I don't have any other materials to spot-weld, only nickel-plated steel strips, so I can't experiment with other metals.
The tests certainly helped me realize that if I spot-weld a 0.15mm sheet metal to a battery terminal, I can use a power output of up to 35%. However, if I spot-weld two insulated 0.15mm sheets, it's easy to pierce the supports even at 30%. At 20%, however, I see that the work is satisfactory.
From initial testing, I found the ceramic support base to be good for spot welding two metal sheets.
What I was wondering, however, is whether using a non-conductive surface (ceramic, wood) or a conductive one (e.g., stainless steel) as a support surface might affect the spot welding. I still have to run some tests, but I had the feeling, with the same settings, that the two results were slightly different. But I could be wrong. I also found it very convenient to have a nice flat support base, like tile, for straightening the metal sheets properly (with a rubber mallet).
