This whole "BUG!!" is between chair and oscilloscope. Please repair this thread title. Please first try to learn basic fundamentals and after real knowledge and experience start naming things as "bugs".
Here you can of course ask how to use oscilloscope. But please, before it, try to even read the user manual first, even though it's boring.
What an amazing A-#ole! First, I don't think you have any idea what I'm talking about. Next, unless you have something constructive to add .. STFU!
I have read the manual. Have you? As bdunham7 mentions, it's found in the 2nd page of the channel menu and it is not even mentioned in the manual.
The "bug" might simply be the fact that they have two controls that do the same thing but are labeled differently. Or it's not meant to exist. That's fine. Fix the "bug" by calling them both "position" or both "offset" or just removing it. However, not being a Finnish twat, where I come from the words "position" and "offset" mean different things, especially in context of each other.
The title stays the same. Now, vittuun!
Well, frankly, you have colorful personality yourself...
So let us all calm down and let's figure this out..
Position and offset are actually interchangeable in this context for reasons to be discussed. And it is why I asked what do you mean by this two terms. And I didn't mean by it to be explained as to what is meaning of these two english words (know that, thank you anyways) but as to what meaning you ascribe to them in context of the scope...
I don't have SDS1000X-E so I didn't know about this distinction. Touch screen scopes from them don't have it. And I agree with RF, it is not a bug. It might be confusing design choice or misnomer but not a bug.
What I presume it has it because offset/position in DC and AC mode will differ. Maybe they wanted to have separate control for the two.
Experiment: apply 25% duty cycle 0 to 1V squarewave to scope input.
Put it in DC mode. What you see?
Center it on the screen with vertical position knob (physical one on the channel).
Change channel to AC mode. What do you see?
Now try moving it up and down with vertical position knob (physical one on the channel).
Go out in DC mode? What you see?
Center it again.
Go back in AC mode.
Now try moving it up and down with offset function ( one in the menu ).
Do you see any difference in behaviour now?
Would you be so kind and try this? I am also curious what would the results be.
Best,
