Author Topic: Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests  (Read 416391 times)
0 Members and 12 Guests are viewing this topic.
Offline KungFuJosh
  • TEAS is real.
Re: Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests
« Reply #925 on: April 02, 2024, 08:23:11 pm »
This is a minor UI bug.
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Offline hpw
« Reply #926 on: April 02, 2024, 09:23:03 pm »
Small changes in FFT. Now log10/linear
Yes, this is nice
as it gets, was looking for any colors changing. Look at given pic's dark yellow text and lighter yellow line... so hard to see about the freq. axis values
« Last Edit: April 02, 2024, 09:25:16 pm by hpw »
Offline mathstudi
« Reply #927 on: April 02, 2024, 09:29:21 pm »
New UI update seems to lack anti-aliasing and the padding is also off, buttons are harder to press with fingers now..
I hope this will be reverted to be in the style of 1.5.3  :o
Yes, I also noticed the anti-aliasing, but only when you pointed it out. It doesn't bother me, but it's an aesthetic thing that is perceived individually.
I like the serial decoders that I tested today. Too bad the documentation (Serial Signal Test for I2C and SPI) is not ready yet.
My bandwidth tests with the tinySA ULTRA were all positive.
Unfortunately there is no I3C decoder. This is probably a licensing problem, because there is no free I3C decoder for the saleae Logic Analyzer either, although many decoders are already included with the saleae.
What makes me happy is the fact that Siglent is still doing a great job of product maintenance. Especially that new gadgets are still being added.
Cheers
The following users thanked this post: tautech, KungFuJosh
Offline tautech
« Reply #928 on: April 02, 2024, 09:30:07 pm »
Yes, this is nice
Change your Scale or Ref level.  :P
Avid Rabid Hobbyist
The following users thanked this post: Mahagam
Offline electronics hobbyist
  • Country: cn
    • sds800x-hd-review-demonstration-thread
« Reply #929 on: April 03, 2024, 01:38:20 am »
Which button is more difficult to press? The size of the button looks the same. It would be even better if a picture could be attached.
« Last Edit: April 03, 2024, 02:35:31 am by electronics hobbyist »
Offline hpw
« Reply #930 on: April 03, 2024, 09:48:51 am »
Yes, this is nice
Sometimes it is prefered to keep the full scale as to track the progress.
As only 20dB/div maximum scale possible, not any 25...30..40..50 given O:((
Now on print png, the text gets now some white/blue collor while saving.
Offline smallfreak
  • Country: at
« Reply #931 on: April 03, 2024, 10:06:15 am »
Do you have an example? The PNG should look just as the screen. Happening with the "print" button, or via web interface?
Offline hpw
« Reply #932 on: April 03, 2024, 10:37:56 am »
As I told you, the axis x/y text gets this color while saving in progress. Only at that time and then come back to normal.
In addition, you will see scope & FFT axis X/Y color as quasi nor readable while it is NOT POSSIBLE to alter those line or axis colors.
So the request is simple  :-DD:
- lets modify the colors as all SW allow this  :-+
- add 25/30/40/50 dB/div  :-+
- may as simple wish, to add scale dBV/rthz as a simple task  :-+
« Last Edit: April 03, 2024, 10:40:56 am by hpw »
Online 2N3055
  • Country: hr
« Reply #933 on: April 03, 2024, 10:46:31 am »
Yes, this is nice
What would be the purpose of 50dB/div ??
You think any system in the universe have 400dB instantaneous dynamic range?
On a 8 bit scope?
Dr. Richard W. Hamming
The following users thanked this post: Performa01, tautech
Offline hpw
« Reply #934 on: April 03, 2024, 11:12:36 am »
well, 50dB for a 4..5 x 50dB as 200..250dB full range as my pictures shows up.
