Author Topic: R&S MXO3/04/05 - Reviews, Bugs & Wanted Features/Improvements Thread  (Read 28548 times)
Offline LoTech
Re: R&S MXO3/04/05 - Reviews, Bugs & Wanted Features/Improvements Thread
« Reply #275 on: July 01, 2026, 09:05:29 pm »
Great and how do I get to the new firmware?
For the past couple of years R&S support is going in the wrong direction. I have a bench full of R & S equipment and my life is miserable every time I need to download anything from them.
« Last Edit: July 01, 2026, 09:07:37 pm by LoTech »
The following users thanked this post: egonotto, Elio
Offline n55_6mt
« Reply #276 on: July 02, 2026, 02:41:06 am »
Managed to get my hands of a copy of the 2.10.2.0 firmware from another forum member. I've only encountered responsiveness issues with the horizontal encoder a handful of times but it's promising that in the release notes, this time they say that they've solved the issue rather than just improved responsiveness. I'm curious about impedance analysis although it looks like it will be a paid option.
Unfortunately, the reference waveform update rate issue still seems to be present, maybe this will get fixed on the next update.
Overall, there's a number of nice features added, histograms on measurements are an especially cool feature.
2851940-0
The following users thanked this post: pdenisowski
Offline LoTech
« Reply #277 on: July 02, 2026, 04:20:46 am »
can you help a brother out or is it asking for that frown upon?
« Last Edit: July 02, 2026, 07:53:10 am by LoTech »
Offline LoTech
« Reply #278 on: July 02, 2026, 03:33:59 pm »
Does anyone know if K31 (power analyses) is included in the PK1 for MXO4?
Website info does not mention is included but IIRC from my RTM scope, the K31 was released later with a FW update
Offline rusoaie
  • Curious how stuff works, but skeptic on datasheets
« Reply #279 on: July 02, 2026, 03:49:12 pm »
yes, it is:
R&S®MXO4-PK1 - Application bundle, consists of the following options: R&S®MXO4-B6, R&S®MXO4-K31, R&S®MXO4-K36, R&S®MXO4-K510, R&S®MXO4-K520
Source: MXO 4 Series Oscilloscope - Specifications, version 20, May 2026, page 41
« Last Edit: July 02, 2026, 04:01:58 pm by rusoaie »
The following users thanked this post: LoTech
Offline Martin72Topic starter
« Reply #280 on: July 02, 2026, 04:14:39 pm »
Hm?  ;)
Online KungFuJosh
  • TEAS is real.
Best Continuity Tester Ever
The following users thanked this post: egonotto, Martin72
Offline LoTech
« Reply #282 on: July 02, 2026, 11:50:42 pm »
All right, FW updated for the MX04. BIG THANKS to the awesome members here.
The scope is now updated to latest FW, but bare bonez...I am waiting for a few options to come in and in the meantime I poked around the MXO4 demos and noted the band-pass filter demo, which I think it is a pretty awesome feature. The band-pass setting points to a "user defined filer file" but it is part of the demo "user defined filter".
Has anyone here experienced with this option? What is the header and what prereqs must be present when building a custom user file, for the scope to read it. I would obviously want to change the band-pass freq as need...Ideally I can find a way to the demo file, make a copy and use the copy as the woriking copy that can be modified as needed.
Thoughts or directional guidance? If there is a thread already out there discussing this, please point me in that direction.
« Last Edit: July 03, 2026, 01:31:43 am by LoTech »
Offline santiall
  • Country: hk
« Reply #283 on: July 03, 2026, 03:20:01 am »
I was starting playing with that at some point but I never finished playing with it . You need to create a csv with the filter coefficients, the impulse response, which you have to do by yourself (user manual suggests Matlab or you write your own program).
The main 'trick' is that the filter sampling frequency needs to match the oscilloscope sample rate:
Bandpass and bandstop FIR filter with CSV file
To define a bandpass or bandstop, you need a CSV file that contains the comma-separated filter coefficients in one row. The maximum number of filter coefficients is 100 000 taps. No other parameters are allowed in the file.
To create the CSV file, we recommend using the MATLAB Filter Design & Analysis tool. In the tool, enter the filter type, filter order and filter frequencies. Alternatively, you can create the filter and the CSV file with Python.
