Author Topic: Self made test cables for VNA......  (Read 4556 times)
Offline SquarewaveTopic starter
« on: June 17, 2026, 03:29:08 pm »
Hello, I'm wondering if someone can suggest a better cable for my test leads for use with a VNA and SA.
I've been using some I made with RG58, which appear to be ok, but RG58 isn't really the best quality. I have more cables I'd like to make, so was thinking of something like LMR195, probably would need the 195 ultra flex. What have you guys used?
Thanks.
Online KungFuJosh
  • TEAS is real.
Re: Self made test cables for VNA......
« Reply #1 on: June 17, 2026, 03:52:54 pm »
This is a giant, and potentially very expensive, can of worms.
What frequency range are you looking for?
Also, check out this related thread: https://www.eevblog.com/forum/testgear/cables-connectors-(nsmabnc)-adapters-with-measured-results-for-comparisons/
« Last Edit: June 17, 2026, 03:54:52 pm by KungFuJosh »
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
The following users thanked this post: pdenisowski
« Reply #2 on: June 17, 2026, 03:58:11 pm »
So I realise any losses are calibrated out, but I'm generally using half a metre to 1 metre max. I used crimp/solder SMA plugs. I usually only go up to 500mhz, I've no work in the Ghz range, but perhaps I should consider the VNA does go up to 1.3Ghz.
I'll have a read of that thread, thanks.
Online KungFuJosh
  • TEAS is real.
« Reply #3 on: June 17, 2026, 04:07:23 pm »
In that frequency range, the M&P cables are good. Gore cables are better. But it really depends on what you want to budget. It's easy to spend a ton of $$$.
Offline Rubo
« Reply #4 on: June 17, 2026, 04:30:45 pm »
I would (and am) using RG400 cables for anything that I make myself for the lab. You can use connectors for RG58 (it's a close enough fit).
They are on the stiffer side, but have a much better shielding & PIM compared to any of the LMR stuff.
Online mawyatt
« Reply #5 on: June 17, 2026, 04:34:37 pm »
Get double shielded cables for more precise work.
Best
~Wyatt Labs by Mike~
« Reply #6 on: June 17, 2026, 08:09:03 pm »
Have you got a link to M&P? I was able to find Gore.
Online KungFuJosh
  • TEAS is real.
« Reply #7 on: June 17, 2026, 08:13:18 pm »
here ya go: https://messi.it/en/catalogue/50-ohm-rf-coaxial-cable/n-male-connectors/hyperflex5/solder.htm
HF5 should be fine in the frequencies you're using, but going up to 7 or 10 gets better performance. I've shown them, and Gore, in the other thread.
« Reply #8 on: June 17, 2026, 08:54:00 pm »
Ah yes Messi & Paoloni, I use their UF7 for my HF antenna and patch leads. You know what, I never considered looking at them for 5mm cable (5mm max really for bench top test work), so thanks for the heads up. M&P cables often have better characteristics than the likes of LMR.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #9 on: June 17, 2026, 11:12:45 pm »
One thing to keep in mind about VNA cables is that while you can cal out many cable imperfections, you can't "cal out" a cable that is not phase or temperature stable.  In particular, phase stability (during flexure) is one of the things that you're paying for when you spend $$$ on VNA cables.
Or, you could buy a big roll of tape and secure the cable to the bench that way  :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: Smokey, Squarewave, KungFuJosh
Online KungFuJosh
  • TEAS is real.
« Reply #10 on: June 17, 2026, 11:30:22 pm »
Yup. This is where the Gore cables excelled compared to all the others I've tried.
Offline Rubo
« Reply #11 on: June 18, 2026, 05:06:45 am »
Agreed. And that's why I keep cheking eBay and keep spending money on Gore  :palm:
The following users thanked this post: jjoonathan, Squarewave, TylerPeppy
Offline knudch
« Reply #12 on: June 18, 2026, 06:48:47 am »
I can not recommend HF5  (Hyperflex 5)
Loses are ok even at 1,3Ghz (which does not matter much for VNA use)
But the SRL / (Structual return Loss) is not meeting its specification 0,3-600MHz > 28 dB
I measure more something like 20-23dB (different lengths 2m - 6m)
Hyperflex 10 meets its specifications of 0,3-600MHz >30dB
Hyperflex 5 seems also sensitive to bending/flexing and don't be "hard" to it, it deforms easily.
HF10 seems also significant better in this respect but is a little un-handy for lab use.
I got some 0,5m cables made of RG142-PUR (5mm diameter) they are very good in respect til bending/flexing
But it is not widely available.
Knud
Online tszaboo
« Reply #13 on: June 18, 2026, 11:25:49 am »
For GHz VNA measurements, I use RG402, sometimes it's called SS402. It also what comes with the LiteVNA for example.
It's semi-rigid, so it's not the easiest to work with, and you can absolutely damage it if you bend it the wrong way.
