply would drop to e.g. 45W after 2h at 55W, this would mean that the scope would shut down in the middle of usage.
-> it seems safer to use a 100W PD supply just for this safety margin.
« Last Edit: November 03, 2025, 11:52:42 am by 0xdeadbeef »
The following users thanked this post: Fungus
Offline Fungus
« Reply #80 on: November 03, 2025, 11:37:40 am »
Dave measured consumption at nearly 60W so 65W is far too close for comfort. I doubt many power banks are designed to run at 100% for long periods of time.
I'd be looking for at least 80W and preferably 100W.
Offline Hydron
« Reply #81 on: November 03, 2025, 12:03:25 pm »
Was thinking more along the lines of laptop PSUs than power banks - these scopes are portable enough that it would be nice to run off the same PSU as the laptop you are likely also carrying. Most are 65W or so unless you have some awful tank of a laptop.
For fixed use for sure would use something chunkier.
Offline 0xdeadbeef
« Reply #82 on: November 03, 2025, 12:35:09 pm »
Some 100W USB-PD supplies are pretty small (e.g. the Ugreen Nexode Pro I used). Again, they are also not exactly meant to deliver 100W for multiple hours, but there seems to be enough safety margin to run the MHO98 for several hours.
Offline Fungus
« Reply #83 on: November 03, 2025, 12:52:34 pm »
Maybe the one Rigol supplied in the box...?  :-//
Offline Hydron
« Reply #84 on: November 03, 2025, 01:08:54 pm »
Yep - my interest in smaller supplies is so that I can keep the Rigol supplied one on the bench and use something else (e.g. the 65W laptop one I normally carry) when taking advantage of the scope's portability (half the reason I am getting one).
Offline 0xdeadbeef
« Reply #85 on: November 03, 2025, 01:49:45 pm »
Same idea here. Besides, it's really somewhat problematic to fit everything including the logic probe and the original power supply in the bag.
But the 100W supply I tried is really not that much bigger compared to a (very small) 65W supply:
2689703-0
Offline Fungus
« Reply #86 on: November 03, 2025, 02:08:02 pm »
... one on the bench and use something else (e.g. the 65W laptop one I normally carry) when taking advantage of the scope's portability
You can try it and see what happens ... but battery chargers are usually OK with less than 100% current, it just means the battery charges slower.
Oscilloscopes? Not so much.
« Reply #87 on: November 04, 2025, 01:59:38 pm »
Why not run this directly from a battery pack as with DHO800/900?
« Reply #88 on: November 04, 2025, 02:25:10 pm »
adb shell lsmod
>adb shell lsmod
Module                  Size  Used by
usbtmc_dev             41918  2
8821cu               3514198  0
afe_rms_gpio            2864  0
dac_gpio                3663  1
beeper_gpio             3684  1
spi2afe_gpio            5571  1
xdma                   99943  2
fpga_gpio               3923  0
spi2pll_gpio            4744  0
motorcomm              17303  0
pwm_fan                 8802  2
hdcode_gpio             3046  0
I did quick reverse engineering of this module. Looks like it reads some settings from the DT. And DT can be easily edited (only if You use Linux tho).
Beside of the DT, I suggest to look into /sys to find any files that can be edited to change this module behavior.
Offline Hydron
« Reply #89 on: November 04, 2025, 02:46:09 pm »
Does it load the DT from somewhere easily writable? If so I'll have a poke around when mine arrives. Also interested if there are any tweaks that can be done to the DT to make the damn thing boot faster - was this the case on the DHO8/900, or did that also need app tweaks?
I have a fair bit of experience hacking on device trees on Jetson devices, but have not played with any on other platforms or Android vs straight linux (assuming little difference there though).
« Reply #90 on: November 04, 2025, 02:50:02 pm »
It's not in any FS. Just inside Android boot image. You can find it with binwalk and extract it with dd.
« Reply #91 on: November 04, 2025, 04:57:16 pm »
I extracted and decompiled DT from the Dave SD card image (attachment).
