Author Topic: Serial to usb on Kunkin KP184 electronic load  (Read 114500 times)
0 Members and 22 Guests are viewing this topic.
Offline interflexo
  • Country: pt
Re: Serial to usb on Kunkin KP184 electronic load
« Reply #150 on: July 05, 2021, 09:51:00 am »
New KP184 Software Version 1.0.26.0:
Changes:
1. Several Python modules were updated.
Setup KP184 Software V1.1.07.0
« Last Edit: August 10, 2026, 04:14:00 pm by interflexo »
The following users thanked this post: CyberWalker, adso85swe
Offline MeterReader
« Reply #151 on: August 25, 2021, 06:32:32 pm »
I appreciate the seemingly straight-forward interface. Unfortunately, I can't get it working with my KP184 V4. Tried the version you just linked, one from your very short youtube video, and another from somewhere else. I do have it successfully working with another load controller. I'm using a CH340-based USB to serial adapter.
Got it going after a restart!
« Last Edit: August 27, 2021, 04:04:38 am by MeterReader »
Offline cskilbeckTopic starter
« Reply #152 on: September 29, 2021, 05:21:15 pm »
It's here https://github.com/cskilbeck/modbus but I haven't touched it for ages and it will surely not work with the reversed LSB firmware, someone would need to add a command line switch to enable that
Offline interflexo
  • Country: pt
« Reply #153 on: October 28, 2021, 11:24:45 am »
New KP184 Software Version 1.0.27.0:
Changes:
1. Overcomes a KP184 internal firmware issue that periodically (each 7.53h) resets the Wh value during very long battery discharge tests. The screen shows the internal Kunkin Wh value but the saved .csv file shows the correct calculated value by the software. The Kunkin internal calculations for the Ah values are all right. I thank all the users that perform comprehensive tests and report these issues.
2. Several Python modules were updated.
« Last Edit: August 10, 2026, 04:15:02 pm by interflexo »
Offline voltsandjolts
« Reply #154 on: October 28, 2021, 12:07:05 pm »
Are you using tkinter for this app's gui?
How do you create the exe?
Is the source code available somewhere?
I'm just interested in Python gui programming and interested to see how you've done it.
Offline interflexo
  • Country: pt
« Reply #155 on: October 28, 2021, 01:23:47 pm »
Hi voltsandjolts. This application is programmed in Python 3, GUI is coded using PySimpleGUI module (wrapper for tkinter). Graphics produced with matplotlib module. The .exe file is created with pyInstaller. The source code is not available at this point.
The following users thanked this post: voltsandjolts
Offline interflexo
  • Country: pt
« Reply #156 on: November 02, 2021, 12:56:59 pm »
New KP184 Software Version 1.0.28.0:
Changes:
1. On the non static cycle (CYC) load mode the user load profile definition text for line comment char was changed from '#' to '//'. The .ini read file parsing code was deleting multiple line comments.
2. Several GUI tooltips were corrected.
« Last Edit: August 10, 2026, 04:15:52 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #157 on: November 08, 2021, 12:59:52 pm »
New enhanced User Manual for KP184 ModBus Software:
User_Manual
« Last Edit: August 10, 2026, 04:16:29 pm by interflexo »
Offline Ziggo
« Reply #158 on: November 10, 2021, 06:35:11 am »
Does the software support multiple units on a single RS485 bus? I have 3 now but really need at least 3 more to get enough load for some tests.
The units themselves claim to support a "master / slave" mode for multiple units but I haven't tried it yet (since I can barely use them at this point because the rotary encoders are so flaky).
Offline interflexo
  • Country: pt
« Reply #159 on: November 10, 2021, 08:09:07 pm »
From the user Kunkin KP184 manual:
"Set up online mode. KP182 load provides a multimachine online mode. The multimachine is connected through 485 communication wire. There is one master, and the other devices are slaves. When setting up parameter on the host panel and operating ON/OFF, these operations are sent to the slave through communication port and the slave will execute the same operation."