Make sure to set the sample frequency in MATLAB or Python and the sample rate at the oscilloscope to the same value. If the values differ, the filter is shifted in frequency.
On the MXO 4, select "Menu" > "Math" > "Setup" > "Filter", the filter "Type" = "User defined", and load the CSV file.
Offline tooki
« Reply #284 on: July 03, 2026, 02:48:09 pm »
It depends on when you bought the bundle. If you bought the bundle before K31 was released, you don’t get it for free retroactively.  >:(
Offline n55_6mt
« Reply #285 on: July 03, 2026, 06:47:27 pm »
Yeah that's unfortunately another one of the things R&S does with how they manage licenses. The PK1 and other bulk licenses are really just discount codes for all of the individual entitlements, it's not a license in of itself. If they add or remove things from the bundle in the future, you'll still have the same entitlements.
I can't blame R&S too much for this as it's pretty much in alignment with how the other big players operate these days when it comes to software and option unlocks.
Online 2N3055
  • Country: hr
« Reply #286 on: July 03, 2026, 07:01:20 pm »
Of course you can blame them. They do not need to a**holes like the rest of them. It is a deliberate choice..
Dr. Richard W. Hamming
Offline LoTech
« Reply #287 on: July 04, 2026, 06:23:10 am »
I thought of grabbing only a couple of options (B6 and K36) and the K31 at a later time, but I might end up with PK1 ...and a big hole in the wallet.
Offline chilternview
Re: R&S MXO3 - A short Review
« Reply #288 on: July 24, 2026, 11:45:39 am »
One annoying thing - maybe a bug? - with the MXO3 and logic probes is that if probes are already attached to the powered down scope, and the scope powered up, the 'Logic' entries are all greyed out. You have to unplug, and replug in the probe connector with the scope, which then initiates an alignment, and the probes are then recognised.
I had hoped that this would be fixed in 2.10.2.0 but no, you still have to plug in the digital probe connectors *after* powering up the scope.
The scope remembers what analog probes are connected after power down/up, why not the digital? I raised a ticket and they seem to think this is an enhancement request; it's not, it's a bug.
If it ain't broke, don't fix it!
Offline Bernd_2
« Reply #289 on: September 19, 2026, 10:24:13 am »
Hello,
I've also been thinking for a long time about how to generate a coefficient file for bandpass and bandstop filters. I don't have MATLAB, and it's too complicated for me anyway.
But I've now found a way to create working CSV files for such filters using just a few lines of Python code.
I tested this with the MXO5, and to keep this thread from dying out completely, I'm posting the results in the MXO5 thread.
https://www.eevblog.com/forum/testgear/rs-to-launch-mxo5/msg6362062/#msg6362062
Best Regards,
Bernd
The following users thanked this post: egonotto, pdenisowski, Martin72
Online jjoonathan
« Reply #290 on: September 20, 2026, 02:33:52 am »
Scipy is great, but if you have python and want to manually design filters, pyfda is brilliant. It's "matlab fdatool, but for python, and also better."
https://github.com/chipmuenk/pyFDA/
The following users thanked this post: nctnico, Bernd_2
Offline Bernd_2
« Reply #291 on: September 20, 2026, 10:20:56 am »
Hi  jjoonathan,
Thank you very much for the tip and the link to pyfda. That looks very promising and powerful.
The GitHub page also includes a link to a live web app (borish127) that works without a local installation.
Unfortunately, however, when exporting in CSV format, the following error message appears:
Export failed: TypeError: unsupported format string passed to nympy.ndarray._format_
It seems the only option is to install it locally after all. Have you perhaps tried using it to export a filter in CSV format?
Best Regards,
Bernd
« Last Edit: September 20, 2026, 10:23:26 am by Bernd_2 »
Online jjoonathan
« Reply #292 on: September 20, 2026, 04:54:31 pm »
It's in the python package index so if you have uv installed (yeah, python has another package manager, but this one is pretty good -- "npm for python") you can run it with a single line anywhere:
uv tool run --from pyfda pyfdax
I just tried exporting a CSV and it appears to work, so my guess is a version mismatch in the webapp is causing the problem you see.
« Last Edit: September 20, 2026, 04:56:27 pm by jjoonathan »
