Thanks,
Yes , just take apart and knocked around to look for false contact.
Pull out and refit all transistors in vertical preamplifier board . Also for connectors.
Seem strange to me ,all function works ;basetime it's ok , it can trigger the weak signal from output calibration ( I've put also a stronger signal from wave gen.) but on screen it' always compressed .
If i touch the probe with finger , the signal goes over the full screen (my higher body impedance..) if this coulb usefull... And this happen on both channel . I'm going to check the voltage at first but signal on screen goes to became "clipped" . Isn't ?
See soon
