Author Topic: Sniffing the Rigol's internal I2C bus  (Read 2305157 times)
0 Members and 134 Guests are viewing this topic.
Offline ted572
  • Radio Communications Equipment/System Design Engr.
Re: Sniffing the Rigol's internal I2C bus
« Reply #4350 on: May 13, 2017, 02:13:48 pm »
DSA800 Boot Loader:    It is customary for electronic equipment manufacturers to store their Boot Loader in ROM, EROM, ERAM, etc;  in a form of Protected Memory.  Not necessarily to prevent hacking, but to safe guard it from corruption.  Because once corrupted (and it has to be retained for the Life Of The Equipment) the unit is dead in its tracks, and re-installation of firmware isn’t generally possible.  So then,  >  Back To The Factory.  That’s why I said the changing the firmware will probably be tricky.  The task of the Boot Loader is primarily to just boot up the system firmware upon equipment power up, to check and control firmware updates, changes, and installation methods.  Not to prevent alterations of installed firmware.  The firmware, its checksum(s), etc, do that job.  So the Boot Loader doesn’t itself prevent someone from hacking the Rigol Options.
We know that the Rigol DP800 Series is an exception to using protected memory for the Boot Loader.  Because Rigol provided a new Boot Loader along with at least one of its firmware updates.
Hopefully someone can figure out how to go back to a earlier Boot Loader in the DSA815.  Although if its protected, and very likely it is, especially in the newer hardware Main Boards, then it may not be easy at all.  It would have been very easy for Rigol to add a Boot ROM in the newer boards (v. 7 and above), and then it would be much more difficult to change, But Not Impossible.
Offline smgvbest
    • Kilbourne Astronomics
« Reply #4351 on: May 13, 2017, 03:37:22 pm »
granted, however the DSA815 support boot from USB and the blackfin supports uart boot.  so if we have the boot code in LDR format and put that on a USB drive or load via uart to get 1.03 in then could we not backload FW1.0x then?
Sandra
(Yes, I am a Woman :p )
Offline ted572
« Reply #4352 on: May 13, 2017, 09:13:28 pm »
Hi Sandra:  The Blackfin's interface capability can be limited/overridden by the instructions from the Boot Loader. Or purposely left out by the hardware designer for expediency because it wasn't required for the task.  I think that the current .04 Boot Loader most likely preempts doing this, so I think someone will have to directly force a .03 Boot Loader (or equivalent) in place of the .04.
I don't have any vested interest here, because I have the original hardware with all of the permanent Options (so far anyway).  If I had the newer unit I would be charging into this relentlessly with a DSA815 open on my bench, to try to at least understand high level system architecture used.  I did this for my units Front End, LOs, Mixers, and IFs through to the DSP.  https://www.eevblog.com/forum/testgear/spectrum-analyzer-rigol-dsa815/msg1059060/#msg1059060
You may want to consider sketching out your units digital control logic surrounding the firmware and its management.  This should help shed more light on all this.  I believe that all of the involved ICs have vendor P/Ns, and a few may have SMT Codes.  Doing this with Peter's info may help pull it together.
EOT and Cheers, Ted
Edit:  I think that this discussion should moved back here ->  'Re: Spectrum Analyzer - Rigol DSA815'  to get all the interested and knowledgeable parties in this matter involved.
Please go to  'Re: Spectrum Analyzer - Rigol DSA815'  to follow this subject:  https://www.eevblog.com/forum/testgear/spectrum-analyzer-rigol-dsa815/msg1207904/#msg1207904
« Last Edit: May 13, 2017, 11:27:18 pm by ted572 »
Offline cybernet
  • pm deactivated, use the search function ...
