I purchased Metravi (india) DSO-5070A on 27-Aug-2013 from Lynx-India. This is manufactured by Siglent and known as SDS1072CML. Making EasyScopeX work was like hitting a wall. It was due to, lack of properly defined steps and software prerequisites in the manual.
Yesterday, after lot of R&D I figured out steps that made every time EasyScopeX work and recognize the oscilloscope on three different machines viz Windows XP Pro SP3 (32-bit), Windows 7 SP1 (32-bit) and Windows 7 SP1 (64-bit). I am mentioning those steps here to save others from wasting time and re-inventing wheel. These steps must be followed strictly.
Caution: DO NOT CONNECT OSCILLOSCOPE TO COMPUTER'S USB PORT UNTILL BELOW STEPS ARE FULLY FOLLOWED.
Warning: I am not liable/responsible, if things goes wrong at your end. Follow, below steps at your own risk.
Note: On Windows 7, run installers with administrative privileges.
Download and Installations
1. Microsoft .NET Framework 3.5 Service pack 1 (Full Package) [http://www.microsoft.com/en-us/download/details.aspx?id=25150]
1.1 Windows XP SP3 (32/64 bit): Download and Install if not previously done.
1.2 Windows 7 or Windows 7 SP1 (32/64 bit): Enable it from Control Panel > Programs > Turn Windows Features On and Off.
2. Reboot machine after installing or enabling the .Net Framework 3.5 SP1.
3. IVI Shared Components [http://www.ivifoundation.org/shared_components/Default.aspx]
3.1 Download and Install IviSharedComponents_x.x.x.msi or IviSharedComponents_x.x.x.exe on 32-bit Windows. IviSharedComponents64_x.x.x.msi or IviSharedComponents64_x.x.x.exe on 64-bit Windows.
3.2 Download and Install (VISA Shared Component) IviVisaSharedComponents32_x.x.msi on 32-bit Windows or IviVisaSharedComponents64_x.x.msi on 64-bit Windows.
4. Reboot machine after installing IVI shared components.
5. NI-VISA 5.1.2 [http://joule.ni.com/nidu/cds/view/p/id/2914/lang/en]
5.1 Register on NI site to download NI-VISA 5.1.2
5.2 Download NI-VISA 5.1.2 (574.97 MB).
5.3 During installation choose to install .Net Framework 3.5 support under "Development" and "Measurement & Automation Explorer" menus. Leave others in default state.
6. Reboot machine after installing Ni-VISA 5.1.2
7. Open Measurement & Automation Explorer.
8. Turn On oscilloscope and make sure the back USB port is set to "USBTMC" mode. Follow manual to perform the same.
9. Temporarily disable Internet connection on computer to prevent Windows searching drivers online because it eventually fails to find suitable driver for USBTMC devices.
10. Connect oscilloscope to computer's USB port.
11. Windows must recognize and install the device as "Test and Measurement Devices (IVI)". The device will appear in "Measurment & Automation Explorer" as USB::manufacturer-ID::model-code::serial-number::INSTR. Please note INSTR.
12. Finally, install EasyScopeX and ADD your device. (Reboot computer if required)
If you have followed steps strictly. I am pretty confident that EasyScopeX will show your device and ADD it easily.
In case you previously tried to connect oscilloscope with or without installing prerequisites and messed up things on computer. Please follow the below steps
1. Right Click > My Computer > Properties > Advanced Tab > Environment Variables.
2. Under System variables > Press "New" Button
3. Type "DEVMGR_SHOW_NONPRESENT_DEVICES" in Variable name and set Variable value to "1".
4. Right Click > My Computer > Properties > Hardware Tab > Device Manager.
5. Device Manager > View > Show Hidden Devices.
6. Uninstall greyed out devices under Universal Serial Bus controllers.
7. If you see greyed out device showing device model number, uninstall it.
8. It is good practice to uninstall greyed out devices time to time as this make your computer neat and tidy.
9. Uninstall IVI, VISA and NI-VISA. Delete their physical folders as well from "Program Files" location after reboot.
10. Delete files from "C:\Documents and Settings\<User-Profile>\Local Settings\Temp" (Hidden) on XP machine. In Windows 7 "C:\Users\<username>\AppData\Local\Temp" and "C:\Users\<username>\AppData\Roaming\Temp".
11. Use Free CCleaner to clear registry entries. It can be downloaded from [http://www.filehippo.com/download_ccleaner/]
12. Reboot computer and follow installation steps mentioned above.
Regards,
Sameer Dhiman
