I just picked up a 1670G on ebay, and have a few questions:
1) when I first powered it up, it passed all the tests. And then, while still booting, like a dumbass, I noticed there was a floppy in the drive and ejected it. After that, the floppy drive self-test has been failing. Any way of knowing if I just borked the floppy, or the drive unit itself died at that exact point? I can't find any spare floppies to test with right now...
2) and speaking of which, is it possible to replace the floppy drive itself with a USB adaptor? I've seen that done with vintage computers, but not sure if the analyzer would work with it.
3) the next obvious point of concern is the HDD. It's currently working, but with a drive that age it's a concern. Is it a standard IDE HDD? Can it be replaced with anything more modern (SSD, CF card, SD card, etc.)? I saw some discussion about another vintage HP analyzer that suggested that only very specific CF cards worked in it, and these days even those CF cards are unobtanium. Is the 1670G similarly picky?
4) the analyzer came with the pod cables, but not with flying leads. Are E5383A leads correct for this? And are there any differences between the E5383A and the (currently in production) E5383B?
5) EDIT: I thought it was just missing the knob, but it actually looks like the D-shaft the knob was riding on has been sheared off. So I probably need to replace whatever the component is. Service manual just lists the whole keyboard board as a single unit, there's no schematic. Does anyone know what the part is? Potentiometer, rotary encoder, what kind? Can the analyzer be used without the knob, or are there some functions that can only be done with it?
Anything else I need to be aware of with this device that isn't covered by the manual? Bear in mind that I've never used a real LA before (closest I've gotten is an Analog Discovery 2), so things that might seem obvious to you may not be obvious to me
My use case for this is to work on retro computer systems, especially s-100 systems, which is why I wanted a lot of channels. This is strictly hobby use, in case that matters.
