Author Topic: Teardown B&K 2120 Scope  (Read 12506 times)
Offline med6753Topic starter
« on: December 16, 2015, 03:11:59 pm »
This is my first teardown thread. A B&K 2120 20Mhz Scope I purchased new in 1991 to replace a Heathkit IO-4540 5Mhz Scope I built in the 1970's. Back then going from 5Mhz B/W to 20Mhz B/W was quite a leap in performance which looks rather trivial today. The B&K has served me well over these many years and for a while was the only scope on my bench. Lately I've noticed intermittent and noisy contacts on both channel's attenuator switches and high frequency roll off. So it's time for a good cleaning. But getting to the switches involves major teardown and shield removal. So let's get started....
With the case removed there's the upper board consisting mainly of the trigger circuits, a portion of the linear LV supply, and the high voltage supply. The CRT is to the left. Both the board and CRT will be removed.
Close up of the upper board.
The CRT is from Japan by Toshiba. The scope itself was made in Taiwan.
Neck and gun assembly of the CRT. Since the HV is only -2KV there is no anode cap on the bell of the CRT. The HV enters via one of the base pins.
Upper board and CRT removed. No unsoldering was required to remove them. I was surprised that the CRT had an internal graticule just like the big boys. Having it removed gave me an opportunity to clean the face plate for the first time.
The Input Board with the shields covering the input attenuator switches. They are soldered to the foil side of the board.
I got the shields unsoldered but things did not go as planned from that point. They would not clear the vertical position control assembly immediately above it. That assembly is attached to the front panel with a set a screws requiring a sub-minature allen key in a size I don't have. Plus I discovered that the shields themselves have a front lip that wouldn't clear the attenuator switch decks if I tried to pull them straight back. I looked at removing the entire input board and that required a lot of dis assembly and unsoldering. Not something I really wanted to get into. Since the shields were now loose from the board I was able to pull them up slightly and I could see all 3 decks of the switches. So I carefully sprayed the deoxit with the extension tube on each deck. Not the best solution but hopefully I would get lucky. Resoldered the shields and reassembled the scope.
Success! The Volts/cm switches for both channels are now rock solid. Channel 1 shows some peaking on the square wave. Channel 2 looks much better. I also noticed that the timebase is slightly off. The source waveforms are from a homebuilt function generator utilizing the 8038 chip. The outputs are fixed at 0.5V p-p and 5Khz. I use it specifically to quickly check basic scope functions. So a project for after the holidays is a complete alignment/calibration.
« Last Edit: July 18, 2017, 10:53:03 am by med6753 »
Re: Teardown B&K 2120 Scope
« Reply #1 on: January 10, 2016, 06:28:45 pm »
Update to this teardown. Finally got to perform a complete calibration and everything came within spec.
Source: 5Khz, 0.5 v p-p Square from 8038 function generator chip. No more peaking on Channel 1. 50uS sweep on scope and it's right on the money.
Pushing the envelope for a 20Mhz scope. 1 Mhz Square from a Heathkit IG-4244 Oscilloscope Calibrator. Special cable with built in 50 ohm termination. Scope sweep set to 2uS with X10 engaged. Looks reasonable.
Ready for another 25 years of service  ;D
« Last Edit: July 18, 2017, 10:54:39 am by med6753 »
Offline alank2
« Reply #2 on: April 20, 2016, 07:01:12 pm »
Great teardown.  I get a little noise when switching the vertical - where exactly did you spray deoxit?  I've got some radio shack contact cleaner - would it also work?  I'm not sure I want to tear it down as much as you did!
ALSO - one thing I didn't realize until a few days ago was that you can pull the trig level switch to only have it display when the trigger is satisfied.  It probably seems basic for an analog scope, but I didn't know it was there.  Your mention of the X10 tipped me to look for the X10 on the timebase too!  I wondered how it could display anything close to 20 MHz until I found it!
« Reply #3 on: April 21, 2016, 12:45:00 am »
The RS contact cleaner isn't going to cut it. Those deck switches seem to get a lot of corrosion. Look at the Time/Div switch deck and you'll see what I mean. You'll need this...
Unfortunately you can't do an adequate job of cleaning the volts/div switch decks unless you pull the shields as I did. The culprit for most of the noise is the deck closest to the front panel. You can't get the deoxit on it unless you lift the shield.
And if you are going to pull the top board I recommend changing out all the resistors in the focus divider circuit. I've had several of them go open over the years. I don't have the schematic in front of me at the moment. I'll post it later and identify the resistors you should change.
« Last Edit: July 18, 2017, 10:29:09 am by med6753 »
« Reply #4 on: April 21, 2016, 10:35:19 am »
Here's the HV and CRT schematic. The resistors that you should consider changing are R526, R527, R528, and R529.
« Last Edit: July 18, 2017, 10:07:10 am by med6753 »
Offline alank2
« Reply #5 on: April 21, 2016, 01:14:03 pm »
I appreciate the help - I'll order some of the deoxit and see about getting it apart!  I may have more questions when I get there!!
Offline alank2
« Reply #6 on: April 21, 2016, 01:49:03 pm »
Is deoxit D5 the same stuff?  You get 2.5x as much for 2/3 the price...
« Reply #7 on: April 21, 2016, 01:53:44 pm »
I don't know. Perhaps someone else can answer that.
