tautech, Thanks for the images,
Basically, I think you are saying to set display at a slow sweep rate, use History to find your frame of interest, then change to a higher sweep rate and use Navigate to play the frame as needed.
Okay, that is what I've been doing and I can get what I want eventually.
The key is to record at very slow sweep rate relative to the signal. Which is not normally how I like to use my scope. So a recapture is usually required.
For what it's worth (I'm a newbie to digital scopes), it seems to me the people here who say this is a problem have a point. The ability to zoom out, as Dave said in the video, seems like a good fix.
Thanks to all for the comments.
Frank
P.S. I managed to use zooming, but I'm not sure it's any better.