But it's reliable, low loss, and you can solder the connector or the cable yourself. Meaning that it doesn't require expensive blanking/crimping tools.
And you can buy pre-made cables, with high quality stainless connectors, that cost like 1/20th of the price of the typical name brand VNA cable.
Online KungFuJosh
  • TEAS is real.
« Reply #14 on: June 18, 2026, 03:49:30 pm »
Knud
There's no question that HF5 is not as good as its older siblings, but if it's made well enough, it should meet its specs. Here's one I made:
...and I'm not claiming I did a very good job making it. ;)
It is more sensitive to bends, especially if the connector installation quality is questionable...which I found out when I made questionable connections at the ends.  :-DD
Thanks,
Josh
Offline knudch
« Reply #15 on: June 18, 2026, 04:43:08 pm »
Interesting :)
This one is 2m long with special N-connector for that cable type, crimped.
CAL-set is Siglent F503
Have another 2m piece ..look the same, also a 6m piece..same.
cables are approx 3 years old and has not been subject to violence.
Knud
Offline knudch
« Reply #16 on: June 18, 2026, 04:50:15 pm »
This is a RG400 from ROSNOL 1m N-connector crimped.
Teflon, double shielded, inner and shield is steel/copper silverplated.
Much better and ruggedized
Knud
Online KungFuJosh
  • TEAS is real.
« Reply #17 on: June 18, 2026, 05:36:27 pm »
Interesting :)
Knud
Hyperflex 5 doesn't have an official N crimp connector. That's what I like the least about it. ;)
My cable is with their connectors: https://messi.it/en/catalogue/50-ohm-rf-coaxial-cable/n-male-connectors/hyperflex5/solder.htm
Offline knudch
« Reply #18 on: June 18, 2026, 06:37:10 pm »
Other manufacturers make the same cable and connectors.
Soldering the center pin in a 5mm cable with foam isolation, is risky...very little heat melt the foam and offset the center conductor.
Crimping is always preferable unless we talk about teflon cables.
Maybe there is fluctuating quality...seen before amongst some European cable manufacturers in there competition for lowest attenuation.
They use low density foam (you can read that from the velocity of the cable, HY5 is 87%), low density makes it vulnerable to handling both in production and user handling.
Of course that gives lower looses.
Knud
Online KungFuJosh
  • TEAS is real.
« Reply #19 on: June 18, 2026, 07:00:07 pm »
What connectors fit it? HF5 is 5.4mm. I've not found anything that fits it.
Risky maybe, but it worked better than those 3rd party crimp connectors. ;) Joking aside, it's a fast solder. It might take some practice, but really not bad.
Offline knudch
« Reply #20 on: June 18, 2026, 07:52:27 pm »
Ecoflex 5 from SSB electronic (Germany)
Belden H155 (Dutch)
LMR240 will also go in this category, maybe with a different outer ferrule
Connectors which fits these cables will also fits HY5
Same design multi core inner conductor, braid + foil shield, foam dielectric
It is jungle to navigate in which connector and crimp tool goes with which connector.
Some times is the connector housing the same but different center pin and different outer ferrule.
Luckily I have a supplier close to me which has a great variety of parts/cables and knowlegde in this area.
But it is interesting that you have clearly better results from  HY5 than I have
I could be tempted to order a few meters and connectors...not very expensive here..out of curiosity
Knud
Online KungFuJosh
  • TEAS is real.
« Reply #21 on: June 18, 2026, 07:58:24 pm »
That's funny. Despite my better results, I still want to try the crimp connectors. 🤦‍♂️
Offline knudch
« Reply #22 on: June 18, 2026, 08:20:33 pm »
The connectors is definitely not the difference over a such wide frequency range.
The cable is the guilty :)
So be happy that the HY5 works you ;)
May I got the last meters they produced before the weekend ;)
But in the low price segment the competition is hard....focus on low attenuation is a highlight "mine is faster than yours"
For VNA use this is secondary
Knud
« Last Edit: June 18, 2026, 08:27:33 pm by knudch »
Online KungFuJosh
  • TEAS is real.
« Reply #23 on: June 18, 2026, 08:54:11 pm »
I disagree. I did a terrible job originally with the connectors, and didn't get those results until replacing them. ;)
The cable meets spec for me, and not for you. If it was the cable, it would not meet spec for either of us.
Offline knudch
« Reply #24 on: June 18, 2026, 09:27:22 pm »
I fully understand your deduction ;)
You made crappy connection got poor results, change to good connections get good results
Vice versa I get poor results...I must have made crappy connections ;)
What are against that conclusion:
I made 6 identical bad connections ....I am very good ;)
I have seen more poor cables than poor connections ;)
All my other crimped connections (close to 100) are ok
I believe it is more likely that I have got a length of "monday" cable
Knud