« Reply #4353 on: May 17, 2017, 09:41:46 pm »
some ppl asked for it, finally found that stuff again:
DS2000 stuff:
IDA Pro Signatures: http://www.filedropper.com/showdownload.php/ds2000cybernet23072013
LDR Tool: http://www.filedropper.com/geltoolsrctar
Custom LDR binary: http://www.filedropper.com/rigolds2000customlcdtar
UBOOT Custom: http://www.filedropper.com/uboot-201404ds2000tar
DG4000 stuff:
Firmwares, CEN, IDB files: http://www.filedropper.com/dg4000tar_1
DS815 stuff:
DSA815 Dump + IDA: http://www.filedropper.com/dsa815
have fun
« Last Edit: May 19, 2017, 12:47:31 am by cybernet »
___________________
"all rights reversed :-)"
R0=-0x18;
UNLINK;
RTS;
The following users thanked this post: robots, ironcurtain
Online RoGeorge
« Reply #4354 on: May 18, 2017, 06:37:59 am »
DG4000 stuff:
Thank you, but this download didn't worked for me. I tried with 2 different computers, and they both say "unexpected end of archive", "file is broken".
Could you check, please?
Offline cybernet
« Reply #4355 on: May 19, 2017, 12:47:52 am »
reup'ed and updated the link, try that one.
___________________
R0=-0x18;
UNLINK;
RTS;
Online RoGeorge
« Reply #4356 on: May 19, 2017, 07:52:34 am »
Thank you for re-uploading, but still not working for me.
In Win10 the 7zip gives "unexpected end of archive" then hang.
In Debian 8, the same:
rogeorge@debian80:~$ cd Downloads/
rogeorge@debian80:~/Downloads$ gunzip -t DG4000.tar.gz
gzip: DG4000.tar.gz: not in gzip format
rogeorge@debian80:~/Downloads$ tar -xvzf DG4000.tar.gz -O > /dev/null
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
rogeorge@debian80:~/Downloads$ md5sum DG4000.tar.gz
74fa6a60981025eee721ae1bc76d8054  DG4000.tar.gz
rogeorge@debian80:~/Downloads$ sha1sum DG4000.tar.gz
30aa545b6339e51e03db70b29b91ada9dea60cf1  DG4000.tar.gz
rogeorge@debian80:~/Downloads$ file DG4000.tar.gz
DG4000.tar.gz: POSIX tar archive (GNU)
rogeorge@debian80:~/Downloads$ cp DG4000.tar.gz DG4000.tar
rogeorge@debian80:~/Downloads$ tar xvf DG4000.tar
DG4000/
DG4000/license_gen/
DG4000/license_gen/cengen
DG4000/license_gen/cengen.zip
DG4000/license_gen/cengen.c
DG4000/license_gen/license.zip
DG4000/license_gen/.DS_Store
DG4000/license_gen/build.sh
DG4000/license_gen/license.CEN
DG4000/license_gen/diff
DG4000/license_gen/._.DS_Store
DG4000/license_gen/work1/
DG4000/license_gen/work1/main.c
DG4000/license_gen/ix
DG4000/lxi_test/
DG4000/lxi_test/dbgcmd.bin
DG4000/lxi_test/._dbgcmd.bin
DG4000/lxi_test/my_lxi_command.bin
DG4000/mem_dump/
DG4000/mem_dump/dg4000_async0.bin
DG4000/mem_dump/._dg4000_lo1.bin
DG4000/mem_dump/dg4000_memdump.tar.gz
DG4000/mem_dump/dg4000_scratch.bin
DG4000/mem_dump/ivt.bin
DG4000/mem_dump/dg4000_data_a.bin
DG4000/mem_dump/kkkkk.bin
DG4000/mem_dump/dg4000_lo1.bin
tar: Unexpected EOF in archive
tar: rmtlseek not stopped at a record boundary
rogeorge@debian80:~/Downloads$ gunzip DG4000.tar.gz
gzip: DG4000.tar: unknown suffix -- ignored
Do you have the same md5 or sha1 checksum on your PC, please?
Am I doing something wrong?
Offline McBryce
« Reply #4357 on: May 19, 2017, 08:02:18 am »
I tried downloading it (windows 7). I get the same "unexpected end of archive", but it still allows me to extract all the files and they seem to be ok.
McBryce.
