So, basically, the language menu is as attached.
Copying the original config back to both locations brought the model number back and forced Chinese language.
That is great news!
Later, I'll share a few more .CFG to see their behavior.
Test this one, please.
No change, still model SDS1202F+ and forced Chinese language.
Don't worry... Tv84 will eventually sort it out for you.
Hi, I just ordered an SDS1072CML +. Will anyone still have information on how to convert it to SDS1152CML +.
Could you please kindly send me a PM how you did it.
Thank you in advance.
SDS1072CML+ with FW version 6.01.01.21R2 confirmed, works like a treat.
Is anybody has problems with file coding then use file from " Reply #80".
Lama12, użyj załączonego pliczku, jak sam robiłem plik to nie działało. Telnet na porcie 23.
I know it's been a while, but can I ask what SCPI command was executed, to get the 1152 from the 1052?
Thanks
It's the usual command to change BW:
MCBD <BW_lic>
Wondering if someone have experience hacking SDS1102X+ oscilloscopes. All backdoors are closed to read memdump. Scope has ID xxxx.yyyy.zzzz so missing last 4 numbers. Tried some code calculators from forum which give some unlock codes with only 12 digits input but none of them work.
Some way to read memdump with disassembly? Other ideas?
sorry to kick this thread alive again..
but I find no other threads about SDS1102CML hack
new trick : i was not able to connect via putty, correct ip number, tribble checked it was corrent,
none of the mentionened ports, SSH or telnet, no way. also checked with nmap where they could be..
The solution : get siglent software EasyScopeX
this will connect to the scope just fine,
its command interface also accept the hack code, and you can up the bandwidth that way
I can connect to my SDS1102CML+ on the LAN with EasyScopeX, and ping it, but can not Telnet to it even after rebooting with startup.sh on the USB drive, or bring up the IP address in a browser.
The firmware version is 6.01.01.22, the 8/6/21 update.
Any suggestions?
Hello
I need help.
My device 2190e (sds1152cml+) was fully erased.
Attention !!! Don't run "run mmc-all" from uboot. This command contains "run chip.erase"!!! This will fully erase nand .
Factory partitions with calibration data was erased too.
Who can share partitions from working device.
For now the device is not usable.
Thank you for help.
