Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1835566 times)
Offline true
  • INTERNET
Re: Sniffing the Rigol's internal I2C bus
« Reply #450 on: July 21, 2013, 02:56:19 am »
Requires mapping the signed key (serial+opts) to the Rigol license format. It looks like docmandu has done this. I'm working on it now; hopefully someone will paste working code before me. Why not help work on it? Shouldn't take too long.
alan2k: can you stop posting if you are just going to erase the posts?
Offline BravoV
  • +++ ATH1
« Reply #451 on: July 21, 2013, 03:03:36 am »
+1, its so fucking annoying to read thru those junks in this really great thread :-- , ignore list updated.
Offline DanielR
« Reply #452 on: July 21, 2013, 03:05:28 am »
Right, well I can certainly can help test with my scope if that helps. Ill keep an eye on this.
If there is some code to write I am pretty good in python, c not at all really.
Offline true
  • INTERNET
« Reply #453 on: July 21, 2013, 03:13:20 am »
Language doesn't matter
The only references I have is the rigol-to-hex mapping function in main.c, the valid character list, and some valid mapped keys as listed in this thread
edit: mostly done, I think I still have a bug, but I can't generate to test...same issue that I thought I read before (did alank2 delete it? he ruins the discussion), where seed does vary what I see in signed.ecs.
edit 2: don't know what I did while playing with it, now I can generate the sample listed here.
edit 3: hexkey to rigol key done. but ecsign still doesn't work for any other key/serial other than the demo posted earlier, with the seed posted earlier...
« Last Edit: July 21, 2013, 09:38:37 am by true »
Offline cybernet
  • pm deactivated, use the search function ...
« Reply #454 on: July 21, 2013, 10:07:38 am »
cool stuff, i have a tool that can generate key strings, will release shortly.
i must admit i got the private key yesterday via mail from a guy already, but my ecs tools where so heavily "recoded", the just outputted crap ;-)
should have something this night (GMT) ;-)
___________________
"all rights reversed :-)"
R0=-0x18;
UNLINK;
RTS;
Offline UberSteve
« Reply #455 on: July 21, 2013, 10:10:03 am »
Keeping a very close eye on this thread....very exciting! Great work guys!  :clap:  :-+
Offline true
  • INTERNET
« Reply #456 on: July 21, 2013, 10:15:11 am »
alright, I found the bug... still not sure what it is, something with how the file is edited... echo -n 'DS2A123456789XXXX' > lic works...
So now I can generate license code strings.
$ echo -n "DS2A123456873VSA9" > lic; echo -e "123879325\nlic\n" | ./ecsign | php gen.php; ./riglol `php gen.php`
MVVD4QW-CSSG5HS-GMAAMER-J3VS9L4 DS2A123456873
serial:           DS2A123456873
license-key:      MVVD4QWCSSG5HSGMAAMERJ3VS9L4
license-skipped:  MVD4QWCSG5HSGMAMERJ3VSL4 (5CC7A7505036CF032C0B23D199C15)
license-1-mapped: 5CC7A7505036CF
license-2-mapped: 32C0B23D199C15
license-options:  VSA9 (9C01)
serial&options:   DS2A123456873VSA9
sha1(serial&opts) D3B9717C00057C72EDFD409F62F2F10EE04135F2
v:    5CC7A7505036CF
lic1: 5CC7A7505036CF
 License Key is VALID
Questions for others investigating:
1. Is VSA9 the only code that should / can be used? Other codes don't seem to generate valid keys.
2. I generated a key for my scope that passed riglol, but it didn't work (License is unavailable! error) :( Should I try different seeds since the codes change?
« Last Edit: July 21, 2013, 10:17:16 am by true »
Offline cybernet
« Reply #457 on: July 21, 2013, 11:11:52 am »
enjoy ! - now i can finaly put by scope back together ;-)  :-+
UPDATE: for a DS2000 use DSA9 as option key !
