In their
RTB2000 data sheet, R&S write that (emphases added):
Waveform and pattern generator: The integrated R&S RTB-B6 waveform and pattern generator (up to 50 Mbit/s) is useful for educational purposes and for implementing prototype hardware. Apart from the common sine, square/pulse, ramp and noise waveforms, it outputs arbitrary waveforms and 4-bit signal patterns. Waveforms and patterns can be imported as CSV files or copied from oscilloscope waveforms. Before playing signals back, the user can preview them to quickly check signal correctness. Predefined patterns for e.g. I2C, SPI, UART and CAN/LIN can be used.
The R&S
RTx-B6 option data sheet, for the RTB2000, RTM3000 and RTA4000 oscilloscopes, says on its first page (emphases added):
4 bit pattern generator with predefined patterns: Waveforms and patterns can be imported as CSV files or copied from oscilloscope waveforms. Before playing signals back, the user can preview them to quickly check signal correctness. Predefined patterns for e.g. I2C, SPI, UART and CAN/LIN can be used.
But I cannot find no way to import 4-bit patterns in CSV format into my RTB2004 (firmware 2.300) with option RTB-B6 installed. Cannot find this in the manual either.
Has anyone been able to do so successfully? And willing to share how it is done?
Thanks!