Offline cybernet
« Reply #4358 on: May 19, 2017, 11:49:25 pm »
ea51691d00365fe47bc3cf081667c47f8699526d  DG4000.tar.gz
gzip -dc DG4000.tar.gz |tar -vxf -
DG4000/
DG4000/license_gen/
DG4000/lxi_test/
DG4000/mem_dump/
DG4000/mem_dump/dg4062.idb
DG4000/mem_dump/dg4000_async2.bin
DG4000/mem_dump/dg4062.map
DG4000/mem_dump/dg4000_data_b.bin
DG4000/mem_dump/iar
DG4000/mem_dump/dg4000_async1.bin
DG4000/mem_dump/secure_code.txt
DG4000/mem_dump/dg4000_sysmmr.bin
DG4000/mem_dump/dg4000_inst_ab.bin
DG4000/mem_dump/dg4000_inst_c.bin
DG4000/mem_dump/license.CEN
DG4000/mem_dump/dg4000_async3.bin
DG4000/mem_dump/dg4000_coremmr.bin
DG4000/mem_dump/facts.txt
DG4000/mem_dump/aaaaa.bin
DG4000/mem_dump/dg4062.rar
DG4000/dumpeth.txt
DG4000/model_sub/
DG4000/model_sub/dg4162.asm
DG4000/model_sub/dg4102.clean
DG4000/model_sub/dg4102.asm
DG4000/model_sub/dg4162.clean
DG4000/.DS_Store
DG4000/._DG4000Update.GEL
DG4000/FW0.7/
DG4000/FW0.7/._DG4000Update.GEL
DG4000/FW0.7/DG4000Update.GEL-FW0.7.zip
DG4000/gelfile/
DG4000/gelfile/dump_20400000.bin
DG4000/gelfile/dump_20470000.bin
DG4000/gelfile/dump_20300000.bin
DG4000/gelfile/crc_table.h
DG4000/gelfile/dump_2046fc00.bin
DG4000/gelfile/dump_209b0000.bin
DG4000/gelfile/dump_20440000.bin
DG4000/gelfile/dump_20440400.bin
DG4000/gelfile/dump_20460000.bin
DG4000/gelfile/dump_20460400.bin
DG4000/gelfile/dump_20db0000.bin
DG4000/gelfile/dump_20830000.bin
DG4000/gelfile/dump_205b0000.bin
DG4000/gelfile/dump_20040000.bin
DG4000/gelfile/dump_20443800.bin
DG4000/gelfile/gelfile.c
DG4000/gelfile/build.sh
DG4000/gelfile/dump_20443400.bin
DG4000/gelfile/dump_20bb0000.bin
DG4000/gelfile/DG4000Update.GEL
DG4000/gelfile/dump_207b0000.bin
DG4000/license.CEN
DG4000/lxi.py
DG4000/test.RAF
DG4000/bootld/
DG4000/bootld/dg4062_boot_async3.bin
DG4000/bootld/dg4062_boot_ram.bin
DG4000/bootld/dg4062_boot_async2.bin
DG4000/bootld/dg4062_boot_srama.bin
DG4000/bootld/dg4062_boot_smmr.bin
DG4000/bootld/dump.txt
DG4000/bootld/dg4062_boot_cmmr.bin
DG4000/bootld/dg4062_boot_ram.idb
DG4000/bootld/dg4062_boot_dump.zip
DG4000/bootld/dg4062_boot_instab.bin
DG4000/bootld/dg4062_boot_instc.bin
DG4000/bootld/dg4062_boot_async1.bin
DG4000/bootld/dg4062_boot_async0.bin
DG4000/bootld/dg4062_boot_sramb.bin
DG4000/addr_0.3.txt
DG4000/._.DS_Store
DG4000/newoffset
DG4000/._license.CEN
DG4000/DG4000Update.GEL
DG4000/FW0.6/
DG4000/FW0.6/DG4000Update.GEL-FW0.6.zip
DG4000/FW0.6/._DG4000Update.GEL
DG4000/test.ldr
___________________
R0=-0x18;
UNLINK;
RTS;
The following users thanked this post: wp_wp
Online RoGeorge
« Reply #4359 on: May 20, 2017, 05:42:27 am »
My download doesn't have the same checksum as your file. I tried also resetting my router, getting a new IP, fire up a clean Debian VMware machine, download without any addblockers, and I still get the same wrong checksum:
Thank you for your patience cybernet, but please don't waste any more time with this. I give up.
