Hi!
I recently purchased s Schumberger/Enertec 5027 Oscilloscope, it's a 4 channel instrument that seems to be derived from the 5218/5224 series which uses Seven Segment displays to display voltage/time coefficients and other functions, rather than use a marked front panel.
I was going to pass it on because of the gaping hole where the "Synchronization" control was, but the seller said he had the missing knob for it, so decided to take the plunge!
Do any of our International friends recognise the Enertec 5027 and is there known to be any bookwork/manuals for it anywhere?
I can draw out circuits and layouts, but trying to write the adjustment procedures is next to impossible unless there's a similar model I can use as a guide!
Chris Williams
