Author Topic: Siglent SDG2042X Hack door closed  (Read 87848 times)
Offline Martin72
  • Testfield Technician
Re: Siglent SDG2042X Hack door closed
« Reply #175 on: July 21, 2023, 11:48:13 am »
Maybe we should make a script for the sdg only (just remove all things except 120Mhz bandwith (and 40Mhz for selfcontrol)) to avoid misunderstandment.
Offline tv84
  • Country: pt
« Reply #176 on: July 21, 2023, 05:55:08 pm »
Don't go that way as there's plenty of garbage around already. Those that can't solve that by themselves don't deserve to "hack" the thing.
The following users thanked this post: Martin72, blurpy, Wrenches of Death
Offline gjvdheiden
« Reply #177 on: July 23, 2023, 12:12:59 pm »
Indeed. I applied this hack a month ago or so, it is so stupid simple, nothing will help to make this easier.
Offline LogicalDave
« Reply #178 on: September 03, 2023, 09:48:15 pm »
Thanks for the "Guide for Dummies" @ghulands, I can confirm that an "improved" SDG2042X does indeed produce a clean 120MHz signal (checked on a 500MHz scope).  Folks doing this with generators running newer firmware should note that the hack requires downgrading the firmware to 17R5 and then back up to 23R8 and then 37R6 in steps.  It's also worth noting that new/larger USB flash drives don't seem to work; I had to dig up an old 128MB flash stick.
Perhaps the hardest thing about the hack these days is finding the actual instructions because the threads have become so long (68 pages)!  The link of interest is here: https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/msg928681/#msg928681
« Reply #179 on: September 03, 2023, 09:57:21 pm »
Did you miss the much more recent process and just use one from 2016 ?
https://www.eevblog.com/forum/testgear/siglent-sdg2042x-hack-door-closed/msg4599439/#msg4599439
Much much safer than mucking with OS code.
Avid Rabid Hobbyist
Online KungFuJosh
  • TEAS is real.
« Reply #180 on: September 04, 2023, 02:50:16 pm »
Larger flash drives work fine, but not all brands and types are equal. I use SanDisk 32GB Ultra Fit USB 3.1 Flash Drives in all my Siglent gear with no issues. Firmware upgrades run without trouble too.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline gjvdheiden
« Reply #181 on: September 06, 2023, 08:47:54 am »
Yes, somehow that method sticks... No idea why you want to do that. Maybe because of the title of this thread? Maybe you need port 5024 (not a standard ip port) and telnet (not ssh)? No idea. Haven't tried, but I think the telnet method is even reversible.
I did update the firmware to whatever was the latest. But the update had no relation with the telnet hack. I repartitioned the USB, so there was only one partition on it. Sometimes there are weird partitions on the stick from factory and/or when used to boot a Raspberry Pi. Also storing files on the USB stick works fine after partitioning it. But again, only for updating and storing. Normal use.
Offline Minki
  • Country: jp
« Reply #182 on: November 03, 2023, 08:27:44 am »
Hackupdate report
I just get the unit today.
The keygen method still working  :-+ :-+ :D ;) :popcorn:
[ Specified attachment is not available ]
« Last Edit: November 03, 2023, 03:31:53 pm by Minki »
Offline ebastler
« Reply #183 on: November 03, 2023, 08:54:06 am »
Hack report
Too bad these units have the power connector on the back. Otherwise you could hack them before even fully unpacking.  ;)
ebastler, who still enjoys his "upgraded" SDG2042X.
(Except for the slightly sluggish touch screen and rubber buttons...)
Offline Johnny B Good
« Reply #184 on: November 03, 2023, 02:58:17 pm »
 Minki misnamed his licence upgrade as a "hacking" exercise which carries no risk of turning his brand new SDG 2042X into a "brick", hence his "plunging straight into 'upgrading it'" straight out of the box. :)
 The worst that can happen when using the keygen is that it simply rejects invalid licence keys with no harm done.  I guess he must have thoroughly researched the topic perhaps even to the point of having the keygen script ready to roll the minute he'd unpacked and checked it out. ::)
« Last Edit: November 04, 2023, 10:42:05 pm by Johnny B Good »
John
Offline Minki
  • Country: jp
« Reply #185 on: November 03, 2023, 03:34:03 pm »
 The worst that can happen when using the keygen is that it simply rejects invalid licence keys with no harm done.  I guess he must have thoughly researched the topic perhaps even to the point of having the keygen script ready to roll the minute he'd unpacked and checked it out. ::)
Just want to share the state :'( :'(
I am happy with SDG2042X easy to  'upgrading it' and stick in SDS6000A upgrading :'( :'( :'( :'( :'(
Offline Martin72
« Reply #186 on: November 03, 2023, 06:43:04 pm »
Hackupdate report
Another one who made it.  :-+
Offline Peter_O
« Reply #187 on: November 05, 2023, 01:22:57 pm »
Instructions are still valid.  :D
HW 02-02-00-40-00
SW 2.01.01.35R3B2
The online python worked fine:
https://www.programiz.com/python-programming/online-compiler/
Thx to all of you involved in exploring the device.  :-+
Without reading the full thread:  :-[
Is the -40- in the HW version info a hint, that there is some bandwidth specific HW involved and that the 120 HW might be different?   :scared:
Edit: reading some of the thread: NO, the -40- is some kind of HW version counter, there are -35- or -46- devices in this thread.   :phew:
But nevertheless: Any HW or performance differences known?