I guess something is wrong with that file sharing site.
Offline neslekkim
  • Country: no
« Reply #4360 on: May 21, 2017, 12:25:35 pm »
DG4000 stuff:
Same for me, this file is corrupt.
DG4000 stuff:
And this one doesn't even start to download on chrome, but with IE I got an corrupt file, smaller than from the previous link.
Offline PA0PBZ
« Reply #4361 on: May 21, 2017, 01:05:12 pm »
Same here, 153MB first file, 113MB the second one.
Also, if I can trust the catalog the contents of the mem_dump folder are different, the 2nd one has more bin files but the idb is missing.
Offline phy14
  • Country: cn
« Reply #4362 on: June 12, 2017, 06:05:23 pm »
thanks!! :)
Offline cybernet
___________________
R0=-0x18;
UNLINK;
RTS;
Offline psysc0rpi0n
  • Country: ar
« Reply #4364 on: July 08, 2017, 12:32:02 pm »
Guys, I can't find the link to generate Serial Keys for the MSO1074Z scope... That rigup tool online site!
Offline sokoloff
« Reply #4365 on: July 08, 2017, 01:07:18 pm »
google for "riglol" (yes, with the extra "l")
The following users thanked this post: psysc0rpi0n
Offline psysc0rpi0n
  • Country: ar
« Reply #4366 on: July 08, 2017, 01:29:07 pm »
I found the site. Thanks!
But where do I see my Private Key in order to be able to generate the keys?
Offline sokoloff
« Reply #4367 on: July 08, 2017, 02:27:46 pm »
The site generates the private key. You enter your serial number and the 4 alpha code of the options you want to enable and you get a private key out. (Yeah, the web UI makes it look like you need to enter something there. You don't.)
Also note: I found it way easier to hook the Rigol up to my network and telnet into it and do the upgrade via the command line (where I could easily copy/paste the serial number and the private key). When you do that, do not enter the dashes.
:SYST:OPT:INST <private key without dashes>
is the command you need.
Online ebastler
« Reply #4368 on: July 08, 2017, 02:32:01 pm »
Not sure whether you are "1337" enough for this...  ;)
Offline psysc0rpi0n
  • Country: ar
« Reply #4369 on: July 08, 2017, 06:49:28 pm »
What you mean?
I have already dumped my Rigol memory and generated the Serial Keys to my model. And I could not use that site because the tool was buggy and some member from here fixed that bug somehow and generated the keys to my model. But I'm helping a friend of mine has just bought an MSO1074Z.
Online ebastler
« Reply #4370 on: July 08, 2017, 07:54:38 pm »
What you mean?
Just kidding, since you asked several questions about the most simple step in this "hacking" process.
No offense was intended!
Offline psysc0rpi0n
  • Country: ar
« Reply #4371 on: July 14, 2017, 10:02:28 pm »
What you mean?
I couldn't even understood it so no offence could be taken! Just that I'm still in ignorance!  :-// ::)
Offline SkyMaster
« Reply #4372 on: July 14, 2017, 11:50:36 pm »
ebastler was pulling your leg when making reference to "1337"
https://en.wikipedia.org/wiki/Leet
He was not serious
Offline ivi_yak
« Reply #4373 on: July 27, 2017, 11:57:06 pm »
hi, what kind of software you use?
drivan
Offline LeoIt
« Reply #4374 on: August 20, 2017, 10:16:30 pm »
Hello everybody,
I have a question about DSA815....
I searched a lot in the forum to get information about the component U1220 it is a SOIC8 marked as MQD2C.... I didn't find what is it, somebody out there could help, it seems connected to the 4 pins strip near to the power supply connector, I suppose it it something controlled by TWI or SPI ?
May be it is a serial flash that contains some calibration or configuration data ?
Any help is much appreciated !
Many Thanks.
« Last Edit: August 20, 2017, 10:19:37 pm by LeoIt »
