Just picked up an old HP 5006A from ebay.
It's clearly built down to a price: cheezy plastic case, sheet metal insert "nuts" for some of the machine screws, no connectors for the probes (they're hard wired). Not at all up to the usual HP test equipment quality I expect from that era. But whatever, it's not something I'm going to use every day and it gets the job done.
I got a very clean unit, but of the 11 buttons on the front panel, not a single one of them worked except the power button. Not even intermittently after a bunch of cycling. The unit responded to GPIB so I was sure it was something with the keyboard driver.
Not the case. After a 20 minute session with a can of contact cleaner, I eventually got them all working again. I guess this unit didn't see much action, certainly lately.
I do like the self test feature where you can plug all the probes into the front panel. It automatically detects you're doing it and let's you know if everything passed or what's failing.
It has a service manual available for it and if you need to fix it, you need... A signature analyzer!
Anyone interested in reading more than you probably want to know about this old debugging technology can look here:
www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1977-05.pdf