The OnLine Host/Slave mode is just a way of blindly broadcasting the Host panel key strokes to all the Slaves in RS-485 network. The manufacturer intent here was to be able to perform the same test on several different KP184 units at the same time. When this OnLine mode in engaged I think there is no feedback from the slave units or the Master for that matter (I am guessing here). So there is no way of making remote data acquisition on this mode.
This multi device mode would have to be emulated with the normal ModBus comms. The software commands would have to be broadcasted for each previously configured slave addresses, and each slave would be pooled in succession to retrieved it's data. The sample period would take a hit. The KP184 firmware is a bit slow to respond. A minimum practical value of 250ms is standard for one unit. Using 4 units in a RS485 network the minimum sample period would be 1 second. The savings here would be an USB to serial adapter per KP184.
The KP184 ModBus software as is can't do what you want via RS-485. You can however launch unlimited instances of the software on the PC communicating simultaneously with USB to serial adapters with different KP184 units which are wired in parallel with the same load and control (no need to touch the operating panel) and record the data acquisition of each instance. This method would leave the minimum sample period unharmed.
If each single unit works well via RS-485 with the software I could change the software to accommodate this feature if there is a broad interest about it. However this seems to me to be a niche within a niche.
The GUI interface would consume most of the work and comms would be the easy part, i have the same threaded  low level code working with 30 simultaneous serial channels within the same application.
« Last Edit: November 11, 2021, 07:19:27 am by interflexo »
Offline HKJ
    • Tests
« Reply #160 on: November 10, 2021, 08:52:07 pm »
With TestController ( https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/ ) you can run any number (and brands) of loads in parallel as long as each has its own connection to the computer (i.e. not 485).
Offline interflexo
  • Country: pt
« Reply #161 on: November 10, 2021, 10:34:05 pm »
Ziggo has issues with the rotary encoders and needs KP184 full remote panel control. I mensioned 6 loads because Ziggo needs 3 + 3 electronic loads.
Offline HKJ
    • Tests
« Reply #162 on: November 11, 2021, 06:34:26 am »
In TestController you will get a control panel like this for each load:
There are many different way to see the values from the load and it is also possible to define more limited control panels.
If the same test needs to be repeated, it is fairly easy to generate a script for it.
The following users thanked this post: dophuc
Offline interflexo
  • Country: pt
« Reply #163 on: November 17, 2021, 06:13:25 pm »
New KP184 Modbus Software Version 1.0.29.0:
Changes:
1. New solar panel test mode (SOL) added. A user defined CV sweep mode records de solar panel characteristic I-V curve and MPP data for device diagnostic or manufacturer specifications comparison.
2. The data acquisition report button now handles both report types (battery capacity discharge test and solar panel test) according to the last test mode.
3. Correction on the non static programmable profile cycle (CYC) load mode startup.
4. Some settings were not available on the configuration dialog window.
Updated User Manual
Solar Panel Test Report Example
« Last Edit: August 10, 2026, 04:17:28 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #164 on: November 19, 2021, 03:12:41 pm »
New KP184 Modbus Software Version 1.0.30.0:
Changes:
1. Both types of reports (battery capacity discharge test and solar panel test) now share the same PDF generation engine and have a consistent layout. Got rid of the html conversion stuff.
2. Correction on the non static cycle (CYC) load mode. Now when the load profile programming code is empty the load does not turn on and an appropriate message is displayed.
