Author Topic: Siglent SSA3021X upgrade (no SSA+)  (Read 3240 times)
Offline R-1125FTopic starter
« on: March 06, 2025, 08:33:43 pm »
After reading a very long thread about the Siglent SSA3021X hack, I got thorougly lost because the subject kept changing between the SSA3021X, the SSA3021X plus, and the SVA models. The last post to that thread also mentioned the confusion.
All I need is some clear instructions on how to mod the SSA3021X (no plus please!).   I just got an SSA3021X (not plus) with SW1 2.1.1.1.   Can the SSA3021X (not plus) with this version of the firmware be upgraded to an SSA3032X (not plus)?   If so, how?
« Last Edit: March 06, 2025, 08:46:40 pm by R-1125F »
The following users thanked this post: paulvo
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
Re: Siglent SSA3021X upgrade (no SSA+)
« Reply #1 on: March 06, 2025, 09:53:42 pm »
All you need to do is to find the link to the python script that generates the keys for you.
« Reply #2 on: March 06, 2025, 09:55:42 pm »
The only one I have found so far does not work on the SSA3021X (not plus).    Can you point me to the correct version that will work with the SSA3021X?
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #3 on: March 07, 2025, 07:36:07 am »
Send me a PM with your Host ID.
The one you found certainly does work, you just must have forgotten to edit the correct model.
The following users thanked this post: R-1125F
Offline coromonadalix
« Reply #4 on: March 07, 2025, 10:01:07 am »
you did not use the script correctly or made an error, it is possible to convert it to ssa3032x  with no problems
but the ssa to sva conversions  seems to be done with the SSA 3021X Plus series,   not the non plus  ...
« Reply #5 on: March 07, 2025, 10:04:03 am »
Yes, Plus versions are different and later HW.....
Avid Rabid Hobbyist
The following users thanked this post: coromonadalix
« Reply #6 on: March 08, 2025, 03:36:04 am »
A big thank you to Bicurico for sending what I needed.  Today, I also found a link to the correct python script.  The first version I came across only worked on plus models.   I found the one that works for non-plus and plus models today buried in message #1296/1311, but it was a discussion about the plus model.  Here is the link and instructions to the code that works with the SSA3021X (not plus) model.
Open python script http://tpcg.io/_SV2SRE
Inside script change HOSTID to your device Host ID
Uncommentt (remove "#") in front of 'SSA3000X_Plus' (or other models)
Run the script with "Execute" button on top left
The following users thanked this post: paulvo, backyard_cnc, Perbear
Offline backyard_cnc
« Reply #7 on: September 11, 2025, 04:41:33 am »
Does this python script expand the range to 3.2ghz and enable all the software options as well?
Thinking of ordering a 3021x but not sure if the 3021x + is a better way to go. There is a $500 price difference here in Canada between the two models.
« Reply #8 on: September 11, 2025, 06:56:36 am »
Plus models give you touch and mouse control and an excellent webserver.
One of the webserver's overlooked benefits is being able to remotely control the SA as when operating it directly can impose near field effects on the DUT.
The price differential has opened since release but is less here in NZ than in NA which maybe due to the new tariffs.  :-//
If you can spring for the Plus do so and you can thank me later when you discover why.  ;)
Avid Rabid Hobbyist
The following users thanked this post: backyard_cnc
Offline KungFuJosh
  • TEAS is real.
« Reply #9 on: September 11, 2025, 03:41:43 pm »
The Plus model among other improvements, also has better reference level range, and higher resolution on the internal frequency counter.
Best Continuity Tester Ever
« Reply #10 on: November 25, 2025, 12:54:10 am »
Well I went ahead , pulled the pin and ordered up the SSA3021xPlus today, should be here in a few days! Very exciting!
Offline fab13
« Reply #11 on: December 20, 2025, 02:25:12 pm »
Hi there , it appear that "http://tpcg.io/_SV2SRE" with the Python script is not available any more . anyone know alternative ? thx
Offline 807
« Reply #12 on: December 22, 2025, 05:54:33 pm »
Open the attachment in this post with notepad.
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg4355635/#msg4355635
Then copy & paste it into this online python compiler
https://www.programiz.com/online-compiler/
If you have python on your device, you could run it locally instead.
Offline paulvo
« Reply #13 on: July 30, 2026, 12:31:33 pm »
Can the non-plus SSA3021X (SW1=1.3.9.8 and HW=0F.03.00) be enhanced with the VNA option (in order to show Smith diagrams) ?
If yes, I will find the procedure. Just asking as in the HACK-thread so many models are mixed, as OP correctly stated, and not everything is applicable to the non-plus version.
Offline tv84
  • Country: pt
« Reply #14 on: July 30, 2026, 01:52:37 pm »
No.