« Last Edit: November 05, 2023, 01:32:17 pm by Peter_O »
« Reply #188 on: November 05, 2023, 08:44:25 pm »
Best to stick to official BW licenses to ensure performance matches spec.  ;)
40, 80 or 120 MHz.
Avid Rabid Hobbyist
The following users thanked this post: Peter_O
Offline alexian79
« Reply #189 on: December 26, 2023, 09:55:51 pm »
HW 06-00-00-46-00
Product type : SDG2042X
software unlock/upgrade script did not work for me. None of the options matched code in the device. That is sad, might be returning it to Amazon.
Offline tv84
  • Country: pt
« Reply #190 on: December 26, 2023, 10:01:39 pm »
HW 06-00-00-46-00
Then you must be doing something wrong.
Offline alexian79
« Reply #191 on: December 26, 2023, 10:07:25 pm »
Thank you,
it sure can be I am doing something wrong, for the script is product name should be as on screenshot? should SCOPEID be padded with something to certain length?
Offline tv84
  • Country: pt
« Reply #192 on: December 26, 2023, 10:19:52 pm »
Thank you,
The model is wrong. Should be like SDG2000X.
The following users thanked this post: alexian79
Offline alexian79
« Reply #193 on: December 26, 2023, 10:28:34 pm »
thank you TV84, with correct SCOPEID it now matches 40M option from generator.
HW 06-00-00-46-00 works fine.
Offline backyard_cnc
« Reply #194 on: January 06, 2024, 04:28:37 am »
Worked as promised! Easy peasy as long as you pay close attention to the details!  Tnx so much!
 I’m  loving this forum and the very affordable Siglent test equipment, I’ve got both my SDS1104X-E and SDG2042x “enhanced” and I’m now looking very strongly at ordering up the Siglent SSA3021X plus as soon as the toy budget bounces back.
Offline Michael-VK2BEA
« Reply #195 on: February 11, 2024, 04:18:56 pm »
FYI: The Python script doesn't run under Python 3.12.1
I had to specifically specify Python 3.11.
(using Fedora Linux)
😼 python3.11 ./SiglentKeygen.py
INFO: CHECK YOUR GENERATED KEY BEFOR ENTER A NEW ONE !!!
You get your bandwidth key by running "MCBD?" at the SCIP prompt
Compare your key with the generated key
INFO: IT HAVE TO BE SAME !!!
Here are the bandwidth codes
Enter these codes over SCIP prompt
« Last Edit: February 11, 2024, 06:30:06 pm by Michael-VK2BEA »
Offline ali_asadzadeh
« Reply #196 on: March 09, 2024, 01:02:13 pm »
Thanks for sharing, I managed to crack the scope from SDS2104X Plus to SDS2354X Plus, also I have added the otpions like FLX,I2S, etc... But the script has lacking serials for these options
SDS_2000XP_SENT
SDS_2000XP_Manch
SDS_2000XP_4BW05
What string should I use for it in the script?
bwopt = ('25M', '40M', '50M', '60M', '70M', '100M', '120M','150M', '200M', '250M', '300M', '350M', '500M', '750M', '1000M', 'MAX', 'AWG', 'WIFI', 'MSO', 'FLX', 'CFD', 'I2S', '1553', 'PWA')
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline Martin72
« Reply #197 on: March 09, 2024, 01:38:47 pm »
Wrong thread here...
« Reply #198 on: March 11, 2024, 02:06:43 pm »
already found them
'MANC', 'SENT', '500M'
Offline TaylorD93
« Reply #199 on: April 30, 2024, 06:54:14 pm »
trying to do this hack to my SDG2042x Firmware V2.01.01.38
Im trying to find a link to the actual script to create the keygen etc, the putty bit ive had no issues with, but all the links ive found (including the two in the SDS scope thread) go to here https://replit.com/repls/ElasticEnormousMice  and it says "page not found" even after ive logged in
All of Martins other steps have worked, i just cannot create the keygen without the script.
thanks in advance!
Edit; Found a script here https://pastebin.com/fygAJy6y , for the "ScopeID" line of the code i entered my S/N, Model as 'SDG2000X' changed the '150M' setting to '120M' then compiled it using an online util here https://www.programiz.com/python-programming/online-compiler/
as per previous posts, i double checked that the key generated for the '40M' option matched my current key (logged by sending the MCBD? at the start via the telnet) once i saw that it matched, i realised the python script had worked.
sent the new key in via the MCBD command, works perfect :)
thanks all! i suppose this also helps anyone else wondering if the latest V2.01.01.38 still allows it... yes it does!
« Last Edit: April 30, 2024, 08:07:13 pm by TaylorD93 »
