In the attachments I am probing a signal that toggles from 80V to 0V @ 2MHz, I replicated the scenario with a power supply and am unable to replicate the same behavior, well I can't toggle the power supply at 2MHz.
I applied 80V at 1V/div and I can bring down the offset to -79V and the signal appears at the right place, I also toggled the supply low and captured the falling edge the behavior is correct (no apparent offset), repeated with 5V/div as well and it appears correct as well.
