Is use of hot air no better to remove the caps?Ripping off the caps from the PCB could destroy the PCB. If you have to remove up to 100 caps you can have luck with 90% but the rest could be catastrophic.
With surface mount parts, it is sometimes easier to crush and remove the body with a pair of pliers and then unsolder the leads from the board.
