I have seen may bench power supply help threads but only for standard ranges.
Currently I have a Tenma 72-6905 it isn't great but good enough.
I pre-regulate anything important.
So you don't have to look it up it is. 8-15 1A, 2.2-5.2 1A, +-0-30 0-3A all isolated.
I like it because it has series, parallel and isolated switchs.
What I am missing is something that can give me 150v .5A.
My actual requirements are 140v but I like to leave headroom for pre-regulation when required.
I can make over 150v by chaining almost all my power supplies but i'd rather not.
Ideally I something like think a +-75v 0-1A would be my most adaptable solution.
Other selling points Compact (small bench) and 115 60Hz (Canada)
Here is the problem I have slogged through hundreds of power supply specs looking for my best option.
I have found that most sites do not advertise the voltages and I end up at the standard 0-30v supplies.
For this reason the only supply I any real info in is a B&K power supply for $800ish.
I am thinking there must be other viable options out there, for under $500.
Before I give up and make one I want to ask everyone if they know of any other options for me to look at.
