Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Tek 547: Ground? What Ground?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tek 547: Ground? What Ground? (Read 1472 times)
scuzzyTerminator
Regular Contributor
Country:
on:
March 12, 2019, 06:13:21 am »
I have a Tek 547 stashed away where it can't easily be checked for awhile.
I was browsing a thread about using an isolation transformer for scopes (Bad Thing) and remembered that my old beast has a two prong plug with no earth. I had assumed it is the original equipment - I'm old enough to remember that it would have been hard to find an earthed oulet to plug it into in the early '60s.
So I'm wondering what the probe ground reference is supposed to be. Mains neutral? Floating?
Logged
Jeroen3
Super Contributor
Country:
Embedded Engineer
Re: Tek 547: Ground? What Ground?
Reply #1 on:
March 12, 2019, 09:08:33 am »
Did you check the manual what was delivered with the unit?
Logged
bd139
Super Contributor
Country:
Reply #2 on:
March 12, 2019, 10:48:06 am »
AFAIK they came with a 3 pin socket on the back so the earthyness is up to the user to work out. I remember in my short spell in industry, our scopes were ground strapped separately to the mains lead. They were somewhat newer than a 547 though.
Logged
TEA
and
more TEA
med6753
Super Contributor
Country:
Tek nut
Reply #3 on:
March 12, 2019, 03:01:05 pm »
Go back and look at your 547 again. I'm familiar with them and have never seen one that WASN'T a 3 prong plug.
Understand that these scopes were almost always in a lab environment. Labs were early to implement 3 wire grounding where as typical US residences built after WW2 and up until the early 1960's were not.
Logged
scuzzyTerminator
Regular Contributor
Country:
Reply #4 on:
March 12, 2019, 08:53:53 pm »
Thanks for the replies. I thought someone might have a similar scope for a quick answer or check but it looks like I'll need to dig mine out. That will be awhile.
The power cord is two pronged and connects directly to the scope without a receptical. It is worn at the entry showing the two wires within. I had been thinking of replacing it with an earthed cord and assume that I could just put earth to chassis.
When I get it out I can check for conduction of chassis with probe ground and mains neutral.
This is a '60s model that I bought in the '80s.
Thanks again.
Last Edit: March 12, 2019, 08:57:42 pm by scuzzyTerminator
Logged
David Hess
Super Contributor
Country:
DavidH
Reply #5 on:
March 12, 2019, 09:18:58 pm »
My stock 547 has a three prong power connection. So does my Lavoie LA-265A which is a clone of the Tektronix 545A.
Logged
scuzzyTerminator
Regular Contributor
Country:
Reply #6 on:
March 12, 2019, 10:38:26 pm »
Found manual at:
http://w140.com/tek_547.pdf
I have a 1A4 plug-in:
http://bee.mif.pg.gda.pl/ciasteczkowypotwor/Tek/1a4.pdf
The videos at "Tektronix 547 (Tek 547) Oscilloscope Restoration":
https://lazyelectrons.wordpress.com/2018/07/06/tektronix-547-oscilloscope-restoration/
are way cool, But he clearly has a 3-pronger.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
