Author Topic: Siglent SDS2000X Plus Hack  (Read 161856 times)
Offline tv84
  • Country: pt
Re: Siglent SDS2000X Plus Hack
« Reply #250 on: April 23, 2022, 06:23:24 pm »
I can confirm that the hack works flawlessly with the latest version ( 1.3.9R10 )  :-+
What is your SCPI answer to?
:syst:board?
Offline ozkarah
  • Country: tr
« Reply #251 on: April 23, 2022, 07:24:57 pm »
:syst:board?
600bps_LIC-V1
Is it same with previous batches?
Offline tv84
  • Country: pt
« Reply #252 on: April 23, 2022, 07:46:23 pm »
600bps_LIC-V1
Correct. LIC-V1 means that you have the "classic" option licenses version.
Offline Martin72
  • Testfield Technician
« Reply #253 on: April 23, 2022, 08:03:29 pm »
600bps_LIC-V1
After complete hacking, including bandwith to 500Mhz ?
Offline tv84
  • Country: pt
« Reply #254 on: April 23, 2022, 08:32:52 pm »
600bps_LIC-V1
I think so because, as I've shown you, Siglent didn't code the thing correctly OR didn't expect anyone with a SDS2k+ to issue the command. So the FW is not prepared with the 2k+ designation for 500MHz.
« Last Edit: April 24, 2022, 08:17:34 am by tv84 »
Offline Martin72
« Reply #255 on: April 23, 2022, 10:14:14 pm »
OK, I thought it was because of the missing bandwith upgrade.
Offline tv84
  • Country: pt
« Reply #256 on: April 24, 2022, 08:17:09 am »
 :palm: And you thought well. I wrote from memory and was wrong... Let's see if ozkarah has upgraded to 500M and if his response was after upgrade.
Offline ozkarah
  • Country: tr
« Reply #257 on: April 24, 2022, 10:36:37 am »
Yes, I did the bw update in 200->350-->500 MHz order. And the response was after the update?
Could you pls explain what is wrong with the response ?
Offline Martin72
« Reply #258 on: April 24, 2022, 11:23:53 am »
Maybe nothing, I got the response "4CH_500M" from my scope at home, one of the first sds2k+ and completely hacked.
Then I did the SCPI request on one of our brandnew 100Mhz SDS2k+ at work with no hack at all and get the same response like you got.
But that´s tv84´s playground, he will knows it better.
« Last Edit: April 24, 2022, 11:25:41 am by Martin72 »
Offline ozkarah
  • Country: tr
« Reply #259 on: April 24, 2022, 01:18:15 pm »
Did you do the bw hack using the keygen or removing the bandwidth file?
And  FYI: scope model is shown as SDS2504X Plus after the hack.
Offline Martin72
« Reply #260 on: April 24, 2022, 01:36:33 pm »
It was "so long" time ago, I don´t know it anymore... ;)
But it wasn´t with the license generator, except the (later added)Manchester and Sent decoding options I´ve used the known gen for.
Offline ozkarah
  • Country: tr
« Reply #261 on: April 24, 2022, 03:12:17 pm »
That might be the cause of the difference.
I used the keygen for all. And I did the bandwidth upgrade following the 100->200->350->500 MHz path with rebooting after each.
Offline tv84
  • Country: pt
« Reply #262 on: April 24, 2022, 03:37:23 pm »
Your SCPI response was obtained after you do the BW licensing up to 500MHz?
Offline ozkarah
  • Country: tr
« Reply #263 on: April 24, 2022, 04:45:22 pm »
Yes
Online MathWizard
« Reply #264 on: May 01, 2022, 10:55:20 pm »
Hopefully next year I'll get a 2104Xplus, and if I can still upgrade it (for free), it should be the best scope for the money, I can get, and it should last me for years, as long as the chips last.
Offline jscm2000
  • Country: cn
« Reply #265 on: June 09, 2022, 04:57:27 am »
I just bought the SDS2074X+, the Chinese market is $930, the crack is still valid, the latest firmware version 1.3.9R12
« Last Edit: June 09, 2022, 05:03:04 am by jscm2000 »
Offline Helix70
  • VK4JNA
« Reply #266 on: June 17, 2022, 12:07:05 pm »
I just upgraded to R12 firmware, but when I connect via SCPI and issue :syst:board? my scope locks up, TCP/IP connection is lost, UI frozen and needs a hard power off to restart.
*IDN? works fine, gives Siglent Technologies,SDS2504X Plus,SDS2PDDQ5R2444,5.0.1.3.9R12.
Any thoughts? I am using Keysight Interactive IO for the SCPI commands.
Offline ozkarah
  • Country: tr
« Reply #267 on: June 17, 2022, 03:06:00 pm »
I have the same scope and FW. I get response on both commands without any lock up.
*IDN?:
Siglent Technologies,SDS2504X Plus,SDS2PEEC6Rxxx5,5.3.1.3.9R12
:syst:board?:
600bps_LIC-V1
1- Try using SCPI control interface of scope's web interface.
2- My device's hw version is 04-05 (new hw revision of Siglent) Please check if it is same with yours.
3- You can compare other system information :
  •   Uboot OS Version: 5.3
  •   FPGA Verison: 2022-02-08
  •   CPLD Version: 05
4- In the Utility Menu, "Tek Mode" is off. Please check yours.
« Last Edit: June 17, 2022, 03:42:08 pm by ozkarah »
Offline tubularnut
« Reply #268 on: June 17, 2022, 07:39:36 pm »
*IDN?:
:syst:board?:
600bps_LIC-V1
  •   CPLD Version: 05
Mine also locks up. Has done since the command was first published and I was on R6, now on R12
TEK mode off. Command sent through scope web interface.
  •   Uboot OS Version: 5.0
  •   FPGA Verison: 2021-07-16
  •   CPLD Version: 03
  •   HW: 02-04
« Last Edit: June 17, 2022, 07:41:22 pm by tubularnut »
Offline Martin72
« Reply #269 on: June 17, 2022, 07:54:58 pm »
Hmm.....
The new owner of my sds2k+ reported me, he had a freeze while booting - This I´ve never got before in the 2.5yrs of using the scope.
One of the last things I´ve done was to upgrade the firmware from R6 to R12....
Maybe that was not a good idea.
Offline tv84
  • Country: pt
« Reply #270 on: June 17, 2022, 08:49:21 pm »
It should be a bug but, just in case, I ask the guys with lock ups to check the file NSP_system_info.xml and see if there is any reference to a "Dynamic Key"?
Offline Domitronic
« Reply #271 on: June 17, 2022, 09:14:53 pm »
Thanks to everyone who contributed to provide a keygen and also for foolproof instructions how to use it.
Also good to read the info about new firmware. Mine is still running 1.3.7R5 and i wanted to update soon. So reading the changelog the best option might be to update to 1.3.9R6 since the newer ones are mostly for compatibility with new hardware.
Offline Martin72
« Reply #272 on: June 17, 2022, 09:26:04 pm »
R6 is a "must" as the FFT bug was fixed with it, the other ones don´t have an effect when the scope got the "old" hardware (as far I could test it before selling my scope).
Offline tubularnut
« Reply #273 on: June 18, 2022, 06:48:25 am »
I’ve not had any lock ups on R12 (running for a few weeks now), and on the older hardware.
Only locks on running the :syst:board? command.
No Dynamic Key in NSP file.
Offline FlPr
  • Country: ru
« Reply #274 on: July 07, 2022, 08:57:53 am »
Hack works.
V1.3.9R12
:syst:board?
600bps_LIC-V1
The following users thanked this post: tom66
