Well, now I'm not so sure about temps. Here's a look at temps with the scope just at idle, one trace on the screen. I can feel the difference in case temp with my hands, the left side feels much cooler than the right side. Not sure if that's normal? Screenshot of temps attached. The ADCs seem a little on the high side. My lab/room is probably around 74F.
I took a look at RW Everything and I honestly have no idea what I'm looking at I mean I get it's reading memory space and register, but I didn't see anything specifically calling out hw errors.
I've got prime95 running now while I monitor the motherboard temps with HWInfo. CPU temps look pretty good so far though, hovering around 42-43.
Hoping to have some time over Thanksgiving weekend to take things apart and look at power. Thanks again for the help so far!
Edit: Here's the latest selftest log
22.11.2025 01:57:22
DAB
Step 1 of 1 : Passed.
RTC 0 DAB_EYE: 14
RTC 1 DAB_EYE: 20
DAF
RTC 0 DAF_EYE_CLK: 12
RTC 0 DAF_EYE_DATA: 9
RTC 1 DAF_EYE_CLK: 13
RTC 1 DAF_EYE_DATA: 10
TrgBus
RTC 0 TIF_EYE_CLK: 10
RTC 0 TIF_EYE_DATA: 11
RTC 1 TIF_EYE_CLK: 12
RTC 1 TIF_EYE_DATA: 11
TrgRtc
RTC2 TRG_RTC_PRN_CLK :11
RTC2 TRG_RTC_PRN_DATA :10
RTC1 TRG_RTC_PRN_CLK :10
RTC1 TRG_RTC_PRN_DATA :9
FecBus
RTC_SDRAM
RTC 1 RAM_DATA_WALKING_ONE_TEST: 0 ERRORS
RTC 1 RAM_DATA_WALKING_ZERO_TEST: 0 ERRORS
RTC 1 SDRAM_ADR_TEST: 0 ERRORS
RTC 1 SDRAM_RANDOM_PATTERN_TEST: 0 ERRORS
RTC 2 RAM_DATA_WALKING_ONE_TEST: 0 ERRORS
RTC 2 RAM_DATA_WALKING_ZERO_TEST: 0 ERRORS
RTC 2 SDRAM_ADR_TEST: 0 ERRORS
RTC 2 SDRAM_RANDOM_PATTERN_TEST: 0 ERRORS
RTC MCO-RAM
Spike test based on mask test with 0 Divs offset
Test passed, No Spikes found in mask test of any channel
Spike test based on measurements with 0 Div position
Channel: 1 Measured: 0.00592885 Volt, max.limit: 0.05 Volt
Channel: 2 Measured: 0.00790514 Volt, max.limit: 0.05 Volt
Channel: 3 Measured: 0.00790514 Volt, max.limit: 0.05 Volt
Channel: 4 Measured: 0.00790514 Volt, max.limit: 0.05 Volt
Spike test based on measurements with 4 Div position
Channel: 1Measured: 0.00013834 Volt, max.limit: 0.001 Volt
Channel: 2Measured: 0.000167984 Volt, max.limit: 0.001 Volt
Channel: 3Measured: 0.000123518 Volt, max.limit: 0.001 Volt
Channel: 4Measured: 0.000167984 Volt, max.limit: 0.001 Volt
Spike test based on measurements with 5 Div position (overflow)
SPI Channel: 1
Cal Relay Channel: 1
DC 1 MOhm difference = 1.17963%
DC 1 MOhm min/max detector difference = 1.14286%
DC 50 Ohm difference = 0.35767%
DC 50 Ohm min/max detector difference = 0%
AC difference = 0.287055%
AC min/max detector difference = 0%
SPI Channel: 2
Cal Relay Channel: 2
DC 1 MOhm difference = 1.18231%
DC 1 MOhm min/max detector difference = 1.68539%
DC 50 Ohm difference = 0.721127%
AC difference = 0.0360921%
AC min/max detector difference = 0.568182%
SPI Channel: 3
Cal Relay Channel: 3
DC 1 MOhm difference = 1.06195%
DC 50 Ohm difference = 0.486977%
AC difference = 0.0228102%
AC min/max detector difference = 0.578035%
SPI Channel: 4
Cal Relay Channel: 4
DC 1 MOhm difference = 0.732534%
DC 1 MOhm min/max detector difference = 0.574713%
DC 50 Ohm difference = 0.288921%
AC difference = 0.269875%
