PS: I imagine the first thing most customers do is press "auto-cal", thus invalidating the certificate.
Do you even really know how that works ?
Or Quick Cal for that matter ?
Are Siglents so magical that a user can't mess them up by pressing "auto-cal"?
(eg. before it warms up properly)
If you selfcal while internal temp is still low, you can always restart selfcal.
User can also permanently decalibrate it by using hammer.
I was pointing out the idiocy of lawyer talk in Keysight documents.
There is a factory calibration/adjustment that defines real accuracy of the instrument.
And self cal that is equivalent to bench multi-meter Autocal (that high precision meters have).
Somehow in bench meters it is auto cal is improving specification, and on the scopes it invalidates traceability..
There is a complete lunacy surrounding this topic, completely confusing bureaucracy of traceability with accuracy of instrument measurements.
Perhaps even more...
Whole NIST traceable cal have many problems.
One of simplest is something like this mechanism is build in this whole mess.
Take example. I have some lab what make tests and all need do with NIST traceable instruments with valid certificate. Lab room temp is also measured with certified meter so that it is inside valid range. Think certificates valid period is 1 year. After instrument come from cal lab we continue measurements and write documents and every document have also info about instruments calibration cert.
Year go and lot of things have done.
Instrument go again to cal lab for certificate.
In this process find it is off and can not write certificate, first need repair/adjust etc.
But there is not any knowledge when this fault happen, if it happen just after last cal check or drifted until some day gone out of limits.
There is lot of test reports around of world done with this instrument or it is part of test setup.
Do you call back all test results made after last cal certificate because you do not know when it have failed. It can be failed whole year and all measurements can be just garbage.
This is one small hole in this whole cal mess.
