It looks like you bought the wrong unit out of the two cheap Chinese signal generators:
https://www.eevblog.com/forum/testgear/feeltech-fy3224s-24mhz-2-channel-dds-aw-function-signal-generator/msg697718/#msg697718
Among those two signal generators (FeelTech FY3224S and MHS-5200A), the FeelTech is the clear winner in terms of performance!
However, be warned. The FeelTech has an issue with the power supply, which requires improvement, as there is a potential safety issue. More details can be found here:
https://www.eevblog.com/forum/testgear/feeltech-fy3224s-24mhz-2-channel-dds-aw-function-signal-generator/msg891787/?topicseen#msg891787
Note that FeelTech has launched a better model recently with a 14-bit D/A converter and an improved power supply design. So maybe the power supply issue is resolved in that newer model.
https://www.eevblog.com/forum/testgear/feeltech-fy3224s-24mhz-2-channel-dds-aw-function-signal-generator/msg963834/?topicseen#msg963834
I do think it's a little harsh to immediately step in to a thread and tell them they've made a bad decision, but to each his own.
There are advantages and disadvantages to either. Looking through the specs, the main thing that I can see that would be in favor of the MHS-5200A is that it has the extra TTL inputs/outputs, which might be useful when doing sweeps or using the generator to make, like the following:
Though I have to admit, I have a MHS-5200A, and I have tried to do this (though not using TTL) and did not succeed fully.
Certainly it would be worth learning what the new device from FT is like.
I actually have
two MHS-5200A devices. One from a US source, and one a Chinese source. Both of them are of the newer, redesigned variety which does not seem to have resistor modification instructions to fix the square wave ringing and overshoot (though these issues appear to actually be fixed anyway).
I am in the middle of doing a teardown for both, a shot-for-shot and component-by-component comparison, and I have already run several tests (and will re-run them and record them) on both.
So while it's not comparing on SG to another, it is comparing one SG to itself -- both for a consistency check and a manufacturing and QA check.