** rigol ds2000 keygen / cybernet & the-eevblog-users
** to compile this you need MIRACL from [url]https://github.com/CertiVox/MIRACL[/url]
** download the master.zip into a new folder and run 'unzip -j -aa -L master.zip'
** then run 'bash linux' to build the miracle.a library
** BUILD WITH:
** gcc rikey.c -I../MIRACL ../MIRACL/miracl.a -o rikey
** adapt -I and path to miracl.a to your environment
** more info: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/
** then fetch private key from EEV Blog and put into "private_key[]=" below, do not prefix with 0x
** supply your serial and wanted options, and enjoy !
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <ctype.h>
#include <stdio.h>
#include "miracl.h"
#define RIGOL_DS2000
// START OF SETTINGS FOR ECC
#ifdef RIGOL_DS2000
 unsigned char private_key[]="8.....";   // <- RILOL FILL ME (no 0x prefix !)
 unsigned char prime1[]="AEBF94CEE3E707";
 unsigned char prime2[]="AEBF94D5C6AA71";
 unsigned char curve_a[]="2982";
 unsigned char curve_b[]="3408";
 unsigned char point1[]="7A3E808599A525";
 unsigned char point2[]="28BE7FAFD2A052";
#endif
// END OF SETTINGS FOR ECC
unsigned char codemap_ee00d0[]={ 0x0, 0x0, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f,
                                 0x0, 0x0, 0x0,  0x0,  0x0,  0x0,  0x0,  0x0,  0x1,  0x2,
                                 0x3, 0x4, 0x5,  0x6,  0x7,  0x0,  0x8,  0x9,  0xa,  0xb,
                                 0xc, 0x0, 0xd,  0xe,  0xf,  0x10, 0x11, 0x12, 0x13, 0x14,
                                 0x15,0x16, 0x17 };
unsigned char codemap_20688e[]={ 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30,  /* 0-9 = 0x30 */
                                 0x37, 0x37, 0x37, 0x37, 0x37, 0x37 };                        /* A-F = 0x37 */
unsigned char vb[]={'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'J', 'K', 'L', 'M', 'N', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '2', '3', '4', '5', '6', '7', '8', '9'};
void show_help(void)
 printf("./rikey <DSA2XXXXXXXXX> <OPTS>\n\n");
 printf("<DSA2XXXXXXXXX> -  serial number of device\n");
 printf("<OPTS> - \n");
 printf("\t\tDSA? for permanent options\n");
 printf("\t\tVSA? for temporary options\n");
 printf("\n\n");
** take serial and options make sha1 hash out of it
static void hashing(unsigned char *opt_str,big hash)
{ /* compute hash function */
    char *p;
    char h[20];
    int ch;
    sha sh;
    shs_init(&sh);
    p=opt_str;
    while(*p)
       shs_process(&sh,*p);
       p++;
    shs_hash(&sh,h);
    bytes_to_big(20,h,hash);
** sign the secret message (serial + opts) with the private key
int ecssign(unsigned char *serial, unsigned char *opt, unsigned char *lic1, unsigned char *lic2)
    FILE *fp;
    char ifname[50],ofname[50];
    big a,b,p,q,x,y,d,r,s,k,hash;
    epoint *g;
    long seed;
    int bits;
    miracl *mip;
    unsigned char *serial_options;
/* get public data */
    mip=mirsys(0x320, 0x10);   /* Use Hex internally */
    mip->IOBASE=16;
    a=mirvar(0);
    b=mirvar(0);
    p=mirvar(0);
    q=mirvar(0);
    x=mirvar(0);
    y=mirvar(0);
    d=mirvar(0);
    r=mirvar(0);
    s=mirvar(0);
    k=mirvar(0);
    hash=mirvar(0);
    instr(p,prime1);     /* modulus        */
    instr(a,curve_a);     /* curve parameters */
