Thanks Alex - I'm coming to the conclusion that the S-6 is not working properly. I have one last idea though - I discovered the Bridge Balance adjustment. The photo below happens to show it for a S-1 in an older scope but I believe the Bridge Balance adjustment is on most or all of the S heads including the S-6. It looks like in this older scope it might have been adjustable with the scope covers off but it also seems like maybe this is something that was intended to be adjusted iteratively while the S head was outside the scope. I'm going to try some settings through the range on the S-6 to see if it makes any difference. Plz let me know if you have any experience with the Bridge Balance.
I have all the manuals (S-1, S-6, S-52, 7S12, 7S11, 7T11) - they are pretty helpful but sometimes a bit hard to decipher; too bad they aren't pdf searchable but for decades latter beggars can't be choosers.
Also, just for the record I'm posting an image from the S-52 outputting to the S-1 in the 7S12 - look about right, right? The image I posted looks pretty similar to the (A) image from the 7S12 manual - but maybe inverted? I think the manual probably is showing a S-52 pulse sampled with a S-6 vs. my image which is the S-52 pulse sampled with a S-1. I'm inclined to think the image shows that the S-52, S-1, and 7S12 are working (but so far the S-6 is not). What do you think? Thanks again. EF
