Author Topic: Siglent SDS800X HD 12 bit DSO's  (Read 1229851 times)
0 Members and 39 Guests are viewing this topic.
Offline KungFuJosh
  • TEAS is real.
Re: Siglent SDS800X HD 12 bit DSO's
« Reply #750 on: March 08, 2024, 12:46:33 am »
You need therapy..
Absolutely. 8)
I saw your previous post saying you were resisting and immediately thought "that won't last long" 🤣🤣🤣
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
The following users thanked this post: Performa01, egonotto, tautech, Mortymore
Offline 2N3055
  • Country: hr
« Reply #751 on: March 08, 2024, 06:28:40 am »
"Resistance is futile. We are the scopes." :-DD
Dr. Richard W. Hamming
Online Martin72
« Reply #752 on: March 08, 2024, 10:22:43 am »
That was an attempt at self-suggestion that failed miserably...
The following users thanked this post: egonotto, KungFuJosh
Offline Bad_Driver
« Reply #753 on: March 08, 2024, 01:20:23 pm »
Performa01 has documented the capture rates of the 824 model in detail. The maximum of nearly 120k wfm/s is obtained at 50 ns/div time scale, 1000 pts/capture, and of course with the display in dot mode.
Now that my 814X HD has arrived, I tested the capture rate of the unmodified scope. And presto -- it reaches the very same 118.6k wfm/s! So Siglent is simply underselling the 814 (and presumably the 804) in the datasheet, maybe to create an additional differentiation for the top-of-the-range model?
Anyway, it seems that an "improved" 804 or 814 model will reach the same performance as the 824 in every respect.
I promised to repeat this with my 804 (now 824):
Max capture rate vector mode 31.6 k, dot mode 120.1 k
(If it walks like a duck …)
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
The following users thanked this post: egonotto, ebastler, Mortymore
Offline Bad_Driver
« Reply #754 on: March 08, 2024, 03:38:39 pm »
  • The included probes are so-so. I bought the 814 to give the 100 MHz probes away together with my old DS1000Z, and they are ok for that. But otherwise, if you are intending to hack the scope anyway, start with the 804 model and get some third-party probes for the money saved. E.g. the Testec passive probes are much nicer than Siglent's, for a comparable price: Separate LF and HF compensation capacitors; hook made from spring steel rather than stamped sheet metal; BNC adapter included; spare tip included; crocodile clip of the ground strap much easier to press since the isolation is not stupidly stiff.
I followed your advice and ordered 2 passive Testec MF-312 probes. They look promising!
― Albert Einstein
Offline capslock
« Reply #755 on: March 08, 2024, 05:50:16 pm »
@ Bad driver: meaning you "improved" it? or did you return your scope and buy a bigger one? What rate dig you get with your 804 (or when it was still an 804)?
Another question I wanted to ask: were there good Black Friday offers for Siglent last year or just for Rigol?
« Last Edit: March 08, 2024, 05:51:52 pm by capslock »
Offline Antonio90
« Reply #756 on: March 08, 2024, 05:55:48 pm »
Can't speak for the USA or Asia, but in Europe there was nothing for BF from Siglent.
Offline egonotto
« Reply #757 on: March 08, 2024, 06:05:28 pm »
After 3 months of intensive testing, I sold it again.
I still think it's good, but no longer for the money, as something clearly better has come onto the market.
I was actually tempted to buy an 804 because I like to experience things for myself.
Otherwise I can borrow scopes from work, but I don't have an "emergency" at home at the moment.
Hello,
The great German philosopher Loriot once said that life without an oscilloscope is possible, but very sad.
Best regards
egonotto
The following users thanked this post: Performa01, tautech, pdenisowski, core
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #758 on: March 08, 2024, 06:09:49 pm »
 :-DD
Das Bild(schirm) hängt schief!
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline tszaboo
« Reply #759 on: March 08, 2024, 06:19:57 pm »
We usually get 15% off from stuff that you would never buy for black friday. Like from the 500 EUR Phillips slow cooker.
Oh what the heck, I've bought one now, you can get rid of it quite easily if.
:clap:
Be prepared to be impressed to what has been crammed into these little DSO's.  :)
Any suggestions what to test thats missing from a MSOX3104, what I used at my different jobs for the past 14 years or so?
