Author Topic: Teardown : Keithley Model 182-M sensitive voltmeter  (Read 4582 times)
Offline TiNTopic starter
  • Country: ua
    • xDevs.com
« on: September 18, 2015, 08:35:45 am »
Traded one of my 2001 DMMs for this interesting instrument.
Tbd..
If you have ideas for experiment involving low DC voltage , let me know.
« Last Edit: September 18, 2015, 03:17:38 pm by TiN »
Offline daqq
  • Country: sk
    • My site
Re: Teardown : Keithley Model 182-M sensetive voltmeter
« Reply #1 on: September 18, 2015, 09:24:32 am »
Try some test plugs thermal voltage. Also banana connectors, coaxes, all sorts of connectors really. That would make a nice experiment - where can you find your unwanted thermocouples.
Offline Zucca
  • EE meid in Itali
« Reply #2 on: September 18, 2015, 09:34:22 am »
Congrats! I was looking for that too. I am happy it is in your good hands now.
1) Take a high amp connector, see what the voltage drop is in high current situations (>30A let´s say). will it be linear to the current or the temperature effect will kick in?
2) We all know the GND layer on a PCB, test how much it will shift in an interesting PCB. Will it be 0V also on the other corner of the board?
3) Take different op amp and test the Offset Voltage on the output
4) What about different DACs with the output set to zero? Will the analog output will be zero?
BONUS) Try to measure how much current it is needed by the 182-M to do its measures.
Bye
« Last Edit: September 18, 2015, 12:13:26 pm by zucca »
  • Country: ua
    • xDevs.com
Re: Teardown : Keithley Model 182-M sensitive voltmeter
« Reply #3 on: September 21, 2015, 04:09:10 pm »
Alright, first part of review is public, second part will feature measurements and more comparisons.
Few money shots : front-end and LMx99 ovenized voltage reference.
This will be interesting, I'll try to do this.
