Hi EV,
I posted your image below to use as reference to adjust the 7S12. (Before trying to fully figuring out how to read the TDR dial I thought it would make sense to align the scope traces as precisely as possible.)
Is line A intended to be just to the right of the boundary line or should it be exactly on the boundary line? If to the right, how far? (Or is that first pulse intended to be exactly 1us, and be aligned in the first time div?)
Was B intended to be at 100%?
Assuming B is at 100% should F be 50mV down from the 50% line (ie, at -50mV)?
Going for maximum precision, should the top of the E trace be just barely touching the bottom of the -100mV line or should the trace be centered vertically on the -100mV line?
Following the diagonal rise, should C intersect the 50% line at .4us into it's division - and should the width of that pulse be .8 us?
Thanks, EF
