That's why we still have LeCroy oscilloscopes—because of the current probes.
But I've switched over, and the last 6 current probes (all from Siglent) that I bought for work don't have a bus interface.
I wouldn't get too hung up on the bus interface either; as you correctly pointed out, it's a matter of convenience and makes the current clamp a bit more compact.
More important are the features themselves and the Micsig… well… I’d tested it, just as I’d tested almost everything else in recent years that falls under the “Tektronix principle.”
Including an “Instrance” current clamp that I won’t be forgetting anytime soon.
The conclusion from all these tests was that you either have to dig deep into your pockets or buy a used Tek current probe along with a power supply and amplifier—if you value good performance, that’s a given.
If something like the Micsig is enough for him, well, then everything's great.