Online Martin72
« Reply #760 on: March 08, 2024, 06:20:28 pm »
Little OT:
The following users thanked this post: Performa01, egonotto, pdenisowski, Bad_Driver
Offline pdenisowski
« Reply #761 on: March 08, 2024, 07:02:20 pm »
The great German philosopher Loriot ....
Or in the case of the Siglent SDS800X :  Der Funktionsgenerator bleibt draußen!
The following users thanked this post: egonotto, Martin72, Bad_Driver
Offline Bad_Driver
« Reply #762 on: March 08, 2024, 07:13:25 pm »
I checked only the bandwidth during the „improvement“ process, not the capture rate.
The label on the top and the invoice say, it‘s a 804, the system info says now 824  ^-^
― Albert Einstein
Offline tautechTopic starter
« Reply #763 on: March 08, 2024, 07:28:15 pm »
:clap:
Start with a whole order of magnitude more memory depth and work from there.
Avid Rabid Hobbyist
Online Martin72
« Reply #764 on: March 08, 2024, 09:40:10 pm »
Welectron actually has the 804X HD in stock, as I received an email confirming shipment this afternoon.
As I never have luck with DHL on Saturdays, I assume it will arrive on Monday. ;)
The SDS1104X-E is already back here.
The following users thanked this post: egonotto, ebastler, KungFuJosh
Offline egonotto
« Reply #765 on: March 08, 2024, 11:04:28 pm »
Hello,
then have fun with the new device. But from Friday afternoon to Saturday would be very quick.
Best regards
egonotto
Online Martin72
« Reply #766 on: March 08, 2024, 11:16:22 pm »
Hi egonotto,
I´ll have fun with it..
When the SDS3034X HD arrives, the 804X HD will probably sold again, I wouldn't know what else to do with it.
Until then, I will take measurements and present them here, different situations, sometimes with and sometimes without the demo board.
Noise test with microphone too, bandwidth measurements, staggered according to original, 100Mhz, 200Mhz.
Then see if the upgrade to the 824 really means 100Mpts memory, stuff like that.
I like to try out scopes myself instead of watching videos or reading threads and the price makes it easy to realize this.
I have no doubt that I'll get rid of it quickly when the time comes.
The following users thanked this post: egonotto, core, Bad_Driver
Offline RAPo
« Reply #767 on: March 09, 2024, 11:55:12 am »
My reseller says it takes more than a month before the *licence* for the LA probe is in stock. How can that be?
Online Martin72
« Reply #768 on: March 09, 2024, 12:10:01 pm »
Everything is possible at Siglent.eu... :-X
No, fun. ;)
If it's only about the license key, that can't be right, it's never "in stock" because it's virtual.
Normally you buy the key, give the serial number of the scope and then it can only be a matter of days after the purchase until you receive the appropriate key by email.
Online Martin72
« Reply #769 on: March 09, 2024, 01:05:19 pm »
A beautiful mistake.... ;)
I don't know what deal welectron has with DHL, but the delivery time from warehouse to home is rarely over 36h.... madness. :scared:
Actually 70Mhz probes included, actually clever.
A set of new probes costs more than buying the larger model.
Unless, like me, you have others at home anyway, then the idea behind it has become obsolete.
So, let the scope acclimatize first.... 8)
« Last Edit: March 09, 2024, 01:09:12 pm by Martin72 »
The following users thanked this post: Performa01, egonotto, Mortymore, KungFuJosh
Offline Bad_Driver
« Reply #770 on: March 09, 2024, 01:20:45 pm »
It is a beautiful little black beast, isn‘t it?
― Albert Einstein
Online Martin72
« Reply #771 on: March 09, 2024, 01:21:59 pm »
I could get used to the color, so yes. ;)
Online Martin72
« Reply #772 on: March 09, 2024, 01:39:52 pm »
Glare check...
Offline RAPo
« Reply #773 on: March 09, 2024, 01:41:46 pm »
This indeed is no fun. I've emailed Eleshop: deliver scope+probe now
Online Martin72
« Reply #774 on: March 09, 2024, 02:10:10 pm »
 :scared:
How does it work....
That's nothing more than operating a key generator, or do they work it out at Siglent with a slide rule....