Offline hpw
« Reply #935 on: April 03, 2024, 11:14:16 am »
One more wish:
- add the used FFT Window to the BIN file, so we know later on, what FFT Window has been used
- may add better performing FFT Window functions as BH7
Online 2N3055
  • Country: hr
« Reply #936 on: April 03, 2024, 11:21:01 am »
FFT has 8 vertical divisions. 8*50=400
You can also use split window.
Offline KungFuJosh
  • TEAS is real.
« Reply #937 on: April 03, 2024, 02:35:01 pm »
Are you complaining about the colors in your screenshot being inverted? That's a setting.
Offline hpw
« Reply #938 on: April 03, 2024, 09:01:14 pm »
Look, the probe gain supports +1E6 to -1E6 so we get +/- 120dB  ... so for 8 x 20dB Grid there is not much room left
Offline hpw
« Reply #939 on: April 03, 2024, 09:04:42 pm »
About the color thing: this is possible and in the latest given documented.
To setup / change the colors:
[1] >> Display menu... then on the right go down until this settings sub menu entry is visible.
[2] only Math F1 or F2 as for line and axis text.
Offline hpw
« Reply #940 on: April 03, 2024, 09:12:35 pm »
Three bug seen on V1.6.2:
[1] reboot and have setup as C2 & F1: you will see for a while the NOT enabled C1 input and than alters to C2 & F1
[2] using this setup: on the right side an 500Hz vertical line is drawn. See picture with red rectagle
[3] If you enable on C2 the axis text as level & time as I use right justify: the level Y axis text gets overwritten by the trace line
Offline mathstudi
« Reply #941 on: April 06, 2024, 07:38:26 pm »
Haven't tested the new function yet. I'll wait for the adapted documentation.
These are what is called compliance tests.
They will automatically test number of critical parameters of protocol and compile a PASS/FAIL test report with data.
I actually wanted to wait for the updated documentation. But the interest in the new function was greater and so today I ran some tests with an I2C protocol.
I am impressed! I've been looking for something like this for a long time, especially for the popular I2C and SPI protocols.
This is exactly what I appreciate about Siglent, that even years after the market launch, new gadgets are still being added.
The "fail" with the "Clock Signal Frequency" is my mistake -> wrong configuration.
A report can also be generated (HTML/XML), which is quite impressive. I will do further tests.
Offline mon
« Reply #942 on: April 07, 2024, 10:58:33 am »
Did 1.6.2 get yanked? Everywhere I checked is still 1.5.2R3 (int.siglent.com, siglentna.com, and siglent.com)
Offline james38
« Reply #943 on: April 07, 2024, 11:59:23 am »
Yes, there were some problems (freezes) with the upgrade for some,
so the update has been withdrawn until further notice.
I think we have to wait here for now.
Regards Chris
Offline BitBangingBytes
« Reply #944 on: April 11, 2024, 05:40:44 am »
That’s a bummer! I discovered my VNC no longer works properly after upgrading to the latest 1.5 version and found this thread where others seemed to have the same issue.
Hopefully the 1.6 version goes public soon so I can see if that fixes it.
Offline KungFuJosh
  • TEAS is real.
« Reply #945 on: April 11, 2024, 01:07:52 pm »
I never tried connecting through VNC before 1.6,  but it worked fine on 1.6.2R1 for me.
« Reply #946 on: April 11, 2024, 03:15:08 pm »
Unplugging everything and doing the Math button repeated press upon boot seems to have fixed it for now.
I had tried that last night but didn’t unplug the Ethernet cable. Unplugging it today and doing it seems to have worked.
Offline KungFuJosh
  • TEAS is real.
« Reply #947 on: April 11, 2024, 03:35:44 pm »
Is that a thing? I don't remember reading about that.
« Reply #948 on: April 11, 2024, 05:10:32 pm »
Yea, I was closely reading Siglent’s directions last night…
2114078-0
The following users thanked this post: smallfreak, KungFuJosh
Offline tautech
« Reply #949 on: April 11, 2024, 05:16:39 pm »
Yes, for boot freeze recovery.
Did pressing Default not work for you ?
Avid Rabid Hobbyist