3. On the solar panel test mode (SOL) plot graph curves the MPP point is now highlighted in red.
4. On the data acquisition save .csv or .png plot graph files a file explorer window is opened with the selected file.
« Last Edit: August 10, 2026, 04:18:18 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #165 on: November 27, 2021, 09:08:27 am »
A couple of videos explaining operation with KP184 Modbus Software:
« Last Edit: November 29, 2021, 11:23:34 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #166 on: December 04, 2021, 11:52:05 pm »
New KP184 Modbus Software Version 1.0.31.0:
Changes:
1. Some python modules updated.
2. Resolved some issues with the tests PDF reports.
To install as Administrator:
1. Open File Explorer.
2. Navigate to the folder with the setup executable file.
3. Select the setup executable file.
4. Use the right mouse button to show the file context menu.
5. Click the Run as administrator option.
« Last Edit: August 10, 2026, 04:19:12 pm by interflexo »
Offline dophuc
  • Country: vn
« Reply #167 on: December 09, 2021, 03:42:58 am »
Hello everyone,
Sorry if my English is not good
I'm testing new KP184 software from Kunkin for KP184 2020.
Now you can use the DB9 to DB9 serial cable that comes with the KP184 connected via a physical Com port or some inexpensive USB - RS232 cable such as a $1 USB-RS232 serial cable using the CH340 chipset ; 2$ 6 in 1 adapter using chipset CP2102... New software and cable work well on Win 10, Win 11 (driver update)
« Last Edit: December 09, 2021, 05:30:34 pm by dophuc »
Offline interflexo
  • Country: pt
« Reply #168 on: December 09, 2021, 08:41:30 am »
With KP184 Modbus software and from the user manual page 9:
Check the CRC LSB First option if you experience difficulties establishing the
serial communication with KP184 later models (Firmware 2020 and up – can
be checked through the Kunkin screen brief flash at startup)
« Last Edit: December 09, 2021, 08:58:57 am by interflexo »
Offline interflexo
  • Country: pt
« Reply #169 on: December 10, 2021, 11:41:48 am »
New KP184 Modbus Software Version 1.0.32.0:
Changes:
1. When having trouble to connect both CRC LSB First flag states are tested for the new Kunkin 2020 Fimware and above.
2. Resolved some issues with the modded KP182 identification on the PDF reports.
« Last Edit: August 10, 2026, 04:20:12 pm by interflexo »
Offline dophuc
  • Country: vn
« Reply #170 on: December 15, 2021, 12:00:28 pm »
For people to have more choices of software. I sent Kunkin's software for KP184 (2020).
I have tested with KP184 version 2020 installed on Windows 11, all working fine.
Please read the note before installing the software.
Hope everyone will be satisfied when using this software.
Link download:
https://mega.nz/file/6kdCkDyJ#UonyK7a-SpXjgB_XiowcR9-LPijSO2mTcB2TciwUW6Q
I took some pictures of my KP184
« Last Edit: December 15, 2021, 01:32:00 pm by dophuc »
Offline interflexo
  • Country: pt
« Reply #171 on: December 28, 2021, 10:35:08 am »
New KP184 Modbus Software Version 1.0.33.0:
Changes:
1. Several python modules were updated for extended compatibility.
« Last Edit: August 10, 2026, 04:21:26 pm by interflexo »
The following users thanked this post: adso85swe
Offline interflexo
  • Country: pt
« Reply #172 on: December 30, 2021, 03:44:31 pm »
New KP184 Modbus Software Version 1.0.34.0:
Changes:
1. Application now checks for updates at startup.
« Last Edit: August 10, 2026, 04:22:11 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #173 on: January 04, 2022, 11:42:23 pm »
New KP184 Modbus Software Version 1.0.35.0:
Changes:
1. Application load time was cut in half.
2. Software updates are automatically downloaded and installed upon user confirmation.
Setup KP184 Software V1.0.92.0
« Last Edit: April 14, 2025, 04:30:45 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #174 on: February 21, 2022, 02:18:37 pm »
I wonder if some already tested this KP184E with the Modbus software.
https://www.alibaba.com/product-detail/KP184E-150V-40A-400W-LCD-Display_1600272552716.html
Same specs and a 320 x 240 TFT color screen single page UI plus Modbus + SCPI on RS232/RS485.
The add states Reverse polarity protection. I don't know if this a typo or substantial changes were made to the PCB power circuitry.