Part of the decompiled PWM module code:
            iVar6 = of_property_read_variable_u32_array
                              (pdVar11,"cooling-levels",lVar9,(long)iVar5,0);
            if (iVar6 < 0) {
              dev_err(pdVar1,"Property \'cooling-levels\' cannot be read!\n");
              iVar5 = iVar6;
              goto LAB_001008a4;
There is no such entry in DT  :-BROKE
From the Linux kernel documentation about it:
  cooling-levels:
    description: PWM duty cycle values corresponding to thermal cooling states.
    $ref: /schemas/types.yaml#/definitions/uint32-array
    items:
      maximum: 255
DT can be edited, compiled back and saved into sd card (externally via adb and dd). The problem is with the size of compiled DT - there is no much space available. In such case whole Android boot image has to be extracted and generated again.
Eventually we can lower the size with deleting some entries. Which is not the easiest task to chose what can be deleted and what not so much.
Offline 0xdeadbeef
« Reply #92 on: November 04, 2025, 06:27:03 pm »
I would think that if Rigol decided to use a static value there, it's best not to mess with it.
The MHO98 gets pretty warm after some time. Even if the fan speed might be optimized for somewhat warmer Asian temperatures, it seems risky to lower it without any kind of temperature regulation in place.
It's somewhat disappointing though that Rigol didn't care about some kind of temperature controlled fan regulation (again).
But yeah, it's not killing me. Everyone who ever sat next to some PC based Agilent/Keysight/LeCroy gear might find the noise level to be pretty low anyway ;)
« Reply #93 on: November 04, 2025, 06:29:27 pm »
As You can see in my previous post, it looks like they started doing PWM control and abandoned it later - maybe they were in hurry to release it?
Offline 0xdeadbeef
« Reply #94 on: November 04, 2025, 06:41:36 pm »
Do the DHO models have fan control?
« Reply #95 on: November 04, 2025, 06:47:30 pm »
Currently only on/off (together with couple other things) and also currently Im working on a way to change it. Actually Im going to make a whole kernel for it, which also will increase performance a lot.
Some GPIO pins are free to use on a PCB - just add a wire and we have PWM to drive the fan speed.
This will not only give less noise, but most importantly, more stable temperature.
The following users thanked this post: thm_w, Markus2801A
Offline voltsandjolts
« Reply #96 on: November 04, 2025, 07:46:54 pm »
You're probably aware already, but the DHO1000 series was reported to have pwm fan control. Just saying, in case you wanted to try similar here on MHO.
Just discovered that 'su' command works ... so its enough to type echo X> /sys/devices/platform/pwm_fan/hwmon/hwmon5/pwm1 , where X is a value from 0 to 255.
I expected this value to be changed by the system periodically but ... it does not seems the case  ???
I'm monitoring temps with PWM = 100, there is a small increase, the monitored ones are still under 50 °C with a room temp of 18 °C.
The following users thanked this post: norbert.kiszka
« Reply #97 on: November 04, 2025, 07:51:59 pm »
It should be easier to copy this part of the DT instead of making new entries. But I don't have MHO to test it - unless somebody will wan't to help with that (with testing).
Offline jayk
« Reply #98 on: November 04, 2025, 08:37:04 pm »
From a trusty source: Fudan actually got Xilinx's help when making these chip, Fudan now even has some RFSoC clone. And it's not made by TSMC!
My personal guess is: At first, Fudan was trying to reverse engineering Xilinx FPGA then sell it to defense related company in China, but the result wasn't ideal. At the same time, Xilinx also wants to sell FPGA to these companies, but due to obvious reason they can't sell it directly.
Then somehow Fudan convince Xilinx to help them build the clone chip, and now both Xilinx and Fudan make big buck of money out of this, it's basically a win-win deal from company standpoint. :popcorn:
Note: I don't want to involve politics in this topic
This is extraordinary if true.  Xilinx is one of the most important suppliers to US aero/defense industries.  Hard to believe they could get even tacit approval for something like this.
« Reply #99 on: November 04, 2025, 08:43:06 pm »
Rigol gives a sh*t to GPL software license conditions. So no surprise they did a copy of Xilinx FPGA.
