thanks so much for all your comments. I'm actually wondering whether the low end scopes will do what I need. I have basically eliminated the Rigol because of its poor fft capability-saw this in a review comparo. Does the hacked Rigol perform any better in this area?
So in Australia the Rigol is around Aus$600, if I increased my budget to Aus$1000, are there any better options? To expand, my interests are in 3 areas: Audio, Micro controllers, and Radio Astronomy (the latter a new interest - my hobby has been CCD imaging in my home observatory for years...). I've been watching local secondhand sources, but nothing decent has come up.
cheers
Gary
It's ultimately your choice in the end, but I'm not sure poor FFT performance on a scope should necessarily be a deal breaker, at least for the applications you're mentioning. If you want an audio FFT, then the 8 bit converters (or swanky 12 bit high res converters) in scopes are never going to give you as much detail as a cheap USB sound card with a 16 or 24 bit ADC on its input channel, and there is free software available that will blow away almost any scope FFT performance because it has access to the main CPU and RAM of a PC. The limitation on using an audio ADC is bandwidth, of course, but if you can't hear beyond 20kHz or so, you don't need megasamples per second to see what's going in with great detail.
On the radio astronomy side, the problem is actually the same, but the solution is different. Not so much to get resolution in your bins over a wide span, but to get the extremely low noise performance that you need to pick up things very far away, an 8-12 bit converter simply doesn't have the dynamic range to see quiet signals over its noise floor. If you're looking at something transmitting in the scope's bandwidth limit and at a very high power (terrestrial sources, basically), then you could theoretically see it... but the low noise and high dynamic range of a proper spectrum analyzer is really what you'd be after.
As for the micro controller part, getting SPI or I2C decoding for a free is a very nice bonus, and it could be useful to have more than 2 channels (like with SPI), though two channels can be good for some serial decoding work and are fine for most basic analog bits interfacing with the micro or for monitoring noise on power rails or what have you.
And from my experience, owning two rigol scopes and a siglent and currently using a rigol scope and a siglent function gen..... the prevalence of software bugs are being very, very exaggerated. I don't mean to dismiss them entirely, as I have run into a couple of minor ones over the years, they are usually relatively minor issues with parts of the instrument that aren't as commonly used... and they do get updated. Even budget scopes will be fairly current for several years (take a look at the 1054Z, for example, which has been recommended for years and still is), and they will get half a dozen or a dozen updates over that lifetime. Sure, if you buy the month it comes out and the first update to fix a glitch takes a few months you won't be happy, but if they've been on the market for a bit, any huge, usage-breaking bugs will not be present from any major manufacturer's firmware... and just reading up on them should give you a good idea of what the problem actually amounts to. Especially for cheaper scopes from major manufacturers, there's no shortage of people with experience with them available online.
Bottom line is that probably many of the scopes mentioned will probably be great tools to add to your workspace. Maybe find a couple make-or-break features to stick with, or play around with the UIs to find your preference (I actually liked my Siglent 1102X's UI a bit better than my current Rigol DS4024, but the hardware is hardly comparable), or just try to find a good deal.