Offline Fsck
  • sleep deprived
« Reply #8 on: April 21, 2016, 01:56:41 pm »
it isn't. D5 is a 5% solution, D100 is 100%.
"This is a one line proof...if we start sufficiently far to the left."
Offline alank2
« Reply #9 on: April 21, 2016, 02:24:07 pm »
That answers it allright!
Offline alank2
« Reply #10 on: April 21, 2016, 11:22:15 pm »
Those service manual says the focus resistors are carbon - should I order that or would metal film be an improvement?
« Reply #11 on: April 22, 2016, 12:34:53 am »
I used carbon because that's what I had on hand. But I think metal film would be a better choice. Just make sure they are .5 watt or better.
Offline alank2
« Reply #12 on: April 22, 2016, 08:45:34 pm »
I'm waiting for the Deoxit to arrive.  Will order the resistors Monday.
Did you have to remove the tube for some reason, or just the top board?  Do I need to be concerned about emptying any capacitors?
Is it easy to remove those black metal bands for the controls?  where they connect to the pot.
« Last Edit: April 22, 2016, 08:52:02 pm by alank2 »
« Reply #13 on: April 22, 2016, 11:31:22 pm »
In order to gain access to the shields from all angles it's best to remove the CRT. It comes out fairly easily. Yes, good idea to make sure the caps in the HV generator circuit are fully discharged.
If you are referring to the extension shafts such as on the Intensity and Focus controls all you have to do is pull forward carefully and they come off.
Offline alank2
« Reply #14 on: April 28, 2016, 12:12:38 am »
It is coming along great.  I got it all apart and it did take some work to get those shields off.  I cleaned up the switch decks with an eraser and then sprayed them with the deoxit afterwards.  I went ahead and sprayed the other pots that had access as well.  I went through the calibration steps and all is going well so far except:
The timebase talks about VR801/VC801, but my PCB as three adjustments VR803, VR804, VR805 instead:
VR803 is for the fast timebases
VR804 begins at 50us
VR805 begins at 5ms
These were not too hard to calibrate.
I had a problem on step 13 of the trigger adjustment - is talks about adjusting VR309 to get 0V on the collector of Q610, but my meter shows +23VDC.  Changing VR309 does not do anything.  Then you repeat it for CH2, changing VR310.  Still not working - still +23VDC.  Any ideas?
ALSO - the corner where the transformer is gets quite warm without the case on - I wonder if it gets as warm with the case in place.
The scope is working so much better now...
« Last Edit: April 28, 2016, 12:15:08 am by alank2 »
« Reply #15 on: April 28, 2016, 12:35:33 am »
VR805 begins at 5ms
I had the same issue. The service manual and the scope did not match. There must have been a revision but the documentation was not updated. I was able to tweak the 3 controls and get the timebase reasonable throughout it's range but it did take some time.
My trigger circuits were in spec so I did not attempt any further calibration. So I don't know what the issue might be.
Yes, the transformer get quite warm even with the case on and it's normal.
« Last Edit: April 28, 2016, 12:38:45 am by med6753 »
Offline alank2
« Reply #16 on: April 28, 2016, 02:13:46 am »
Does your CAL output go to 0.2V p-p?  Mine won't adjust that large, I ended up going with 0.1V p-p instead...
« Reply #17 on: April 28, 2016, 10:28:29 am »
Mine is exactly 0.2V p-p so I would say there's an issue with your calibrator circuit. There's not much to it so it should be easy to identify the problem.
Offline alank2
« Reply #18 on: April 28, 2016, 12:56:06 pm »
4.92V is going into the calibrator circuit.  The resistors check out as does the pot.  I tried cleaning up some of the rosin junk around it but that did not change it.  Bad IC?  If I changed R901 to a larger value I could maybe get it to go higher...
« Reply #19 on: April 28, 2016, 01:30:32 pm »
Check R904 (6.8 ohm) to make sure it hasn't increased in value. If it has it will lower the Vcc to U901 which will reduce it's output. If all the other passive components check out then I would agree that U901 is bad.
Offline alank2
« Reply #20 on: April 28, 2016, 01:37:03 pm »
It was like 7.02 ohms.  I sure wish it was socketed!!!
Offline alank2
« Reply #21 on: April 28, 2016, 03:01:09 pm »
I wonder if the heat producer near the transformer is actually the BUX86 (Q503) transistor bolted to the back of the chassis.  It seems especially warm.  It is part of the +140V circuit.
Offline alank2
« Reply #22 on: April 28, 2016, 09:24:40 pm »
I took a look at the scope running with my Flir E4 and, wow, it has some resistors (R838,R839) that run 100 deg C !  Would this unit benefit from forced air?  That seems pretty warm but perhaps that is just the way it is made.
« Reply #23 on: April 29, 2016, 12:45:21 am »
Yes, the scope does run very warm and I'm sure could benefit from some air circulation. Problem is there's no room for a fan.
All I can say is that I've had mine since 1991 and it's never had a heat related failure and it's sometimes been on for hours.
Offline alank2
« Reply #24 on: April 29, 2016, 01:01:13 am »
I agree, I don't see anyplace inside where a fan could be fit.  I'm tempted to connect a 60mm square type fan to the back cover with some zip ties and at least try to pull some air out at that point so air will enter all the case vent holes.
