Author Topic: Siglent SDS2000X Plus  (Read 736311 times)
Online tautechTopic starter
Re: Siglent SDS2000X Plus
« Reply #1100 on: May 03, 2020, 02:19:29 pm »
Tau is currently the best shot at getting an actual usable manual from them and correcting their mistake less one of them just happens to see this instead i'd think or anyone else with direct contacts
Maybe not, SolderingIron already has this under control apparently however a fix date is unknown yet....it's still the weekend after all !
Avid Rabid Hobbyist
Offline Svrbinek
« Reply #1101 on: May 03, 2020, 04:47:32 pm »
I am working on a new version of the manual, where it will be possible to search :-) I have already finished 20 pages. It's slow but it will work as if the original was like this from the beginning.
Offline Svrbinek
« Reply #1102 on: May 05, 2020, 09:15:30 pm »
Here is the new version of the search manual. If you come across any errors, write to me and correct me.
To download, you need to enter the password: Siglent
The best quality version is 160.5 MB
http://gofile.me/6pUlI/nr1whIQeC
Best quality version .zip 50.1MB
http://gofile.me/6pUlI/7fXa9Kcv3
Medium quality version 20.6MB
http://gofile.me/6pUlI/tYFo9pAph
Medium quality version .zip 11.5MB
http://gofile.me/6pUlI/betpf2iUm
Enjoy :-)
The following users thanked this post: rf-loop, KeBeNe, tautech, kado, tv84, Tom45, Gregg, Martin72, twizla, stafil
« Reply #1103 on: May 05, 2020, 09:54:06 pm »
Nice, thank you.  :)
Grabbed the full 160 MB version and searched for a few words and it seems to work great.  :clap:
No added credit to the manual in recognition for your good work ?  :-//
Avid Rabid Hobbyist
Offline Svrbinek
« Reply #1104 on: May 06, 2020, 06:42:23 pm »
Hi and thank you. I'm glad you like it and it works. I don't need any recognition there. You help others here too, and I could do this for everyone, because I'm not as good at electronics as you are. However, I am now working on translating the manual into Czech and 25% is done. It's very slow but thanks to that I will be able to study it :-)
Otherwise, someone mentioned that he discovered VNC. Yes, it is written about in the manual :-)
The following users thanked this post: Elasia, Martin72
Online Martin72
  • Testfield Technician
« Reply #1105 on: May 06, 2020, 07:58:57 pm »
I think, siglent should honour this, by at least make it official avaible, also the czech version, and by naming the author.
At least...
The following users thanked this post: Jacon
Offline Elasia
« Reply #1106 on: May 06, 2020, 09:02:44 pm »
At least...
IP rights.. same reason i wasnt going to stick my neck out for it, that opens up a host of copyright / infringement issues and legal exposure depending where you live
In the states most rights are use it or lose it forcing many companies to otherwise defend / go offensive even for good intent when it comes to their IP which has lead to many ridiculous outcomes; technically he is also now publishing it
Fantastic work though
Offline Frex
« Reply #1107 on: May 09, 2020, 07:26:16 am »
Hi all,
As others, a great thank you to Svrbinek for the "upgraded" manual. :-+
A pity that doesn't come from Siglent himself.
I played again with my "pimped" SDS2104X-Plus and have some bad things.
The internal generator is very limited, it include several build in waveforms,
but no way have modulated waveforms available... :--
I have also experienced an issue, when I saved a waveform on USB key,
the previous recorded waveform was overwritten by the new !
Anyway,  without understand why and just after seeing options in some menus,
 that seem work now and each new saved file have a new name ( xxx_01.png ,xxx_02.png , xxx_03.png, etc....).
To follow near... :-\
I Played also a lot with the Bode plot and I found an unexpected behavior that occur at low frequency (10Hz-10kHz range).
Sometimes there is a wrong measurement and spikes appears on Bode plot result.
You can show below an example :
This of course not come from my setup, i checked twice.
There is even no DUT, Generator output is sent to both scope inputs that made Vout/Vin, so we expect flat response.
AS you can see, there is a fault spike. There is no noise source source around me.
I have also a complain about the bode plot, i really don't understand why the frequency range is limited to 10Hz.  ???
The generator itself can go to much lower frequencies...
I think the Siglent algorithm to make the Bode plot measurement is not very well optimized,
Bode plot take lot of time (If i compare for example with Analog-Discovery).
