For example, I can get this falling edge at 200ps per Time Div on 1x but I can't get it at 200ps per Time Div on .1x ...?
Time distance is also multiplied by multiplier (10, 1 or 0.1). So it is 100 times shorter with X.1 than with X10. It means that you can see with multiplier X.1 only 1/100 part of the wave which you see with multiplier X10.
This is very helpful info - Thx! But if the time/distance knob is working properly with the full range that would seem to imply that I should be able to duplicate your photos; in other words, I should be able to show the extreme left hand side of the waveform at both 10x and 1x (and also .1x), right?
I think I need to find the "easiest" part of the waveform to zoom in on from 10x, to 1x, to .1x - not sure where that is yet... left size, middle, or right size. (Normally I think it wouldn't matter but I think something is off with some adjustment on my setup.)
Or, are you saying that at the 0 time/distance setting the view of the edge should be retained at all 3 settings (10x, 1x, and .1x)? Thx
Question: is the amplitude also multiplied by the multiplier? Or only the time/distance? Thx