    instr(b,curve_b);
    instr(q,prime2);     /* order of (x,y) */
    instr(x,point1);     /* (x,y) point on curve of order q */
    instr(y,point2);
/* randomise */
    seed=1;
    irand(seed);
    ecurve_init(a,b,p,MR_PROJECTIVE);  /* initialise curve */
    g=epoint_init();
    if (!epoint_set(x,y,0,g)) /* initialise point of order q */
        printf("1. Problem - point (x,y) is not on the curve\n");
        exit(0);
/* calculate r - this can be done offline,
   and hence amortized to almost nothing   */
    bigrand(q,k);
    ecurve_mult(k,g,g);      /* see ebrick.c for method to speed this up */
    epoint_get(g,r,r);
    divide(r,q,q);
/* get private key of signer */
    instr(d, private_key);
/* calculate message digest */
    serial_options=calloc(128,1);
    strcpy(serial_options, serial);
    strcat(serial_options, opt);
    hashing(serial_options,hash);
/* calculate s */
    xgcd(k,q,k,k,k);
    mad(d,r,hash,q,q,s);
    mad(s,k,k,q,q,s);
    cotstr(r,lic1);
    cotstr(s,lic2);
    return 0;
** convert string to uppercase chars
unsigned char *strtoupper(unsigned char *str)
    unsigned char *newstr, *p;
    p = newstr = (unsigned char*) strdup((char*)str);
    while((*p++=toupper(*p)));
    return newstr;
unsigned char code_map_206846(unsigned char i)
 if ((i >= 'A') && (i <= 'F')) return(i-0x37);
 if ((i >= '0') && (i <= '9')) return(i-0x30);
 return(0x0);
** Encryption Routine 1
unsigned char *lic_code_map(unsigned char *lic_skipped)
 unsigned char lv1,lv2;
 unsigned char b1_mapped, b1_shifted, b1_remapped;
 unsigned char b2_mapped, b2_shifted, b2_remapped;
 unsigned char b3_mapped, b3_shifted, b3_remapped;
 unsigned char b4_mapped, b4_shifted, b4_remapped;
 unsigned char b5_shifted, b5_remapped;
 unsigned char *lic_mapbytes;
 lic_mapbytes=calloc(28, 1);
 if (!lic_mapbytes) return(0);
lv1=lv2=0;
 while(lv1 < strlen((unsigned char*)lic_skipped))
    b1_mapped =  codemap_ee00d0[ *(lic_skipped+lv1) - 0x30 ];
    b1_shifted = (b1_mapped / 2) & 0xf;
    b1_remapped = b1_shifted + codemap_20688e[b1_shifted];
    lic_mapbytes[lv2++]=b1_remapped;
    b1_mapped = b1_mapped & 0x1;
    b2_mapped =  codemap_ee00d0[ *(lic_skipped+lv1+1) - 0x30 ];
    b2_shifted =  ((b1_mapped << 0x3) | (b2_mapped / 4)) & 0xF;
    b2_remapped = b2_shifted + codemap_20688e[b2_shifted];
    lic_mapbytes[lv2++]=b2_remapped;
    b3_mapped = codemap_ee00d0[ *(lic_skipped+lv1+2) - 0x30 ];
    b3_shifted = ((b3_mapped / 8) | ( (b2_mapped & 0x3) << 2 )) & 0xF;
    b3_remapped = b3_shifted + codemap_20688e[b3_shifted];
    lic_mapbytes[lv2++]=b3_remapped;
    b4_mapped = codemap_ee00d0[ *(lic_skipped+lv1+3) - 0x30 ];
    b4_shifted = ((b4_mapped / 16 ) |((b3_mapped & 0x7) << 0x1)) & 0xf;
    b4_remapped = b4_shifted + codemap_20688e[b4_shifted];
    lic_mapbytes[lv2++]=b4_remapped;
    b5_shifted = b4_mapped & 0xF;
    b5_remapped = b5_shifted + codemap_20688e[b5_shifted];
    lic_mapbytes[lv2++]=b5_remapped;
    lv1 = lv1 + 4;
  return(lic_mapbytes);
unsigned char * find_match5(unsigned char *code5)
  unsigned char c1,c2,c3,c4;
  unsigned char *input;
  input=calloc(40,1);
  /* lets bruteforce it ;-) */
  for (c1=0;c1<sizeof(vb);c1++) {
   for (c2=0;c2<sizeof(vb);c2++) {
    for (c3=0;c3<sizeof(vb);c3++) {
