Author Topic: TEK2440 set probe attenuation  (Read 1150 times)
Offline rvalenteTopic starter
  • Country: br
« on: August 25, 2020, 07:41:18 pm »
Hello mates,
i'm kind of ashamed to ask this but, where on earth should I change my probe to X10 on a tek 2440?
The only thing the user guide metion is it automatically adjusted when used tek coded probes, but I'm using just a regular probe.
file:///D:/Downloads/2440.pdf
Offline LazyJack
  • Country: hu
  • Yeah, cool.
Re: TEK2440 set probe attenuation
« Reply #1 on: August 25, 2020, 09:06:18 pm »
You can't. It is automatic only, there is no way to manually override.
  • Country: br
« Reply #2 on: August 25, 2020, 09:44:29 pm »
What were tek engineer thinking?
Does anyone knows the resistor values for setting at x1, x10, x100 and x1000?
« Reply #3 on: August 25, 2020, 09:53:36 pm »
They wanted you to use their probes.
Open, 10K, 20K I think and not sure.
A dig around the internet should find the values.
Sensing probes aren't that expensive, you should get some.
Avid Rabid Hobbyist
  • Country: br
« Reply #4 on: August 25, 2020, 10:14:35 pm »
Had a little fun now..
X1 - 15 to open
X10 - 10k, 12K
X100 - 7K
X1000 < 3K to short
I agree, but just a few of my probes are from tek, sometimes a no brand chinese to mearure 100Khz is just fine hehehehehe
Anyway, I like the self detection probe, very useful, but come'on tek, what were you thinking for not leaving a damn menu to choose...
Lets say I have a weird 250:1 probe, can't u left some custom value to fill, just like you do in the newer scopes?
« Last Edit: August 25, 2020, 10:24:03 pm by rvalente »
Online MarkL
« Reply #5 on: August 25, 2020, 10:39:27 pm »
Here's some tables for probe readout pins:
  https://www.electronics-related.com/showthread/sci.electronics.design/116046-1.php
There's not consistency between manufacturers, or even between models from the same manufacturer.
The following users thanked this post: rvalente
