I bet that in the position with the "yellow-circumlined cap", an inrush-current limiting NTC was supposed to be installed. Since the OEM's ECAD probably doesn't provide a resistor in that form factor in the library, they just used a replacement from the caps library...
Did you measure the temperatures? How about the fan noise?
Quote from: Azusa on July 25, 2023, 07:06:02 amPlease, what are explanations about this "ultra" high noise what is visible in this image (nothing connected to inputs)
Sorry,I'm forgot to say,this noise is because i bypass the LC fliter to test maximum bandwidth and forgot to place it back.
Do you have a picture of playing Genshin on the scope?
and it even can split screen
Split screen mode...Wow.Just wow.
Quote from: Azusa on July 26, 2023, 11:48:52 amand it even can split screen How did you do that?Can you load Android APK files on it?Quote from: Martin72 on July 26, 2023, 01:56:53 pmSplit screen mode...Wow.Just wow.I declare the game officially changed again by Rigol.
If ADB works then the hackability of this is going to be huge.The other thing I was wondering is does it support a mouse as standard?
Quote from: Fungus on July 26, 2023, 07:18:28 pmThe other thing I was wondering is does it support a mouse as standard?Of course.
Thank you,hubert.My DHO804 is DHO924 now.Two extra drams are only for LA.It can be unpopulate if doesn't use the LA .The bandwidth is increased successfully.it has 800ps rise time now.And the memory depth is 50M now.
