Hmm. Maybe I'll give it another try. The software (V4.4) on the logic analyser itself runs very slow even with a Pentium 200MMX overdrive upgrade so it would be nice to run it on a desktop PC. Could you post the modified setup.inx file somewhere?
BTW I 'know' RFDES as well. Actually the 800x600 upgrade was my idea to begin with I hacked the GRUB bootloader to do a call to the video BIOS to switch to 800x600 before the OS gets started. RFDES hacked the BIOS which is much easier.
Nico,
I was working my own mods, when I read your posts way back when, and your strategy was kewl. Thanks for sharing. Later I bumped into RFDes, and I learned that his strategy was a bit further along the modification curve than any of the other strategies that I tracked down including that of my own. In any case it still took me two years to do everything. Hah. The PCB I made took forever to finish...life got in the way, but it sure does work nice. I'll include some photos for ya'll to gander at.
To your point, I asked RFDes' permission to refer folks to him last week prior to posting about my TLA mods here in EEV_Blog. But, heh heh, if you're shy
, just say, "hey I bumped into w.w on EEV_Blog, I'd like to ask for a copy of the .inx file" and say hello too.
Yep, his LCD BIOS solution works well, no fiddling around, just turn the scope on. And remember to ask for the tlaSoftOff.exe driver, unless, you like myself, before getting his driver, ya cut holes in the TLA box to install a hard-off power-switch which is no longer needed. Mine is out of the way, I used an Alco alternating 6Amp 250VAC push-button power-switch, recessed into a 1.5" x 1.0" (38,1mm x 25,4mm) milled slot in the right-side plastic louvre cover. Frankly, its nice to be able to actually turn-off the power-supply. Win2k doesn't handle the scope's front-panel 'power-switch' hardware interrupt properly and it crashes the system. But I've reviewed & downloaded your I2C/SPI sauce-recipe over on SparkFun (yep....mighty tastey too), so its likely that you could also write your own soft-off handler, but why? When there's a perfectly functional solutionavailable simply for the asking? Me? I aint shy, I fully intend to implement your serial bus decoder and experiment with it, and hopefully to make some enhancements too. For instance in my other project, I need a Manchester serial decoder, so maybe I can hack your base code to implement this feature. Which I'll share with folks in the old InterNet tradition.
Oh, lest I forget....how did you upgrade your processor and have you seen any timing artifacts attributable to the speed upgrade? However, my Ma said I was born with soldering tool in my hand...and I do have a hot-air rework station, but only a SoldaVac for suck'n solder. I'm reticent to attempt to unsolder the processor, although I do have a spare mainboard for backup in case I munch a trace. The PCB looks tight to me...thru-hole diameters. Was that your experience? Are they tight? In the old days, some folks mechanically broke-up the big IC packages, unsoldering each pin individually grabbing them from the top while heating the pin on the bottom, but I'm not certain that will work in this case. I've been considering using my mini-mill to just shave off the top, then unsolder the pins. That could work, hopefully diminishing the possibility of damaging the mainboard. Any one got any insight into something like that?
So how did you get that puppy off the board? And did you stick in a socket for the MMX? Which part did you use? Got any photos of the finished mod? Does it need cooling? Not forgetting about the height. But if your's works, why would I need to solder in a socket, true?
Oh, and I've been following the TLA7AAx discussion too, very interesting. I wonder if that Tek strategy is employed in the other modules? TLA-7Nx series, 128k? I understand that they go up to 4Mb, you know anything about that? All my modules are pre-counter/timer S/Ns.
Thanks for sharing your code and other ideas.
The photos, in no particular order:
- Brendie, my lab assistant, she oversees all my lab activity making sure everything is purrrfectly proper, heh heh
- Schematic & PCB Layout (Eagle v5.50 Std)
- LCD 41pin to 34pin IDC cable adapter silkscreen (blue)
- PCB installed onto LCD assembly, showing the inverter power cable snaking across
- my homebrew reflow oven, showing blower attachment (gotta have this or it doesn't work)
- screen shot of the oven control sw reflowing the PCB
Cheers
bench_knob
or ya can skipe me, at 'zeebra underscore xray', add me to your contacts list... nifty way to send files that gaaglemale doesn't track...
