Hi everyone, lets see if I get my first post right...
My SDG 1032X is plagued by quite a bit of fan noise due to its case design. I wanted to do the most simple fix and add a resistor to the fan.
Being the cautious guy that I am, I first checked temperatures with an IR camera. Well, everything seems pretty cool (up to mid 40°C), except for three 20k resistors in the power supply section, which heat up to 106°C.
They can be seen in the top middle of the picture, just below the red line:
![Siglent SDG 1032X Hot Resistors in Power Supply 1182004-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=271678.0;attach=1182006;image)
It seems to me the resistors supply the switching circuitry with its operating power. Their relatively huge (surface) size and the fact that there are three of them tells me some heat is to be expected here.
But I am not sure if 106°C is to be expected and if even more would still be ok.
My research only revealed that a typical temperature limit for resistors could be between 105 and 150°C. So it is unclear to me if this is already maxed out or not.
The resistors are not directly in the air stream (see air inlet on top left side), but there might be turbulences providing cooling.
My measurement was done with the case open (therefore no air stream from fan.)
What do the experts here say? Is the temperature already in the red and I should not touch the fan or is there is still room to go higher - and quiter?
Thanks.
