Author Topic: SDG2122X only 1 Mhz with triangular wave ?  (Read 3536 times)
Offline ebclrTopic starter
« on: April 30, 2017, 07:38:13 am »
With sinewave everything just nice at 120 Mhz.
But the maximum frequency that I can get with a triangular wave is 1 MHZ, Is that correct?
Offline WackyGerman
Re: SDG2122X only 1 Mhz with triangular wave ?
« Reply #1 on: April 30, 2017, 07:55:04 am »
Yes , just look at the datasheet  ;)
« Reply #2 on: April 30, 2017, 08:52:17 am »
Arb max is listed as 6 MHz so you might be able to get that via some trickery.
IIRC rf-loop could coax 50 MHz out of an SDG1000 unit with the SCPI command set.
Avid Rabid Hobbyist
Offline WackyGerman
« Reply #3 on: April 30, 2017, 09:07:33 am »
You re right tautech . Didn t thought for the trick . Checked it with my SDG 1010 . Generated an Arb - wave with Easy Wave and sent it to my generator . Works really well and I was able to raise the frequency to 5 Mhz .  :-+
« Reply #4 on: April 30, 2017, 10:36:09 am »
Why they make this?
Apparently no reason to limit to 1Mhz
Offline Kleinstein
« Reply #5 on: April 30, 2017, 10:55:52 am »
With the waveform generation via memory and DAC, it is normal to have a considerable lower limit for the triangle waveform. The sine waveform using DDS can go up to the point of about 2.5 to 3 sampling point per period - this is because the reconstruction filter can be really good in restoring a sine from those few points. However this does not work that well with a triangle or arb waveform. So at higher frequencies the waveform gets more or less distorted. Here the limit is slightly arbitrary, as it is a slowly starting decline of quality when the frequency is increased to much. For a triangle something like 100-150 sampling point might be a reasonable limit - so maybe 1/50 of the maximum sine frequency.
With the arb waveform there might be a chance to use a little of "pre distortion" to compensate for the onset of the filter. So using the arb way might be able to get a slightly high frequency triangle (at the cost of processing needed) and maybe less fine frequency steps. For the 5 MHz shown one can already see an not so ideal shape.
Offline WackyGerman
« Reply #6 on: May 02, 2017, 07:20:37 pm »
Didn t do the job really well when I measured the triangle wave . Used a 1m cheap bnc cable and didn t set the generator and the oscilloscope to 50 Ohms . Now the triangle wave looks better . Still not perfect , it s a little distorted  :)
Offline DaJMasta
    • medpants.com
« Reply #7 on: May 02, 2017, 09:43:31 pm »
You can get something close to a triangle wave up to about 15MHz on my SDG2082X, generate a sine wave, turn on harmonics, set about:
5%Vpp amplitude second harmonic with 270 degree phase
10%Vpp third harmonic with 180 degree phase
2.5%Vpp fifth harmonic
You really need the 5th harmonic for it to look right, so with your 120MHz sine bandwidth, your cutoff for this approximation would be 24MHz.  I guess in theory I should be able to get a 16MHz one out of mine.
With a little tweaking it could probably look nicer, but aside from a tiny bit of wobble in the ramp and a rounded peak, it's serviceable.
« Last Edit: May 02, 2017, 09:45:03 pm by DaJMasta »
Offline mmagin
« Reply #8 on: May 02, 2017, 11:47:48 pm »
This is not unusual among cheap function generators.  If I recall correctly, even some of the lower-end old ones from HP (30-35 years ago) had such a limitation.
Offline Kleinstein
« Reply #9 on: May 03, 2017, 01:45:44 pm »
The old, analog (and maybe with PLL stabilization) generators also might have a lower limit for the triangle. But this is due to the output amplifier, so maybe at 1/5 - 1/10 the sine frequency. The DDS based generators usually have a lower limit at maybe 1/20 - 1/50 the maximum sine frequency.
« Reply #10 on: May 03, 2017, 03:34:07 pm »
We are talking about 1/120 here
