Author Topic: R&S Codenames  (Read 2844 times)
Offline jjoonathanTopic starter
R&S Codenames
« on: August 30, 2019, 07:28:26 pm »
I was poking around some of the XML files on my Rohde & Schwarz RTO oscilloscope and I found a list of frontend components / attributes with some interesting entries.
Does anyone know what Kuma, Ooma, and Majuro are? Codenames for ASICs? German words that Google Translate doesn't want to tell me about?
      <Hardware partNumber="1304.6160.24" sn="------" partChangeIndex="07.08" name="FE" partName="Frontend" externConnected="false">
        <ProgrammableParts>
          <ProgrammablePart name="FEC" version="16.0.16.0"/>
        </ProgrammableParts>
        <Properties>
          <Property name="Kuma version" value="3"/>
          <Property name="Majuro version" value="2"/>
          <Property name="USB vendor ID" value="1060"/>
          <Property name="USB product ID" value="9495"/>
          <Property name="USB device ID" value="2"/>
          <Property name="ADC count" value="4"/>
          <Property name="ADC 1 temp offset" value="-41"/>
          <Property name="ADC 1 temp shutdown" value="120"/>
          <Property name="ADC 1 temp warning" value="110"/>
          <Property name="Buffer 1 temp offset" value="-36"/>
          <Property name="Buffer 1 temp shutdown" value="110"/>
          <Property name="Buffer 1 temp warning" value="100"/>
          <Property name="Ooma 1 version" value="32"/>
          <Property name="ADC 2 temp offset" value="-41"/>
          <Property name="ADC 2 temp shutdown" value="120"/>
          <Property name="ADC 2 temp warning" value="110"/>
          <Property name="Buffer 2 temp offset" value="-36"/>
          <Property name="Buffer 2 temp shutdown" value="110"/>
          <Property name="Buffer 2 temp warning" value="100"/>
          <Property name="Ooma 2 version" value="32"/>
          <Property name="ADC 3 temp offset" value="-41"/>
          <Property name="ADC 3 temp shutdown" value="120"/>
          <Property name="ADC 3 temp warning" value="110"/>
          <Property name="Buffer 3 temp offset" value="-36"/>
          <Property name="Buffer 3 temp shutdown" value="110"/>
          <Property name="Buffer 3 temp warning" value="100"/>
          <Property name="Ooma 3 version" value="32"/>
          <Property name="ADC 4 temp offset" value="-41"/>
          <Property name="ADC 4 temp shutdown" value="120"/>
          <Property name="ADC 4 temp warning" value="110"/>
          <Property name="Buffer 4 temp offset" value="-36"/>
          <Property name="Buffer 4 temp shutdown" value="110"/>
          <Property name="Buffer 4 temp warning" value="100"/>
          <Property name="Ooma 4 version" value="32"/>
        </Properties>
      </Hardware>
Offline nctnico
Re: R&S Codenames
« Reply #1 on: August 30, 2019, 07:59:56 pm »
It could be ASIC or FPGA design names. The Commodore Amiga also had these funny names for the ASICs. Though that was in the era when computers came with complete schematics in the manual.
Re: R&S Codenames
« Reply #2 on: September 09, 2019, 08:17:24 pm »
Yep, sure enough, OOMA was the ADC:
Any leads on Kuma or Majuro?
Offline TRN
  • Country: pt
Re: R&S Codenames
« Reply #3 on: February 08, 2021, 12:05:05 pm »
Majuro2 is a Variable Gain Amplifier (VGA), and is used in the analog front-end of the RTM2000 oscilloscopes
The following users thanked this post: jjoonathan
Offline ElectronMan
Re: R&S Codenames
« Reply #4 on: February 08, 2021, 04:00:43 pm »
        <ProgrammableParts>
        <Properties>
        </Properties>
      </Hardware>
From what I can tell by looking at firmware it looks like Majuro and Kuma are different "Front End Controllers." They could be sub-components of the controller too, but I see them being associated with the Front End Controlller.
Re: R&S Codenames
« Reply #5 on: February 08, 2021, 05:28:38 pm »
That could be. The RTO1024 VGA is on a hybrid labeled "ONOTOA v3.0" but that might refer to the hybrid itself.
Offline a1564980754
  • Country: fo
Re: R&S Codenames
« Reply #6 on: September 07, 2026, 02:10:06 pm »
Help, how can I solve this problem?
