Hi _Wim_,
Sorry for bothering you again, but it seems like I now have a weird issue with the software (haven't used it for a while). I now run Windows 11 and recently reinstalled FRA4PS v0.9.0, PicoSDK x64 v11.1.0.418 and ImpedanceViewer1014. Unfortunately, I now encounter an error while running the software when I click on the Measure > Picoscope button, which reads the following :
"An attempt was made to load a program with an incorrect format
HRESULT Exception : 0x8007000B"
If I click "ok", the setup window opens and I get a crash when starting measurement with the same erreor code and the following exception text. Any idea what I am doing wrong here, by any chance ? Should I raise an issue on Github instead ?
Thank you very much,
Best regards,
Rodolphe
************** Texte de l'exception **************
System.BadImageFormatException: Tentative de chargement d’un programme de format incorrect. (Exception de HRESULT : 0x8007000B)
à FRA_IMP.FRA4PicoscopeAPI.Initialize()
à FRA_IMP.FRA4Picoscope.ConnectPicoscope()
à FRA_IMP.FRA4Picoscope.CheckSettings()
à FRA_IMP.MeasurePicoscope.StartMeasurement()
à FRA_IMP.MeasurePicoscope.buttonStartMeasurement_Click(Object sender, EventArgs e)
à System.Windows.Forms.Control.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ButtonBase.WndProc(Message& m)
à System.Windows.Forms.Button.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
Version de l'assembly : 4.0.0.0
Version Win32 : 4.8.9300.0 built by: NET481REL1LAST_C
CodeBase : file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
FRA_IMP
Version de l'assembly : 1.0.0.14
Version Win32 : 1.0.0.14
CodeBase : file:///C:/Program%20Files/ImpedanceViewer1014/FRA_IMP.exe
WHConsult.Utils
Version de l'assembly : 1.0.0.0
Version Win32 : 1.0.0.0
CodeBase : file:///C:/Program%20Files/ImpedanceViewer1014/WHConsult.Utils.DLL
System
Version Win32 : 4.8.9282.0 built by: NET481REL1LAST_C
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Version Win32 : 4.8.9256.0 built by: NET481REL1LAST_B
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Version Win32 : 4.8.9032.0 built by: NET481REL1
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
log4net
Version de l'assembly : 1.2.11.0
Version Win32 : 1.2.11.0
CodeBase : file:///C:/Program%20Files/ImpedanceViewer1014/log4net.DLL
System.Configuration
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Version Win32 : 4.8.9297.0 built by: NET481REL1LAST_C
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Windows.Forms.DataVisualization
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Windows.Forms.DataVisualization.resources
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization.resources/v4.0_4.0.0.0_fr_31bf3856ad364e35/System.Windows.Forms.DataVisualization.resources.dll
System.Windows.Forms.resources
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
System.Data
Version Win32 : 4.8.9214.0 built by: NET481REL1LAST_B
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
mscorlib.resources
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
************** Débogage JIT **************
Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
application ou cet ordinateur (machine.config) doit avoir la valeur
jitDebugging définie dans la section system.windows.forms.
L'application doit également être compilée avec le débogage
activé.
Par exemple :
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
seront envoyées au débogueur JIT inscrit sur l'ordinateur
plutôt que d'être gérées par cette boîte de dialogue.