     for (c4=0;c4<sizeof(vb);c4++) {
      input[0]=vb[c1];
      input[1]=vb[c2];
      input[2]=vb[c3];
      input[3]=vb[c4];
      input[4]='\0';
      lic_mapbytes=lic_code_map(input);
      if (!strcmp(lic_mapbytes, code5))
           return(input);
  return(0); // no match
int main(int argc, char *argv[0])
 unsigned char *options,*lic1_code, *lic2_code, *lic_all;
 unsigned char *out,*chunk,*temp,*final;
 unsigned char *lic1_key, *lic2_key;
 unsigned char *serial;
 int            v,i=0;
 if (strlen(private_key)<14)
  printf("\n\n");
  printf("set the private_key variable on top of this file\n");
  printf("you can find it here: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg264690/#msg264690\n");
  printf("\n\n");
  exit(-1);
 if (argc != 3)
  show_help();
  exit(-1);
 serial=strtoupper((unsigned char*)argv[1]);
 options=strtoupper((unsigned char*)argv[2]);
 if (strlen(serial)<13)
   printf("\nINVALID SERIAL LENGTH\n");
   show_help();
   exit(-1);
 if (strlen(options)!=4)
   printf("\nINVALID OPTIONS LENGTH\n");
   show_help();
   exit(-1);
printf("serial:           %s\n", serial);
 printf("options:          %s\n", options);
 /* sign the message */
 lic1_code=calloc(64,1);
 lic2_code=calloc(64,1);
 ecssign(serial,options,lic1_code, lic2_code);
 printf("lic1-code:        %s\n", lic1_code);
 printf("lic2-code:        %s\n", lic2_code);
 lic_all=calloc(128,1);
 temp=calloc(128,1);
 chunk=calloc(6,1);
 final=calloc(128,1);
 lic1_key=calloc(20,1);
 lic2_key=calloc(20,1);
 strcpy(lic_all, lic1_code);
 strcat(lic_all, "0");
 strcat(lic_all, lic2_code);
 printf("target-code:      %s\n", lic_all);
 // split in 5 byte groups and run bruteforce
 // run or lic1_code
 strcat(lic1_code,"0");
 while(i<=strlen(lic1_code))
   memcpy(chunk,lic1_code+i,5);
   out=find_match5(chunk);
   if (out)
    strcat(temp, out);
   i=i+5;
 strcpy(lic1_key, temp);
 // run for lic2_code
 strcpy(temp,"");
 i=0;
 while(i<strlen(lic2_code))
   memcpy(chunk,lic2_code+i,5);
   if (strlen(chunk)<5)
    for(v=0;v<5-strlen(chunk);v++)
     strcat(chunk,"0");
   if (out)
    strcat(temp, out);
   i=i+5;
strcpy(lic2_key, temp);
 strcpy(temp, lic1_key);
 strcat(temp, lic2_key);
 // now add the options
 memcpy(final, temp, 1);
 final[1]=options[0];
 memcpy(final+2, temp+1,7);
 final[9]=options[1];
 memcpy(final+10, temp+8,7);
 final[17]=options[2];
 memcpy(final+18, temp+15,7);
 final[25]=options[3];
 memcpy(final+26, temp+22,4);
 printf("----------------------------------------------------\n");
 printf("your-license-key: ");
 for(i=0;i<strlen(final);i++)
  if (i%7==0 && i>0) printf("-");
  printf("%c", final[i]);
 printf("\n");
« Last Edit: July 21, 2013, 01:46:31 pm by cybernet »
___________________
R0=-0x18;
UNLINK;
RTS;
Offline BravoV
  • +++ ATH1
« Reply #458 on: July 21, 2013, 12:04:13 pm »
You guys are awesome , big thank you !   :-+  :-+  :-+  :clap:
Offline cybernet
« Reply #459 on: July 21, 2013, 12:05:23 pm »
there is some bug, working in it ... so hold your breath for now ;-)
bug fixed. SERIAL is 14 chars not 13 .. i corrected that - and one word of caution, my SERIAL number has just reverted to DS2A0...1 after playing with FW up/down grades
i give a f*ck - but be carefull ;-)
tested with FW05 and FW02 - works.
