The closest you can get is the "TDS340A, TDS360, & TDS380 Technical Reference", 070-9436-04. It does have schematics, but not for your exact model. PDF is available from tek.com and several other places.
Excellent!!!, this was of great help, it shows the oscilloscope is using an MC68331 processor running at 15.15Mhz.
Some thoughts after looking at the pdf:
- The flash memory for the firmware is 256Kb x 3 = 768Kb... That's a lot!!
- The option board comes with a 256k EPROM... Isn't too much?
- Another way to hack the oscilloscope is to tap onto the timebase module.
- At some point is says "Increase the frequency of the generator output to 100 MHz (TDS 340),200 MHz (TDS 360), or 400 MHz (TDS 380)."
- Sice this schematic is valid for all 3 oscillsocipes, does that mean that the TDS340, the TDS360 and 380 use them all the same hardware? Then with a SW hack you could convert a 100 Mhz into a 400Mhz right?
Cheers
