Author Topic: SG-816/U High Power Pulse Generator  (Read 1410 times)
Offline graybeardTopic starter
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« on: September 03, 2020, 11:59:19 pm »
I bought this pulse generator about 25 years ago at the W6TRW swap meet.  It has always worked, and was working the last time I fired it up about two years ago.  It is capable of putting a 50 Volt pulse into a 50 Ohm load, that is 50 Watts of power.
I have never been able to locate any documentation for this unit, so please chime in if you know of a source.  It was built by Systron-Donner/Datapulse in Culver City California in 1969, based on the component date codes.
It is an interesting hybrid circuit that uses Silicon bipolar transistors, Silicon and Germanium diodes, 2 nuvistors, and a pair of of 7534 high power/high reliability pentodes as cathode follower output drivers.
It is a somewhat unique instrument, so I thought I would share some photos.  You can click on any of the photos to see the full resolution images.
... Chris
« Last Edit: September 04, 2020, 03:07:22 am by graybeard »
The following users thanked this post: egonotto, capt bullshot, syau, 0culus, D Straney
Offline 0culus
Re: SG-816/U High Power Pulse Generator
« Reply #1 on: September 04, 2020, 02:16:25 am »
Very cool...for radar testing I presume? Guessing since it says made for the Navy.
    • Chris Grossman
« Reply #2 on: September 05, 2020, 02:05:13 pm »
When I did some more online searching for a manual I found two references to it being used for Sonar tests.
... Chris
Offline TimFox
« Reply #3 on: September 05, 2020, 03:32:42 pm »
I looked at the datasheet you linked for the 7534 output tubes--quite impressive.  Before this, I was unaware of frame grids in power tubes, which gave the 7534 a 25 mA/V transconductance and very low screen current (4 mA).
Back in grad school, I used Delco high-voltage TO-3 transistors (higher voltage part in the same series as your DTS-423) to generate 1000 V pk-pk deflection waveforms, using a cascode totem-pole output stage.
« Last Edit: September 05, 2020, 03:37:48 pm by TimFox »
    • Chris Grossman
« Reply #4 on: September 05, 2020, 03:45:31 pm »
Running bipolars in common base mode (cascode output stage) allows you to swing the almost full base-collector breakdown voltage on the device so long as it is not in a high radiation environment.
    • Chris Grossman
« Reply #5 on: September 06, 2020, 12:20:40 am »
I fired it it up again today.  Here are some output waveforms into a 50 Ohm load.  I used a 20W 20db attenuator into a 2W 20dB attenuator into a 50 Ohm feed through termination.
Chris
« Last Edit: September 06, 2020, 12:47:20 am by graybeard »
    • Chris Grossman
« Reply #6 on: September 11, 2020, 06:49:09 pm »
I was looking again online to see if I could find a manual for the SG-816/U High Power Pulse Generator.  I have not, but I did find specifications for it:
Chris