as long as you can spot the common.ecs parameters in the firmware (aka riglol.c) it should be fine.
some DS4 user should give it a try and report ;-)
« Last Edit: July 21, 2013, 12:31:08 pm by cybernet »
___________________
R0=-0x18;
UNLINK;
RTS;
Offline Carrington
« Reply #460 on: July 21, 2013, 12:15:32 pm »
Amazing, very well done!  :)
Has anyone tried to Sniffing the Rigol's internal SPI bus of the LMH6518 to see if it works at 350MHz, or 200MHz?
Cheers.
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline cybernet
« Reply #461 on: July 21, 2013, 12:25:16 pm »
suggest you read the WHOLE thread, your answers are there.
___________________
R0=-0x18;
UNLINK;
RTS;
Offline docmandu
« Reply #462 on: July 21, 2013, 12:26:03 pm »
Not at home atm‚ so excuse my terseness.
cybernet, you don't need to brute force to go back to serial format. look at my first post in this thread for the algo.
just need to take 5 bits at a time and convert them back to a character.
Offline cybernet
« Reply #463 on: July 21, 2013, 12:28:11 pm »
true, but i thought its a tiny bit cooler, if it actually bruteforces SOMETHING in the process ;-)
im sure some windows guys will do a nice .exe for that .. they can do it more elegant then ..  :-DD
___________________
R0=-0x18;
UNLINK;
RTS;
Offline DanielR
« Reply #464 on: July 21, 2013, 12:28:36 pm »
Works for me on latest firmware on a 2102.
Offline Carrington
« Reply #465 on: July 21, 2013, 12:34:25 pm »
Okay, so I will.
Thank you very much.  :)
Space Weather.
Offline UberSteve
« Reply #466 on: July 21, 2013, 12:36:21 pm »
Big thanks to all involved!  :-+
I can confirm it worked on my recently purchased DS2072 (shipped with latest 01.01.00.02 fw), using DSAZ. I also had ~1900 minutes on the trials remaining at the time of entering the key. It's now a DS2202 with all options "offcial version" ;D
Edit: Also restarted the scope several times just to make sure the options stuck!
« Last Edit: July 21, 2013, 12:38:06 pm by UberSteve »
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #467 on: July 21, 2013, 12:54:39 pm »
Bah, can't get MIRACL to build with cygwin.
Someone make a windows executable. With installer. And an android app  :blah:
Chet
Paid Electron Wrestler
Offline darrylp
« Reply #468 on: July 21, 2013, 12:56:34 pm »
Cue, lots of serial numbers being PM'd to a few people on here ! :-)
 Darryl
Offline cybernet
« Reply #469 on: July 21, 2013, 12:58:40 pm »
dave should host a keygen ;-) a bit of php and it runs ...
___________________
R0=-0x18;
UNLINK;
RTS;
Offline jonese
« Reply #470 on: July 21, 2013, 01:02:05 pm »
FYI:  My serial on my new 3 day old DS2102 is 13 chars, not 14
DS2A151900xxx
Offline cybernet
« Reply #471 on: July 21, 2013, 01:07:06 pm »
DS2A151900xxx
strange, but as long as the secret message matches, it should work as well - will update above code to also allow 13 then.
___________________
R0=-0x18;
UNLINK;
RTS;
Offline alez
« Reply #472 on: July 21, 2013, 01:24:47 pm »
Just some quick feedback.
I have a DS2072 with a DS2A1517xxxxx serial. I can generate the license key, but the scope does not accept it. I have used "DSAZ" as the option key.
Offline cybernet
« Reply #473 on: July 21, 2013, 01:28:13 pm »
use DSA9
___________________
R0=-0x18;
UNLINK;
RTS;
Offline UberSteve
« Reply #474 on: July 21, 2013, 01:32:29 pm »
cybernet, my serial is 13 chars also, DS2A1527XXXXX
« Last Edit: July 21, 2013, 01:45:47 pm by UberSteve »
