Author Topic: Rotten DS-1052E LCD Screen  (Read 1600 times)
Offline erperezTopic starter
  • Country: pr
« on: May 21, 2019, 11:40:58 pm »
Hello all,
I was wondering if someone knows of a replacement for the LCD on a Rigol DS1052E that has served me well over the years.
It was on storage for a few months and when it came out the screen was rotten, like the sandwiched lcd layers peeled on the inside.
ill post pictures later of the issue.
suggestions?
thanks
EP
Offline stj
Re: Rotten DS-1052E LCD Screen
« Reply #1 on: May 22, 2019, 12:08:15 am »
i have seen tv's with "stuff" between the defuser layers,
you can usually clean them if you have the patience.
Offline YetAnotherTechie
  • Country: pt
« Reply #2 on: May 22, 2019, 11:11:00 am »
For some reason this is common on large TV´s. Carefully remove the damaged one, buy polarizing film from your favourite online Asian supplier and stick it to the cleaned panel.
