Author Topic: Teardown : Agilent 4142B semiconductor DC test mainframe/SMU  (Read 12141 times)
Offline TiNTopic starter
  • Country: ua
    • xDevs.com
« on: April 02, 2016, 12:04:44 pm »
I have something special today to show you, dear test gear nuts :)
Let's see your scherlock skills.
Guess the equipment model by little piece on the photo? There is enough information around to make exact guess :)
EDIT:
It's 4142B with some modules I got for 200$+230$ shipping.
This beast is 29kg, full 4U size, so not easy to haul it :).
Peek inside it's rather special power supply:
GNDU SMU (1.6A sink, 0V) + ADC
Isn't this BB DAC gorgeous?
SMU module 41421B:
Some high-impedance teflon action:
Everything seem to work just fine.
Added some wires to check main 10V reference:
Measured just fine:
« Last Edit: April 02, 2016, 09:25:56 pm by TiN »
The following users thanked this post: crispy_tofu
Offline Earendil
  • Country: hu
Re: Teardown : new analog voodoo gear
« Reply #1 on: April 02, 2016, 06:30:14 pm »
HP 4142B?
Offline Smith
« Reply #2 on: April 02, 2016, 07:47:53 pm »
Some HP SMU? At least is says SMU, and the silk seems to be HP :)
Trying is the first step towards failure
Offline ywara
« Reply #3 on: April 02, 2016, 08:07:58 pm »
41421B 100V/100mA module for the 4142B. Looks to have fairly impressive current resolution.
  • Country: ua
    • xDevs.com
Re: Teardown : Agilent 4142B semiconductor DC test mainframe/SMU
« Reply #4 on: April 02, 2016, 09:28:22 pm »
Bingo! :)
I took lots of photos of all modules and supply boards, and posted them in article on my site
Enjoy. Even though unit was made in 1992/2000 (different boards different date codes), it does not have a single spec of dust. My best guess - it was in clean room of semiconductor facility, hence pristine condition. Not a smudge of dust even on fan blades, and trust me, those 120x38mm 24V fans are no joke.
« Last Edit: April 03, 2016, 06:39:57 am by TiN »
Online nctnico
« Reply #5 on: April 02, 2016, 09:48:52 pm »
Neat! One of the hidden gems you can stumble upon and if you can take the noise from such a machine then why not?
Quite some electronics porn inside as well.
Offline Vgkid
« Reply #6 on: April 02, 2016, 11:47:10 pm »
Nice unit, what is the internal vref?
  • Country: ua
    • xDevs.com
« Reply #7 on: April 12, 2016, 10:41:30 am »
REF102CM, as I shown in article.
I received broken 41420A SMU module off ebay, this one definately need some repairs :)
python ./cvr.py
HEWLETT PACKARD,4142B,0,4.30
0,0;HP41421B,3;0,0;HP41424A,1;0,0;HP41424A,1;0,0;HP41420A,3
8423,0,0,0
According to HP-IB manual reference error 423 (8 is just meaning it's slot 8 module) is :
SMU is not functioning properly. SMU failed I Monitor Amp. Offset Error Test of Self-test.
What ever that means..
  • Country: ua
    • xDevs.com
« Reply #8 on: April 13, 2016, 05:23:15 pm »
Here's 41420A photos for those who care:
DAC is same as in 41421B's.
More similar hybrids:
And rest of 'em:
Back of the output board still have flux. Not pretty, but it's not the reason why module failed..
Triax outputs:
Moar green transistors from NEC Japan :
Offline free_electron
    • SiliconValleyGarage
« Reply #9 on: April 13, 2016, 07:22:11 pm »
that's a yokogawa-hp machine.
  • Country: ua
    • xDevs.com
« Reply #10 on: May 04, 2016, 12:09:01 am »
Here's front panel looks after some H2O2 procedures:
Having so tight plastic wrap is actually not such a good idea, as that made barely visible areas of different tint due uneven UV exposure. Works for first try, but lesson for next time. ;)
Overall happy with the process. Bodged quick guide article about it. Keithley panel is out now this time..
Offline nidlaX
« Reply #11 on: May 04, 2016, 12:16:17 am »
God, why have I been running around salon / beauty supply shops when I could just buy that stuff from Amazon. :scared: :palm:
Offline lukier
    • Homepage
« Reply #12 on: May 04, 2016, 12:36:46 am »
You don't add Tetraacetylethylenediamine (TAED) as an activator? This I believe is mentioned in the original Retr0bright receipe. It doesn't make a difference?
  • Country: ua
    • xDevs.com
« Reply #13 on: May 04, 2016, 12:43:27 am »
No, i did not add anything.
  • Country: ua
    • xDevs.com
« Reply #14 on: August 23, 2017, 11:00:55 am »
It's been awhile since this thread was created. I got just "few" additions today.
* Bad 41420A got long ago, fails self-diagnostics. Error code is 423, according to service "I monitor opamp fail" on output board A2.
How to fix? Buy more donors!  :-DD
Today arrivals:
* Two supposed to be good 41420A HPSMU (40uV-200V, 1nA-1A ranges, 20fA best resolution). Installed into box, both run w/o errors.
* Third, supposed to be bad 41420A HPSMU (40uV-200V, 1nA-1A ranges, 20fA best resolution). Installed, running w/o self-test errors. Hm?
* One more 41425A monitor (it's like a fast analog comparator between SMUs levels, handy for tracking measurements). No self-test errors. I've already had one from before :D.
Red zero means no errors detected.
There are few more modules for cheap on ebay, so SMU-nuts, beware of EEVBlog/xDevs effect. Bunch of hi-res photos in my old teardown article still available. Plenty of AE foil resistors and japanese green FETs insides, with fancy shielded reed relays.
And finally with Keithley 6485 I can actually hook it all up and measure some low currents. Wonder who is more noisy, Keithley picoammeter (lowest range 1nA) or JHP SMU?
Offline plesa
« Reply #15 on: August 23, 2017, 07:40:49 pm »
I do not know HP SMU, my guess is - Keithley 6485 is more "noisier" meter :)
  • Country: ua
    • xDevs.com
« Reply #16 on: October 31, 2017, 04:56:29 am »
As SMU-nuts may learned already, triaxial cable set for SMUs can often cost as much as SMU itself.
I received today a jackpot, perfect match for my 4142B:
This cable designed to connect 4142B with four SMU modules and one VM/VS module to the HP 4085B semiconductor analyzer switch matrix.
Offline HighVoltage
« Reply #17 on: October 31, 2017, 09:13:41 am »
Very interesting!
I bought the very same set a few month ago and have run out of Triax cables / connectors again !
Offline Berni
  • Country: si
« Reply #18 on: October 31, 2017, 10:26:59 am »
Dang! That is a score indeed. I was forced to make my own and it still cost a fortune!
Offline plesa
« Reply #19 on: October 31, 2017, 01:35:43 pm »
It looks like you are planning prober for Christmas :)