So nothing unacceptable, but Siglent have room to work on a new improved firmware.. :-/O
Frex
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #1108 on: May 09, 2020, 07:36:33 am »
The lower frequency limit is due to channel AC coupling. I didn't check yet whether this can be changed.
« Reply #1109 on: May 09, 2020, 07:41:39 am »
This has been discussed earlier and there might be chance for small improvement however as the channel inputs are AC coupled when in Bode plot, performance at low frequencies is dominated by the input's AC response.
Lowering the Points will increase Bode plot speed.
It's about speed vs accuracy. Pick your poison.  ;)
Yep, this.  :-+
Avid Rabid Hobbyist
Offline thinkfat
« Reply #1110 on: May 09, 2020, 08:15:24 am »
Siglent could implement a calibration mode, like you'd do with a network analyser.
Online Martin72
« Reply #1111 on: May 09, 2020, 09:37:56 am »
Was already reported here.
In this thread, the awg´s missing features could be reported too.
Offline Frex
« Reply #1112 on: May 09, 2020, 09:57:27 am »
Ok, I will do this.
Anyway, the big concern is most the wrong spikes occuring when Bode plotting.
Frex
Online DL2XY
« Reply #1113 on: May 09, 2020, 04:36:09 pm »
I can not reproduce wrong measurements nor spikes.
Offline Frex
« Reply #1114 on: May 10, 2020, 11:17:59 am »
Hello DL2XY,
The wrong measurements points doesn't always appear,
but it seem that it's related to sweep number of point.
With 100 points and 25 points I don't have seen the issue,
 but this morning with 50 points I experienced three time in a row the issue.
I posted also the config page if you want to try using same setup.
Frex
Online DL2XY
« Reply #1115 on: May 10, 2020, 02:42:00 pm »
Hello Frex,
Tryed again by succesively adopting your settings:
1. used 50 points - ok
2. used Auto Gain - ok
3. reversed CH1/Ch2 - bingo... :--
After this Failure every saved screenshot is numbered "_1"  ?!
Walter
« Last Edit: May 10, 2020, 02:47:14 pm by DL2XY »
« Reply #1116 on: May 11, 2020, 07:59:05 am »
Note from Siglent:
SIGLENT have addressed the SDS2000X Plus User manual to allow it to be searched.
The new version is UM0102XP-E01B and you can download it here:
https://siglentna.com/wp-content/uploads/dlm_uploads/2020/01/SDS2000X_Plus_UserManual_UM0102XP-E01B.pdf
Avid Rabid Hobbyist
The following users thanked this post: Tom45, 2N3055, Elasia
Offline Svrbinek
« Reply #1117 on: May 11, 2020, 03:52:27 pm »
So I managed to finish the manual in the Czech language. Complete editing, graphic editing and indexing was necessary :-) But it looks better than the original in English, where there are quite a few errors. It was difficult :-)
Offline Svrbinek
« Reply #1118 on: May 11, 2020, 03:56:56 pm »
Note from Siglent:
Hi, the manual that is now with the search is from page 18-25 in French. Well, if Siglent and Oscilloscopes do this, then good things are not waiting for us in the future :-D
« Last Edit: May 11, 2020, 04:09:50 pm by Svrbinek »
Offline tv84
  • Country: pt
« Reply #1119 on: May 11, 2020, 04:07:19 pm »
Hi, the manual that is now with the search is from page 18 in French.
 :-DD  (nobody said it should be searchable in english!)
Online 2N3055
  • Country: hr
« Reply #1120 on: May 11, 2020, 04:23:19 pm »
Note from Siglent:
LOL it's not. It is manual for North America, that includes Canada. It is customary to provide "Exigence de Sécurité ", General Safety Summary  in French in manual... It is in English. allright...
Offline Elasia
« Reply #1121 on: May 11, 2020, 05:21:23 pm »
Where is the spanish warnings? It's clearly racist....  :horse:  :box:
On another note... I've left my unit hooked up to my SDG2000X via LAN and it has yet to do the same fault shown as others on the bode, would appear limited to the internal AWG?
Online 2N3055
  • Country: hr
« Reply #1122 on: May 11, 2020, 05:44:21 pm »
Mais pas au Canada... :-DD
Offline Elasia
« Reply #1123 on: May 11, 2020, 05:59:36 pm »
Nope... i finally got one on an external arb too
Offline Elasia
« Reply #1124 on: May 11, 2020, 08:12:27 pm »
Doesnt seem to matter on number of points.. just randomly does it
